Nokia E65 not unlocked!! i just tried to unlock a Nokia e65 but gives an error i post the log log: MCU Version V 2.0615.30 MCU Date 13-09-07 Product RM-208 Manufacturer (c) Nokia. IMEI 356961016443270 Mastercode 4774241414 IMEI Spare 3A65690161442307 IMEI SV 3365690161442327F5000000 PSN SIJ365629 Product Code 0552463 Basic Product Code 0536849 PSD 0000000000000000 WLAN MAC 001EA4A8AE46 RETU 15 TAHVO 22 AHNE 30 HW 0801 RFIC 17141715 DSP A06w14PB_07w32 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2140100000000000 Simlock Profile 0100000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F BB5 Unlock Started... MCU Version V 2.0615.30 MCU Date 13-09-07 Product RM-208 Manufacturer (c) Nokia. IMEI 356961016443270 Mastercode 4774241414 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2140100000000000 Simlock Profile 0100000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F Reading Security Block... Security block OK and saved to "RM-208_356961016443270_29032010_181438.SecurityBlock. PM" WARNING: "1360021221654E503E19F87CB7EE0E2932E816A0.C0002664 " Not Exists, Will read it... Reading CYC file from phone... Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9FD34A257F145690D54FB1351EB719D27079C759 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1360021221654E503E19F87CB7EE0E2932E816A0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "1360021221654E503E19F87CB7EE0E2932E816A0.C0002664 " Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... BB5 Unlock Failed -> Simlock NOT ACCEPTED ! Maybe is SL3 phone? what i did wrong? Br. |
Do the unlock via nck calculation new method. BR Alex |
here LOG: BB5 Unlock Started... MCU Version V 2.0615.30 MCU Date 13-09-07 Product RM-208 Manufacturer (c) Nokia. IMEI 356961016443270 Mastercode 4774241414 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2140100000000000 Simlock Profile 0100000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F Reading Security Block... Security block OK and saved to "RM-208_356961016443270_29032010_212331.SecurityBlock. PM" "1360021221654E503E19F87CB7EE0E2932E816A0.C0002664 " Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) BB5 Unlock Failed -> Failed to read NCK Codes, Box Reported: Security Section Checksum Error (decryption fails?) BR. |
it's SL1 select 1st option "308 calculation' |
here the log: BB5 Unlock Started... MCU Version V 2.0615.30 MCU Date 13-09-07 Product RM-208 Manufacturer (c) Nokia. IMEI 356961016443270 Mastercode 4774241414 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2140100000000000 Simlock Profile 0100000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F Reading Security Block... Security block OK and saved to "RM-208_356961016443270_29032010_230542.SecurityBlock. PM" Determining PA Simlock... Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9FD34A257F145690D54FB1351EB719D27079C759 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1360021221654E503E19F87CB7EE0E2932E816A0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0266638E9C2164FC6B5194ED596A6A251C699896 Testing TX2 Line... Prepare phone failed with message -> TX2 Test Failed! Check cable or yellow TX2 Adapter! BB5 Unlock Failed -> Failed to Boot / Prepare Phone BR. |
Are you using the TX2 adapter ? Check your cable / TX2 adapter, clean phone contacts..... Quote:
BR |
with me happens the same.. It was the second without the tx2 adapter and works ok and unlock, with the tx2 cable I canīt do nothing. I already buy the TMA (Evolution) to see if with this works fine or only with the cable directly like the others... rgs devil24 |
Fbus Cable problem Using Fbus jaf E65+TX2 adapter V2 (or TMA) --> connect problem = 0.00 BR, |
