Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-23-2012, 17:57   #31 (permalink)
Crazy Poster
Member: 146766
Thanks Meter: 7
Originally Posted by CTPACT View Post
is it possible to combine 5 series or 6 series with this 7xxx cards? thanks!
Nope!
5 with 7 i have seen it work, but 6 with 7 i have not... so you decide
Old 04-26-2012, 02:04   #32 (permalink)
Crazy Poster
Member: 146766
Thanks Meter: 7
any better performance with the new 12.4 drivers amd released ?
Old 06-15-2012, 11:34   #33 (permalink)
spider-man's Avatar
Member: 135039
Thanks Meter: 1,486
withe 2 card HD 7970 Lightning clocked at 1150mhz its very good machine
psu cooler master 850w and a good system fan or water cooling .
i get 7400 h per seconde .
The Following User Says Thank You to spider-man For This Useful Post:
Old 06-19-2012, 20:21   #34 (permalink)
Member: 8843
Thanks Meter: 117
@ spider
whats yo machine specs?
Old 06-22-2012, 14:34   #35 (permalink)
rico1's Avatar
Member: 5397
Thanks Meter: 38
How settings turn up?
HD5970 +HD7970?
Old 07-27-2012, 22:52   #36 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
Check this and give me know if it works. I'm unable to check it fast.
Old 07-27-2012, 23:12   #37 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
@SPIDER-MAN
Let us know what did you installed?
1 System - which
2 Drivers - which
3 Additional programs - which
4 Additional settings, changes in registry
Any other operations?
Crossfire bridge?
Old 10-10-2012, 07:17   #38 (permalink)
Member: 679135
Sonork: 100.1606448
Thanks Meter: 436
Originally Posted by Chevka View Post
Here is some Speed Review comparing HD5870 and HD7970.
since this 2 Cards is use single core GPU, not like 6970 or 6990.
I test use the same system (same komputer) Win75 64Bit with oclHascat-0.09 and Catalyst 12-1
HD 5870 in Stock Clock 850Mhz reach about 20xx Mhz/s
HD 7970 in Core Clock 850Mhz reach about 25xx Mhz/s
HD 7970 in Stock Clock 925Mhz reach about 28xx Mhz/s
HD 7970 in Core Clock 1000Mhz reach about 30xx Mhz/s
Now you all do the conclusion
according to the power, absoloutely buy 7970 is worthed for Bruteforce.
but considering the price for now, you all do the math according the price in your place.
Best Regards,
Cool!
As you optenido these results with the 7970. I took almost 24 hours and have not had any positive result.
I tested with version 12-1_xp32_dd_ccc AMD driver and the graphics card is not detected. Otherwise the 12-8_xp32_dd_ccc version is seen perfectly.
However, when trying to use the 0.10 version shows me [1] identified message me with the courage to try version 0.9
[1]
F: \ application \ brute force \ oclHashcat-lite-0.10> oclHashcat-lite32.exe 9b957cc6ab
97cbf88c4f6f0f146adafe
oclHashcat-lite v0.9 by atom starting ...
GPU-Loops: 256
GPU-Accel: 160
Password lengths range: 1-55
ERROR: clGetPlatformIDs () -1001
F: \ application \ brute force \ oclHashcat-lite-0.10> pause
Press any key to continue. . .
Any idea about it, please. Thank you in advance.
Old 10-10-2012, 09:55   #39 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Originally Posted by hvalero2001 View Post
Cool!
[1]
GPU-Loops: 256
GPU-Accel: 160
you need windows 7 for this software.. xp won't work
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 10-10-2012, 10:00   #40 (permalink)
Member: 8843
Thanks Meter: 117
@ hvale
what exactly do u want to be helped with?
The Following User Says Thank You to datalife2000 For This Useful Post:
Old 10-10-2012, 10:08   #41 (permalink)
Member: 515559
Sonork: no
Thanks Meter: 121
what about xfx 7870 card ??
Old 10-10-2012, 11:58   #42 (permalink)
Member: 679135
Sonork: 100.1606448
Thanks Meter: 436
Thanks to those who cared for my problematic. Toto was solved. Apparently the version "12.8" for WindowsXP brings no OpenCL. As they assemble windows7 tube, as recommended by the friend @moulnisky
In windows7 with version "12.8" driver works wonders.
The Following User Says Thank You to hvalero2001 For This Useful Post:
Old 10-10-2012, 13:55   #43 (permalink)
Member: 1625969
Thanks Meter: 28
Device #1: Cypress, 1024MB, 0Mhz, 20MCU
Device #2: Cypress, 1024MB, 0Mhz, 20MCU
Device #3: Cypress, 1024MB, 0Mhz, 20MCU
Device #4: Cypress, 1024MB, 0Mhz, 20MCU
Device #5: Cypress, 1024MB, 0Mhz, 20MCU
Device #6: Cypress, 1024MB, 0Mhz, 20MCU
[s]tatus [p]ause [r]esume [q]uit => s
Status.......: Running
Hash.Target..: d3675eccaf16a7f7438a258c
Hash.Type....: SL3
Speed.GPU.#1.: 2187.0M/s
Speed.GPU.#2.: 2185.7M/s
Speed.GPU.#3.: 2187.3M/s
Speed.GPU.#4.: 2189.3M/s
Speed.GPU.#5.: 2187.3M/s
Speed.GPU.#6.: 2187.4M/s
Speed.GPU.#*.: 13123.9M/s
U may be wrong
6 GPU ? Linux or windows 7 64bit ?
Old 10-10-2012, 13:55   #44 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
So to use 12.8 need to install OpenCL ?
Old 06-05-2017, 23:17   #45 (permalink)
Member: 1567028
Thanks Meter: 5
Hi guys I know this is old Topic, but I am quite new to nokia sl3 brute force, I would like to try it myself rather than buying codes every time, I dont need code to be done in 10 minutes, but aprox 12 hours a code would be ok
BUT I am not sure if a pc that I am looking at is ok to do that!
It is design to be a gaming PC, here are the details:
Amd Athlon X4 3.7ghz 8gb Ram Nvidia 960gtx 4 Gb
Please respond who knows if it will be good to me or is not worth doing at all?
Thanks a lot for your attention!
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
winlock 1.0 Aldrin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 01-25-2000 04:49
download Datasuite 3.0 zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 10-31-1999 01:35
2 FREE NOKIA SP SIM CARDS TO RELEASE FOR INFORMATION WE NEED SP UNLOCKER 2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 09-25-1999 03:34
Page generated in 0.26691 seconds with 10 queries
