Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member ![]() Join Date: May 2011
Member: 1581077 Status: Offline Thanks: 0
| Nokia x2-00 rm-618 restaring [SOLVED-Thanks Karwos] i have a one piece nokia x2-00 rm-618 whitout sim work fine.....hit sim restaring only and off....i procedure to flash and it result is bad,in contact service...i writhe the rpl backup but the result is in security test failed i repair with sx4 and no working i need help realy |
| | #3 (permalink) |
| SX4 Authorization / SD Repair Procedure Started.... [Nokia X2-00 USB Phonet]: Port opened OK! Failed to obtain Phone Unique Data, Will use Server and Original Card [Nokia X2-00 USB Phonet]: Port opened OK! MCU Version V 08.25 MCU Date 19-05-11 Product RM-618 (Nokia X2-00) Manufacturer (c) Nokia IMEI 355937045730847 Mastercode 3642552325 SX4 Status: Not authorized (74) Started mutual authenthication with card... Cyclone Server (2.0.0.42), Cyclone Box Team 2008-2012 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [Nokia X2-00 USB Phonet]: Port opened OK! [4,1] Written, Length: 48 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,6] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,18] Written, Length: 80 bytes, Status: OK [4,19] Written, Length: 4 bytes, Status: OK [4,28] Written, Length: 2 bytes, Status: OK [8,0] Written, Length: 2 bytes, Status: OK [8,1] Written, Length: 16 bytes, Status: OK [8,2] Written, Length: 16 bytes, Status: OK [8,3] Written, Length: 128 bytes, Status: OK [8,4] Written, Length: 128 bytes, Status: OK [8,7] Written, Length: 4 bytes, Status: OK [8,8] Written, Length: 8 bytes, Status: OK [8,9] Written, Length: 8 bytes, Status: OK [8,10] Written, Length: 32 bytes, Status: OK [8,11] Written, Length: 4 bytes, Status: OK [8,12] Written, Length: 4 bytes, Status: OK [96,0] Written, Length: 2 bytes, Status: OK [96,1] Written, Length: 20 bytes, Status: OK [107,0] Written, Length: 21 bytes, Status: OK [107,1] Written, Length: 89 bytes, Status: OK [107,2] Written, Length: 69 bytes, Status: OK [107,3] Written, Length: 70 bytes, Status: OK [107,25] Written, Length: 136 bytes, Status: OK [107,26] Written, Length: 12 bytes, Status: OK [362,0] Written, Length: 1 bytes, Status: OK [362,1] Written, Length: 120 bytes, Status: OK [373,0] Written, Length: 44 bytes, Status: OK [374,0] Written, Length: 4 bytes, Status: OK [375,0] Written, Length: 400 bytes, Status: OK [375,1] Written, Length: 20 bytes, Status: OK [391,0] Written, Length: 9130 bytes, Status: OK [391,1] Written, Length: 432 bytes, Status: OK Write PM Finished, Record written OK: 36, Record written NOT OK: 0 Disconnected from Cyclone Server Started Phone Security Analysis... [Nokia X2-00 USB Phonet]: Port opened OK! MCU Version V 08.25 MCU Date 19-05-11 Product RM-618 (Nokia X2-00) Manufacturer (c) Nokia IMEI 355937045730847 Mastercode 3642552325 Reading Security Block... Security block OK and saved to "RM-618_355937045730847_17052012_014702 p.m..SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) Additionaly, Checking HWC/CCC Certs... Booting CMT... [Nokia X2-00 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT Analyze Security Error -> Failed to Boot / Prepare Phone is the log |
| | #5 (permalink) |
| log writhe rpl,sx4 and security test Processing FBUS Part... [Nokia X2-00 USB Phonet]: Port opened OK! Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Handling as SL3 Simlock Data Handling as SIMLOCK1 Format Reading Security Block... Security block OK and saved to "RM-618_355937045730847_17052012_030122 p.m..SecurityBlock.PM" 15 Digits NCK Found Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing WMDRM PD Data... WMDRM PD Data ACCEPTED OK ! Processing FLASHBUS Part... Booting CMT... [Nokia X2-00 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005361 CMT_PUBLIC_ID: 0000000000B8F02A87A05579751DB872D9F43E91 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! Searching for BootCode: DualLine 32Bit BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020003000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020003000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E9700989029D9E899915F781B1582048E042A738 APE Subsystem Not Found CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Write RPL Finished! SX4 Authorization / SD Repair Procedure Started.... [Nokia X2-00 USB Phonet]: Port opened OK! "0000000000B8F02A87A05579751DB872D9F43E91.C0004628 " Exists, That is good... [Nokia X2-00 USB Phonet]: Port opened OK! MCU Version V 08.25 MCU Date 19-05-11 Product RM-618 (Nokia X2-00) Manufacturer (c) Nokia IMEI 355937045730847 Mastercode 3642552325 Reading Security Block... Security block OK and saved to "RM-618_355937045730847_17052012_030159 p.m..SecurityBlock.PM" SX4 Status: Not authorized (74) Started mutual authenthication with card... Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [Nokia X2-00 USB Phonet]: Port opened OK! [4,1] Written, Length: 48 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,6] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,18] Written, Length: 80 bytes, Status: OK [4,19] Written, Length: 4 bytes, Status: OK [4,28] Written, Length: 2 bytes, Status: OK [8,0] Written, Length: 2 bytes, Status: OK [8,1] Written, Length: 16 bytes, Status: OK [8,2] Written, Length: 16 bytes, Status: OK [8,3] Written, Length: 128 bytes, Status: OK [8,4] Written, Length: 128 bytes, Status: OK [8,7] Written, Length: 4 bytes, Status: OK [8,8] Written, Length: 8 bytes, Status: OK [8,9] Written, Length: 8 bytes, Status: OK [8,10] Written, Length: 32 bytes, Status: OK [8,11] Written, Length: 4 bytes, Status: OK [8,12] Written, Length: 4 bytes, Status: OK [96,0] Written, Length: 2 bytes, Status: OK [96,1] Written, Length: 20 bytes, Status: OK [107,0] Written, Length: 21 bytes, Status: OK [107,1] Written, Length: 89 bytes, Status: OK [107,2] Written, Length: 69 bytes, Status: OK [107,3] Written, Length: 70 bytes, Status: OK [107,25] Written, Length: 136 bytes, Status: OK [107,26] Written, Length: 12 bytes, Status: OK [362,0] Written, Length: 1 bytes, Status: OK [362,1] Written, Length: 120 bytes, Status: OK [373,0] Written, Length: 44 bytes, Status: OK [374,0] Written, Length: 4 bytes, Status: OK [375,0] Written, Length: 400 bytes, Status: OK [375,1] Written, Length: 20 bytes, Status: OK [391,0] Written, Length: 9130 bytes, Status: OK [391,1] Written, Length: 432 bytes, Status: OK Write PM Finished, Record written OK: 36, Record written NOT OK: 0 Started Phone Security Analysis... [Nokia X2-00 USB Phonet]: Port opened OK! MCU Version V 08.25 MCU Date 19-05-11 Product RM-618 (Nokia X2-00) Manufacturer (c) Nokia IMEI 355937045730847 Mastercode 3642552325 Reading Security Block... Security block OK and saved to "RM-618_355937045730847_17052012_030209 p.m..SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) Additionaly, Checking HWC/CCC Certs... Booting CMT... [Nokia X2-00 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005361 CMT_PUBLIC_ID: 0000000000B8F02A87A05579751DB872D9F43E91 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! Searching for BootCode: DualLine 32Bit BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020003000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020003000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E9700989029D9E899915F781B1582048E042A738 APE Subsystem Not Found HWC Looks OK! CCC Looks OK! Restarting MCU... -- SECURITY PROBLEM -- [Nokia X2-00 USB Phonet]: Port opened OK! Step 3 : Analyzing Security Block "0000000000B8F02A87A05579751DB872D9F43E91.C0004628 " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Analyze finished! |
| | #7 (permalink) |
| [Nokia X2-00 USB Phonet]: Port opened OK! MCU Version V 08.25 MCU Date 19-05-11 Product RM-618 (Nokia X2-00) Manufacturer (c) Nokia IMEI 355937045730847 Mastercode 3642552325 IMEI Spare 3A55390754378004 IMEI SV 3355390754378034F9000000 PPM V 08.25, 19-05-11, RM-618, (c) Nokia , L CNT Content: l_0595268, V 08.25, 19-05-11, RM-618, (c) Nokia PSN DNP965179 Product Code 059C1H1 Module Code 0204491 Basic Product Code 0591973 PSD 0000000000000000 LPSN 0 HW 1000 RFIC 9 LCD SEIKO BT 2.31-SP2.31 Simlock Server SIMLOCK SERVER Simlock Key 3340201549764300 Simlock Profile B000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 334020 |
| | #8 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: Poland Age: 23
Member: 117496 Status: Offline Sonork: 100.83919 Thanks: 84
| You need write "magic" PM after SD auth ![]() I don't have it now but I AM sure when you use search button you will find it. |
| | #9 (permalink) |
| Use this file... do SD auth, then write, then post results. |
| The Following User Says Thank You to karwos For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Nokia Software!!!!!!! | Jefferson | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 73 | 05-15-2013 13:07 |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
