Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 11-13-2009, 05:41   #1 (permalink)
Member: 771272
Thanks Meter: 8
Please help me Flash Nokia E63 - rm 437
Hi! Please help me! I downloade Flash file for Nokia e63- rm437 .
However, when i try to flash, i did not know which file i need to select. it does not have file as .MCUsw, image or ppm file.....
It only have .pcx or .prd file or something like that.
Please explian me how to flash nokia e63 which flash file should i need to choose.....?
If can, please post me 3 correct flask file to flash nokia E63 - rm 437.
thank you
Tommy
The Following 2 Users Say Thank You to tommyvo For This Useful Post:
Old 11-13-2009, 10:08   #2 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Donwload all the files related to the product code you need using navfirm.
Once you did you will be able to use the auto selection with the VPL vfiles.. easier.
Anyway here a sample : MCU = prd.C00 , PMT = prd.V277_20 , CNT = _20.277U
Alex
The Following 3 Users Say Thank You to moulnisky For This Useful Post:
Old 11-14-2009, 02:00   #3 (permalink)
Member: 771272
Thanks Meter: 8
Thank you!
I did flash succesfully. however after flash, I try to unlock, it come with error when read Info and unlock:
110.21.006110.21.006_v29kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia ,
ADSP DevID 110.21.006j 110.21.006110.21.006_v29kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia ,
ADSP RevID 110.21.006j 110.21.006110.21.006_v29kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia ,
AEM 110.21.006j 110.21.006110.21.006_v29kRM437ENO874571920.a01n256 o256
Flip MCUSW 110.21.006j 110.21.006110.21.006_v29kRM437ENO874571920.a01n256 o256
Failed to read info -> Failed to read SP info
BB5 Unlock Started...
MCU Version V ICPR71_09w04.2
MCU Date 19-02-09
Product RM-437
Manufacturer (c) Nokia
IMEI 356939031667867
Mastercode 4323355222
Warning: Failed to read SP Info, Assuming defaults
Simlock Server SIMLOCK SERVER
Simlock Key 5050300014981890
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 1230011091A88B525E69AEB387DA9B0603CA9D38
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C
CMT_ROM_ID: 4B9B75103E691FF8
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: D9C25399C696B8549EDCDB1497A950B3A20DDFB6
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support...
Booting RAP...
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Received Security Block OK !
BB5 Unlock Failed -> Simlock Array not found in PM 308, this is critical
And this is selftest:
Selftests to proceed: 33
Passed ST_TAHVOINT_TEST
Passed ST_UEM_CBUS_IF_TEST
Passed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Passed ST_SIM_IO_CTRL_LOOP_TEST
Failed ST_SIM_LOCK_TEST
Passed ST_SECURITY_TEST
Passed ST_PWR_KEY_TEST
Passed ST_CURRENT_CONS_TEST
Passed ST_BACKUP_BATT_TEST
Passed ST_SLEEPCLK_FREQ_TEST
Passed ST_HOOKINT_TEST
Passed ST_BTEMP_TEST
Passed ST_EXT_DEVICE_TEST
Passed ST_CDSP_RF_BB_IF_TEST
Passed ST_CDSP_RF_SUPPLY_TEST
Passed ST_CDSP_TX_IQ_TEST
Passed ST_CDSP_TXC_DATA_TEST
Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST
Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Passed ST_CDSP_WCDMA_TX_POWER_TEST
Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST
Passed ST_CDSP_GSM_TX_POWER_TEST
Passed ST_KEYBOARD_STUCK_TEST
Passed ST_LPRF_IF_TEST
Passed ST_CAMERA_IF_TEST
Passed ST_LPRF_AUDIO_LINES_TEST
Passed ST_MAIN_LCD_IF_TEST
Passed ST_BT_WAKEUP_TEST
Passed ST_WLAN_TEST
Passed ST_BT_WLAN_COEXISTENCE_TEST
Passed ST_RADIO_TEST
Selftests done, Tests total: 33, Tests passed: 31, Tests not passed: 2
Please advice me, now phone Can turn on BUT IT ALSWAY SAY INVALID SIMCARD.
thank you
tommy
Old 11-14-2009, 04:13   #4 (permalink)
Member: 771272
Thanks Meter: 8
Hi!
I did try to write original RPL back, It is still same problem:
Working on PM...
Configuration Key - Found
SHA1-RSA - Found
SHA1-HMAC - Found
Signing Configuration Key...
Building RPL...
RM-437_356939031668717_14112009_121102 PM.SLBackup.RPL Saved OK!
Failed to Write RPL File -> RPL File invalid, not begins with `REBUILD DATA` Magic, Maybe it is PLAIN ONE ?
Skipping RPL decryption...
Parsing decrypted RPL...
Processing FBUS Part...
Writing Simlock...
Simlock NOT ACCEPTED !
Processing FLASHBUS Part...
Booting RAP...
CMT_PUBLIC_ID: 0970011091A88B52CF9FD35E58CD9E954B50539C
Box VPP disabled
APE Subsystem Not Found
Restarting MCU...
Writing Simlock...
Booting RAP...
Box VPP disabled
Restarting MCU...
Write RPL Finished!
then
MCU Date 19-02-09
Product RM-437
IMEI 356939031668717
Mastercode 3422351327
IMEI Spare 3A65390913667801
IMEI SV 3365390913667801F4000000
PPM 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256
PSN MWH181633
Product Code 0583813
Basic Product Code 0561985
PSD 0000000000000000
LPSN 0
WLAN MAC 1886AC2571A7
APE SW 110.21.006
APE Variant 110.21.006110.21.006_v27
APE Test RM437ENO874571920.a01
APE HW 256
APE ADSP 256
RETU 16
TAHVO 22
AHNE 11
HW 0802i110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256
PCI i110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256
UEM 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256
UPP 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256
RFIC 17141715
DSP Sofie_ICPR71_08w41i110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia ,
LCD 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia ,
BT 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia ,
ADSP Sw 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256
ADSP DevID 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256
ADSP RevID 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256
AEM 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256
Flip MCUSW 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia ,
Please help me, I got 2 nokia 363 like that
thank you
tommy
Old 11-14-2009, 05:48   #5 (permalink)
Member: 771272
Thanks Meter: 8
Hi!
Big problem for me now, After try one more flash for 2 Nokia e63. Phone Not turn on or go to local mode at all.
What should i do now, Phone is dead.
Thank you
tommy
Old 11-14-2009, 08:25   #6 (permalink)
moulnisky's Avatar
Member: 947561
Flash it with the ENO firmware for the E63 and flash it again with the firmware was in the mobile before it got dead.
About the simlock problems for sure the mobie has the PM120 field 0 changed by unlock so you should rebuild the PM 120/0 as original to have a RPL from PM working.
Alex
Old 11-16-2009, 06:03   #7 (permalink)
Member: 771272
Thanks Meter: 8
Hi!
I forgot to Read all certificate, I only do Create RPL and back up Pm. Now phone got imei: 12345........
And i do not have certificate to write it back.
Please let me know is there anyway to rebuild imei to original?
Thank you
Tommy
Old 11-17-2009, 01:26   #8 (permalink)
Member: 771272
Thanks Meter: 8
I got 2 Nokia e63 dead after download from USA server and flash them. IT NOT really good.
Phone woking before and now dead after flash, I do not how to fix them. Phone can not read info and go to test mode.
Tommy
Old 11-17-2009, 01:41   #9 (permalink)
rajufzr's Avatar
Member: 116314
Thanks Meter: 147
if rpl and pm was read as full area of both then u can restore rpl and pm to revive the set after flashing with eno software. if again simlock not read then make rpl from ur fully read pm and write to fone as plain rpl and post result
The Following User Says Thank You to rajufzr For This Useful Post:
Old 11-17-2009, 01:58   #10 (permalink)
Member: 771272
Thanks Meter: 8
Thank brother...
What is ENO sofware meant?
thnk you
Old 11-21-2009, 17:26   #11 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
Untick Erase Security and write RPL file again.
The Following User Says Thank You to karwos For This Useful Post:
help need full pm e63 rm-437. (answered) G_TRON84 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 10-30-2010 04:19
Nokia E63 RM-437 Baltic product code??? mobile-phone-service Nokia Base Band 5 ( BB-5 ) 2 10-23-2010 06:52
Yes not supported Nokia E63 RM-437 Ver:-200.21.012 msantar MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 11-27-2009 15:48
Please help me flash my Nokia 3250 enzobaby Nokia Base Band 5 ( BB-5 ) 5 09-12-2008 18:39
Please Help Me Flash My Nokia 3250 enzobaby Nokia Base Band 5 ( BB-5 ) 0 09-12-2008 14:04
Page generated in 0.27671 seconds with 10 queries
