01-07-2010, 15:57 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: ๑۩۞۩&&
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | .:: Please Any Solution for this 6120 ::. Only Show Nokia Logo and POwer Off ! look READ INFO. Self Test. Selftests to proceed: 20 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Failed to make Selftests -> Phone is not responding for Selftest Request Any Solution ¿ |
01-07-2010, 16:05 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Read the full back-up, make rpl from phone and read all certs. afterward full flash it again with the version V5.11 same product code. afterward read again info and selftest and post again logs here plus the file of full PM BR Alex |
01-07-2010, 16:35 | #3 (permalink) |
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | without Yellow cable Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm243_05.11_prd_core.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 18900015B9700058097CB373A9BF8E634E6DB3E9 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 rm243_05.11_prd_core.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5 Processing Flash Image Failed -> Not found required Secondary Loader Failed to Process all Image files -> Failed to process rm243_05.11_prd_core.fpsx Allway fail.. withYellow Cable Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm243_05.11_prd_core.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 18900015B9700058097CB373A9BF8E634E6DB3E9 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 rm243_05.11_prd_core.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000400121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x0087FFFF, ONENAND EraseArea[0,CMT]: 0x00B80000-0x04DFFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.141s Writing all blocks... Writing CMT ADA Certificate... CBUS Request Error -> CBUS Response wrong header Block Write Failed -> Failed to write data data (1) Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm243_05.11_prd_core.fpsx |
01-07-2010, 20:52 | #5 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | error 1 is a flash memory error. Could be a cable problem (So, if you can, check with another cable) If still problem check the hardware.. BR Alex |
any solution for this please | steve352 | Smart-Clip | 8 | 02-05-2007 14:56 |
is any solution for this | ahmed elshaer | Infineon C16X M51 & ARM7 M52 BASED | 2 | 10-19-2005 22:01 |
any solution for this old nec | MTi-GsM | NEC | 1 | 10-01-2005 10:30 |
any solution for this c100 | GSM_MARSHALS | Trident/AGERE Platform | 6 | 03-17-2005 13:46 |
p code--- any solution for this pblm | shyjuapex | x1x to x45/x50 | 3 | 11-19-2004 14:39 |
