Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 07-17-2012, 21:11   #1 (permalink)
Member: 1542807
Nokia E52 - corrupted simlock area after writing RPL [Solved]
Hello,
I have Nokia E52 with corrupted IMEI (123456..., startup failed, etc.). So I bought RPL (calculated from ASK file) and wrote it to the phone.
Here's the log:
Skipping RPL decryption...
Parsing decrypted RPL...
Processing FBUS Part...
Writing Simlock...
Handling as SL3 Simlock Data
Handling as SIMLOCK2 Format
Reading Security Block...
Security block OK and saved to "RM-469_12345610654321_2012-07-15_143647.SecurityBlock.PM"
15 Digits NCK Found
Simlock ACCEPTED OK !
Writing Superdongle key...
Superdongle Key ACCEPTED OK !
Writing CMLA key...
CMLA Key NOT ACCEPTED !
Writing WMDRM PD Data...
WMDRM PD Data NOT ACCEPTED !
Processing FLASHBUS Part...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104
CMT_EM_ASIC_ID: 00001040
CMT_EM_ASIC_ID: 00001030
CMT_PUBLIC_ID: 14D0010975400E49CE5178EE0A602065A1D9F871
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695
CMT_BOOT_ROM_CRC: 3E273BF6
CMT_SECURE_ROM_CRC: 37BE26FA
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020004000000031, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 85F252E351E225CAFC4DFBC8041EABD2823E3500
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Write RPL Finished!
Analyze security log:
Started Phone Security Analysis...
MCU Version V ICPR82_11w16.3.5
MCU Date 19-08-11
Product RM-469 (Nokia E52)
Manufacturer (c) Nokia
IMEI 3593270XXXXXXXX
Mastercode 7070XXXXX
Security block OK and saved to "RM-469_3593270XXXXXXXX_2012-07-15_143806.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
-- SIMLOCK PROBLEM --
Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED!
To repair simlock area, Select Unlock method : "RPL CALCULATION",
And then click DIRECT UNLOCK. SL Area will be re-formatted.
Step 2 : Testing SECURITY
SECURITY SEFLTEST PASSED OK!
Step 3 : Analyzing Security Block
"14D0010975400E49CE5178EE0A602065A1D9F871.B000089B " Exists, That is good...
Checking SUPERDONGLE...
SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
Checking SIMLOCK...
Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Checking MCU&DSP TIMESTAMPS...
MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
Checking CMLA KEYS...
CMLA KEYS FOUND AND CHECKSUM OK! PASSED!
Checking ECC KEYS...
ECC KEYS FOUND AND CHECKSUM OK! PASSED!
Checking DIV KEYS...
DIV KEYS FOUND AND CHECKSUM OK! PASSED!
Analyze finished!
Read info log:
MCU Date 19-08-11
Mastercode 70705XXXXX
IMEI Spare 3A952307XXXXXXXX
IMEI SV 3395230723XXXXXXXX000000
PSN 0
Product Code 0593914
PSD 0000000000000000
LPSN 0
WLAN MAC A87B39283E1F
APE SW 081.003
APE Variant 081.003081.003.06.01081.003.283.02
APE Test v0.a091
APE HW 256
APE ADSP 256
RETU 40
TAHVO 00
AHNE 11
RFIC |Vapaus_5.1 | Aura_?.?
DSP ICPR82_11w16
Failed to read info -> Failed to read SP info
As you can see, simlock is accepted, but simlock test is failed (before writing RPL, simlock was ok and test passed). As a result, IMEI is recovered, but simlock area damaged.
Any solution plz?
Old 07-18-2012, 07:29   #2 (permalink)
fortunemobile's Avatar
Member: 1728389
Sonork: 100.1617627
Originally Posted by jatza View Post
Hello,
Here's the log:
Writing Simlock...
15 Digits NCK Found
Writing CMLA key...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Write RPL Finished!
MCU Date 19-08-11
Checking SIMLOCK...
Analyze finished!
Read info log:
MCU Date 19-08-11
PSN 0
LPSN 0
APE SW 081.003
APE Test v0.a091
APE HW 256
APE ADSP 256
RETU 40
TAHVO 00
AHNE 11
DSP ICPR82_11w16
Any solution plz?
Bro do u have a backup PM file of the phone,if u have then now write PM file and post logs here.
Old 07-18-2012, 08:25   #3 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Erase the phone
Full flash it with the latest firmware related to its product code
write back the rpl
sx4 auth and suggested PM
alex
Old 07-18-2012, 14:33   #4 (permalink)
Member: 1542807
I don't have a full PM backup. Don't know if it be useful, but have full PMs from two another, fully working E52 phones.
Old 07-18-2012, 14:47   #5 (permalink)
Member: 1488173
Just Do what Mr. Moulnisky says, that is your solution.
Regards !!
Old 07-18-2012, 15:02   #6 (permalink)
Member: 1542807
Just have done full erase chip, but the phone is no longer detected via fbus.
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Erasing flash chip...
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x0FFFFFFF, ONENAND
Waiting 640s for erasure finish...
Erase taken 1.124s
Restarting MCU...
BB5 Full Erase Finished!
Analyze Security Error -> Phone not detected (FBUS)
Failed to read info -> Phone not detected
OK, it's detected via USB
Old 07-18-2012, 15:18   #7 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Erase taken 1.124s
Restarting MCU...
Obviously
When the mobile is fully erased can be seen only on the flashbus so you can see it doing "check flashing bus"
Full flash the mobile as indicated and afterward the mobile will get again the local mode
Alex
Old 07-18-2012, 16:55   #8 (permalink)
Member: 1542807
1. Fully erased (FBUS)
2. Fully flashed (USB), result: IMEI broken, Simlock test passed, security test passed
3. Wrote back RPL (FBUS), result: IMEI ok, Simlock test failed, security test failed
4. SX4 auth + write PM 1, 309, result: IMEI ok, simlock test failed, security test passed
As I said, I don't have full PM backup.
Power on the phone - white screen for 1 sec then power off.
Old 07-19-2012, 14:30   #9 (permalink)
Member: 1542807
I have done one more thing. Fully erased the phone again and fully flashed with Phoenix service software (dead phone usb/refubrish mode). After that the phone...boots up in normal mode!? Do you believe that? With no RPL, no PM? How come? Typed *#06# and it shows damaged IMEI (123456....). Then I wrote RPL and the phone is dead (IMEI ok, simlock failed). So then erased IMEI (NPC cert) and the phone is alive again (IMEI damaged, simlock ok). Can you explain that? What's going on with this phone?
Regards,
jatza
Old 07-19-2012, 20:52   #10 (permalink)
Member: 1542807
Founded solution!!!
Problem was with PM 120. Writed RPL to phone, readed PM 120 and edited with notepad. Sector 2 of PM 120 [120,2] should have 130 bytes, but has 134 bytes, so it was 4 bytes too long. Just deleted eight zeros from the end of the sector and wrote PM 120 back to phone and....voila . E52 is alive and fully working!!
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.04, (Jun 10 2012 18:37:57, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B000089B
HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27
Box is activated
Started box selftests procedure
USB Voltage 5,03v PASSED
MCU Voltage 3,28v PASSED
Core Voltage 1,79v PASSED
VBAT Voltage 1,35v PASSED
VBAT Voltage 4,93v PASSED
Box VPP disabled
VPP Voltage 0,02v PASSED
Internal Box VPP Enabled
VPP Voltage 5,01v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 99
Avaiable Physical Memory: 1.925GB
Avaiable Virtual Memory: 1.786GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
Phone is in Local Mode
Normal mode set
MCU Version V ICPR82_11w16.3.11
MCU Date 29-03-12
IMEI Spare 3A95230XXXXXXXXX
IMEI SV 33952307XXXXXXXXXX000000
PPM 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01u$Tkv0.a091Ą rm469_091.004_U006.000_prd
PSN MCI656271
Product Code 0591678
Module Code 0203994
Basic Product Code 0565921
LPSN 0
APE SW 091.004
APE Variant 091.004091.004.02.01091.004.C00.01
APE Test v0.a091
APE HW 256
APE ADSP 256
APE BT HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.
RETU 40
TAHVO 00
AHNE 11
HW 8000o256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01u$Tkv0.a091Ą rm469_091.004_U006.000_prd
PCI o256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01kv0.a091
UEM 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01kv0.a091
UPP 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01u$Tkv0.a091
DSP 11w52o256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01u$Tkv0.a091
LCD 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01kv0.a091Ą rm469_091.004_U006.000_prd
BT 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01u$Tkv0.a091Ą rm469_091.004_U006.000_prd
ADSP Sw 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01u$Tkv0.a091Ą rm469_091.004_U006.000_prd
ADSP DevID 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01kv0.a091
ADSP RevID 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01kv0.a091
AEM 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01u$Tkv0.a091
Flip MCUSW 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i091.004j(#091.004091.004.02.01091.004.C 00.01u$Tkv0.a091
Simlock Server SIMLOCK SERVER
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Auto Selecting Flash Files on User Request...
Product Code: 0591678
This is Valid BB5 Product
No variant found with given Product Code, selecting first one
MCU Date 29-03-12
Security block OK and saved to "RM-469_3593270XXXXXXXX_2012-07-19_214436.SecurityBlock.PM"
SIMLOCK SEFLTEST PASSED OK!
Checking SIMLOCK...
Analyze finished!
PS: Full PM backup is not needed.
Problem solved.
Best regards,
jatza
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.39227 seconds with 11 queries
