Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 07-31-2012, 21:20   #1 (permalink)
Member: 1542807
Nokia E52 - how to restore CMLA and ECC keys ?
Hello,
I have backed up RPL, full PM, then fully erased the phone. After writing RPL and PM back the CMLA and ECC keys are missing.
Before log:
Reading Security Block...
Security block OK and saved to "RM-469_353785043597722_2012-07-31_211707.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
SIMLOCK SEFLTEST PASSED OK!
Step 2 : Testing SECURITY
SECURITY SEFLTEST PASSED OK!
Step 3 : Analyzing Security Block
"16A00102948C0344DED57800484D946C5704D32F.B000089B " Exists, That is good...
Checking SUPERDONGLE...
SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
Checking SIMLOCK...
Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Checking MCU&DSP TIMESTAMPS...
MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
Checking CMLA KEYS...
CMLA KEYS FOUND AND CHECKSUM OK! PASSED!
Checking ECC KEYS...
ECC KEYS FOUND AND CHECKSUM OK! PASSED!
Checking DIV KEYS...
DIV KEYS FOUND AND CHECKSUM OK! PASSED!
Analyze finished!
RPL write + SX4 auth log:
Skipping RPL decryption...
Erasing Security...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104
CMT_EM_ASIC_ID: 00001040
CMT_EM_ASIC_ID: 00001030
CMT_PUBLIC_ID: 16A00102948C0344DED57800484D946C5704D32F
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695
CMT_SECURE_ROM_CRC: 37BE26FA
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020004000000031, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 85F252E351E225CAFC4DFBC8041EABD2823E3500
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
CMT NPC Erased
Restarting MCU...
Parsing decrypted RPL...
Processing FBUS Part...
Writing Product Code...
Writing PSN...
Writing HWID...
Writing Simlock...
Handling as SL3 Simlock Data
Handling as SIMLOCK1 Format
31_011939.SecurityBlock.PM"
15 Digits NCK Found
Simlock ACCEPTED OK !
Writing Superdongle key...
Superdongle Key ACCEPTED OK !
Writing CMLA key...
CMLA Key ACCEPTED OK !
Writing WMDRM PD Data...
WMDRM PD Data ACCEPTED OK !
Processing FLASHBUS Part...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE Subsystem Not Found
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Write RPL Finished!
SX4 Authorization / SD Repair Procedure Started....
Failed to obtain Phone Unique Data, Will use Server and Original Card
MCU Version V ICPR82_11w16.3
MCU Date 19-05-11
Product RM-469 (Nokia E52)
Manufacturer (c) Nokia
IMEI 353785043597722
Mastercode 674137450
SX4 Status: Not authorized (74)
Started mutual authenthication with card...
Cyclone Server (2.0.0.44), Cyclone Box Team 2008-2012 - Ready.
Receiving Phone Seed 1...
Phone Seed 1 Received
Sending calculated Data 1, and expecting Seed 2...
Calculated Data 1 accepted, Phone Seed 2 Received
Sending calculated Data 2
Calculated Data 2 sent, Checking Authorization Status again
Authorization successfully finished!
Looking for Virgin PM In Database...
Found, writing...
[1,0] Written, Length: 114 bytes, Status: OK
[1,2] Written, Length: 10 bytes, Status: OK
[1,4] Written, Length: 110 bytes, Status: OK
[1,6] Written, Length: 10 bytes, Status: OK
[1,7] Written, Length: 214 bytes, Status: OK
[1,8] Written, Length: 110 bytes, Status: OK
[1,13] Written, Length: 10 bytes, Status: OK
[1,16] Written, Length: 208 bytes, Status: OK
[1,18] Written, Length: 208 bytes, Status: OK
[1,20] Written, Length: 208 bytes, Status: OK
[1,22] Written, Length: 16 bytes, Status: OK
[1,23] Written, Length: 4 bytes, Status: OK
[1,24] Written, Length: 84 bytes, Status: OK
[1,26] Written, Length: 110 bytes, Status: OK
[1,28] Written, Length: 10 bytes, Status: OK
[1,29] Written, Length: 10 bytes, Status: OK
[1,31] Written, Length: 208 bytes, Status: OK
[1,33] Written, Length: 36 bytes, Status: OK
[1,34] Written, Length: 376 bytes, Status: OK
[1,35] Written, Length: 16 bytes, Status: OK
[1,39] Written, Length: 36 bytes, Status: OK
[1,40] Written, Length: 16 bytes, Status: OK
[1,41] Written, Length: 182 bytes, Status: OK
[1,42] Written, Length: 4 bytes, Status: OK
[1,43] Written, Length: 36 bytes, Status: OK
[1,44] Written, Length: 182 bytes, Status: OK
[1,45] Written, Length: 182 bytes, Status: OK
[309,0] Written, Length: 4 bytes, Status: OK
[309,1] Written, Length: 2 bytes, Status: OK
[309,2] Written, Length: 12 bytes, Status: OK
[309,3] Written, Length: 36 bytes, Status: OK
[309,4] Written, Length: 12 bytes, Status: OK
[309,7] Written, Length: 12 bytes, Status: OK
[309,17] Written, Length: 12 bytes, Status: OK
Write PM Finished, Record written OK: 34, Record written NOT OK: 0
Disconnected from Cyclone Server
After log:
31_012312.SecurityBlock.PM"
Checking SIMLOCK...
Analyze finished!
As you can see, these keys are accepted, but not found in security section. How to restore it?
Regards,
Jatza
Old 08-01-2012, 18:47   #2 (permalink)
Member: 1542807
Is there no solution for this?
Old 08-11-2012, 21:52   #3 (permalink)
Member: 1542807
C'mon cyclonebox supporters, plz help to solve my prob.
Old 08-11-2012, 21:54   #4 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
What's your phone condition now?
Old 08-11-2012, 22:01   #5 (permalink)
Member: 1542807
It seems to be working ok so far. Are this keys important?
Old 08-12-2012, 05:35   #6 (permalink)
Mr.3.'s Avatar
Member: 962029
No.. Just ignore those errors.....
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
DES key Driver black Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-19-2012 05:32
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
Page generated in 0.31780 seconds with 11 queries
