Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 06-17-2009, 02:56   #1 (permalink)
Member: 771272
Please help me for nokia n95 unlocking!!!!
HI!
Today I try to unlock Nokia n95, I used TX2 adaptor + TMA adaptor and 7 pin cable.However Test mode NEVER come up.
I have to click on " CHECK FLASHING BUS" TO FORCE PHONE TO LOCAL MODE. AFTER THAT I CAN READ PHONE INFO.
AFTER THAT, I CLICK ON UNLOCK AND PHONE PROCESSING TO UNLOCK. HOWEVER
imlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 50506F
Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 50599F
Simlock[3,1] State: CLOSED Type: MCC-MNC Data: 50506F
Simlock[4,1] State: CLOSED Type: MCC-MNC Data: 50599F
Simlock[5,1] State: CLOSED Type: MCC-MNC Data: 00101F
Simlock[6,1] State: CLOSED Type: MCC-MNC Data: 00101F
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
APE_SYSTEM_ASIC_ID: 24200705
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: 154989EEF77CF48E1CA6491DF3C4FA53E911CB71
APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 22400105DC740058DC6AC86A28A8C1C8E202A9D5
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_ROM_ID: A8C1D6713E691FF8
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5
Flashbus Write baud set to 4.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
APE Boot skipped on user request
Restarting MCU...
Determined PA Simlock: PA_SL
Checking for Rootkey Hash support...
Restarting MCU...
Booting RAP...
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Received Security Block OK !
Writing Security Block...
BB5 Unlock Failed -> Phone not detected (FBUS)
THE REASON IS PHONE IS NOT STABLE ON LOCAL MODE SO IT CAN NOT UNLOCK ANYMORE.
PLEASE HELP ME ANY IDEA
THANKS
TOMMY
Old 06-17-2009, 03:56   #2 (permalink)
yentrang120705's Avatar
Member: 330960
[QUOTE=tommyvo;4569907]HI!
imlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK!
Booting RAP...
Box VPP disabled
Restarting MCU...
Restarting MCU...
Booting RAP...
THANKS
TOMMY[/QUOT
Bro,Try to change the value of BSI on TMA adaptor.If the phone can not go into local mode,you can't unlock it.[ or remove camera and try again]
Old 06-17-2009, 05:11   #3 (permalink)
Member: 771272
thank you!
I did change TMA adaptor, however local mode is still not come up.
WHY IT SO HARD TO GET LOCAL MODE FOR NOKIA N95 AND Nokia N95 8GB?
I GOT ANYTHING ( TX2 ADAPTOR + TMA ADAPTOR+ GOOD 7 PIN CABLE), HOWEVER I CAN NOT UNLOCK THESE PHONE WITH CYCLONE .
ANY IDEA OR ANY SOLUTION TO GET LOCAL EASIER.
THANK YOU
Old 06-17-2009, 06:13   #4 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Is the version of the TMA adapter with the USB cable? is this cable connected to a free usb port of your computer or to a good powered hub or t a good USB charger? Are you kepint the dummy battery and the mobile well fit each other using an elastic band or some other system?.
Alex
Old 06-17-2009, 06:45   #5 (permalink)
Member: 771272
yes, TMA adaptor come with USB. do I need connect this usb to computer?
What you meant: " Are you kepint the dummy battery and the mobile well fit each other using an elastic band or some other system?." ----> I really not understand these. Please expalain for me.
thank you
Tommy
Old 06-17-2009, 06:46   #6 (permalink)
marekom's Avatar
Member: 196497
Wait for update cyclone box
Old 06-17-2009, 06:59   #7 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
thank you
Tommy
OF course you need! that usb cable added is to Give more power to the mobiles like the N95 one :-)
If you connect it to the computer you will see immediately the difference..
about keep the dummy battery and mobile weel fit each other is to prevent the fbus moving and giving you a bad contact.
retry please and post results.
Alex
Old 06-17-2009, 07:03   #8 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Nothing to do with the update.. Sometime, without a solution for the power and/or bsi problem, is hard to unlock a 6500S too...
I always use my homemade TMA adaptor and never failed an unlock or flash..
Thread : Local mode final solution for BB5 cables
Alex
Old 06-17-2009, 08:56   #9 (permalink)
UnlockingPoint's Avatar
Member: 1033807
thats very simple its really common problem
ure cable is not ok
it identifies ok but cannot unlock or flash the phone
change ure cable problem will b solved insh*****
Old 06-17-2009, 09:16   #10 (permalink)
Avantha's Avatar
Member: 239451
Connect the TMA USB cable to computer and change the dip switch to 5.1k,then it will go to local mode.
Old 06-17-2009, 10:08   #11 (permalink)
Member: 815805
test whith power the box or the phone y have same problem whit mt-box.....
Old 06-17-2009, 10:52   #12 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
for newer Rapido i recommend...with TMA external Power or Modification Inside for usb power
mxkey plz help me for nokia N95-8G boussoula MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 03-19-2010 02:52
please help me for nokia 6131 dreameye Nokia Base Band 5 ( BB-5 ) 0 07-13-2009 11:43
Please help me For nokia n90 not charging Alfa_Team Nokia Hardware & Hardware-Repair Area 1 09-04-2008 01:58
plz help me for nokia chiana n95 pin 6 remouve espoir1283 Chinese Cocktail 1 11-15-2007 08:57
please help me for my nokia 6061 satmaxo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-26-2006 12:11
Page generated in 0.50742 seconds with 11 queries
