Please help with unlocking 1208b RH-106 Can someone please confirm if this is even unlockable? After I clicked on "Read Info" (by using Easy Cable) it shows the phone has MCU V5.23 RH-106 (which I also found "RH-106_V 5.23.unlock_img" in UnlockData) so I'd hope by "initialize" Simlocks should do the job? But for some reason it keeps getting stock at "Booting UPP" then the "Failed to Unlock DCT4 -> Failed to write patch file" will come after that. Please tell me what am I doing wrong?!! Or I must reflash the phone to the "Same Version" before I can unlock it? But what exactly does it mean the "Same Version"? |
Hi, did you try press power switch when "Booting UPP" msg apears ? BR |
Try with FBus cable (1100 cable).... BR |
Thanks again for the reply. I've tried a "lost sticker" FBus cable that seems perfectly fit which phone will always show local mode when plugged in but can never really detected by Cyclone; I've also tried the 1100 FBus cable (which has the same exact connectors / pins as the other one but thicker) and phone still can't be detected and won't even show local mode.... :(:(:( OMG. I never thought it would be so complicated to unlock this little phone... |
Try to flash phone fist. You must have the same version in pc and in phone when doing unlock. |
BR Alex |
No idea.. I use the cable 1110A of my old HWK cable pack and works perfect.. obviously I connect it directly to the box without the yellow adapter as it is DCT4. Try cleaning a bit the pinouts on the telephone with a cotton bud and as well unplug the box and plug it back before retry. BR Alex |
I've tried all the compatible FBus cables; no luck. Cleanning, tapping the connector won't work. This is the log I got when using the easy cable All initialized - Ready to work MCU Version V 5.23 MCU Date 03-10-08 Product RH-106 Manufacturer (c) NMP IMEI 011539006083723 Mastercode 5255305267 IMEI Spare 0A11350960807302 IMEI SV 0311350960807352F4000000 PPM V 5.23, 03-10-08, RH-106, (c) NMP, UB PSN RAO291655 Product Code 0563363 Module Code 0203485 Basic Product Code 0564450 PSD 0000001800000000 HW 0336 UEM 1328 UPP 8850 RFIC 0700 DSP P06w45.v47 LCD WINTEK:NAXv84, ST7628 ADSP Sw p)V 5.23\n03-10-08\nRH-106\n(c) NMP\nub_na Asic 11 HW Signature AA3C7DE9B9C0F4F8 Simlock Server SIMLOCK SERVER Simlock Key 3102000000000000 Simlock Profile 9000000000010002 Simlock Aux 000B0000 Simlock IMEI 00000115390060837200 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310160 Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310200 Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310210 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310220 Simlock [5,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310230 Simlock [6,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310240 Simlock [7,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310250 Simlock [8,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310260 Simlock [9,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310270 Simlock [10,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310310 Simlock [11,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310580 Simlock [12,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310660 Simlock [13,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310800 Simlock [14,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310490 Starting PM read in range 0-512... [2] Reading 8 records [2,0] Reading 50593793 bytes Failed to read PM -> Failed to read PM Record 2,0 Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding MCU Version V 5.23 MCU Date 03-10-08 Product RH-106 Manufacturer (c) NMP IMEI 011539006083723 Mastercode 5255305267 Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RH-106_V 5.23.unlock_img Writing patch file... Booting UPP... Box VPP disabled Processing Flash Image Failed -> UPP Not Responding Failed to Unlock DCT4 -> Failed to write patch file It just keeps hanging at "Booting UPP...". I'm not sure exactly what that means but I just unlocked an E71x without any problems (so I don't think my box is installed incorrectly) Or is it because this version is not unlockable yet?? |
Booting UPP... ---------------------> try holding power botton on fone at this stage Failed to Check DCT4 Flashing Bus -> UPP Not Responding |
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.07, (Sep 11 2009 03:35:10, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags Box Serial Number: C00002A0 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D1000159 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.08v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.25v PASSED VBAT Voltage 5.00v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.95v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 05.22 MCU Date 30-10-08 Product RM-438 Manufacturer (c) Nokia IMEI 351942033596915 Mastercode 415776516 Selecting unlock method... Using Super DCT4 Activation Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-438_V 05.22.sunlock_img Writing patch file... Booting UPP... Box VPP disabled Processing Flash Image Failed -> UPP Not Responding Failed to Unlock DCT4 -> Failed to write patch file MCU Version V 05.22 MCU Date 30-10-08 Product RM-438 Manufacturer (c) Nokia IMEI 351942033596915 Mastercode 415776516 Selecting unlock method... Using Super DCT4 Activation Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-438_V 05.22.sunlock_img Writing patch file... Booting UPP... Box VPP disabled Processing Flash Image Failed -> UPP Not Responding Failed to Unlock DCT4 -> Failed to write patch file MCU Version V 05.22 MCU Date 30-10-08 Product RM-438 Manufacturer (c) Nokia IMEI 351942033596915 Mastercode 415776516 Selecting unlock method... Using Super DCT4 Activation Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-438_V 05.22.sunlock_img Writing patch file... Booting UPP... Box VPP disabled Processing Flash Image Failed -> UPP Not Responding Failed to Unlock DCT4 -> Failed to write patch file How to solve it? |
If Your Are Using Adapter, Don,t Use It And Put Direct Cable in Service Port . |
yes Direct Cable in Service Port use? |
What VPP settings do you have in the tab DCT4/flash? should be on Phone.. BR Alex |
