Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 06-06-2013, 15:58   #1 (permalink)
Member: 153893
Thanks Meter: 266
Pls help need this product code:059C1F7 C5-00 rm-645 after flash dead only vibrate
pls help need someone to upload me nokia c5-00 rm-645 flash file
after flash with cyclone now phone dead only vibrate
here is the logs
Booting CMT...
[Nokia USB Flashing Generic]: Port opened OK!
Old ROM Detected
CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104
CMT_EM_ASIC_ID: 00000C35
CMT_EM_ASIC_ID: 00000C30
CMT_PUBLIC_ID: 25C000179C9C0344F796E32580AEFB2321B23856
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B
CMT_BOOT_ROM_CRC: E693EF0D
CMT_SECURE_ROM_CRC: AC22615B
CMT Ready!
rm645_071.005_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Searching for BootCode: DualLine 32Bit
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Waiting for USB Boot ROM Answer...
ROM Ret: 0xFFFD125D
ROM CMT dwAddr: 0x10004FF0
ROM CMT dwLength: 0x00627837
Seems ROM Initialized OK!
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020004000000031, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Box TX2 Data Pin set to: Service Pin 3
Waiting for FUR Client become avaiable...
FUR Avaiable!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00020000-0x0003FFFF, ONENAND
EraseArea[0,CMT]: 0x00060000-0x004DFFFF, ONENAND
EraseArea[0,CMT]: 0x008E0000-0x0AE3FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 0.781s
Writing all blocks...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS+PMML Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT LDSP Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 25.594s
Flashing Speed: 31674.84 kBit/S
Processing rm645_071.005_prd.core.fpsx (APE)...
Processing rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx.part (CMT)...
rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx.part, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x06D40000-0x0A03FFFF, ONENAND
Erase taken 0.265s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 8.625s
Flashing Speed: 35448.99 kBit/S
Processing rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx.part (APE)...
Processing rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx (CMT)...
rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x0A040000-0x0AE3FFFF, ONENAND
Erase taken 0.94s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 0.157s
Flashing Speed: 417.78 kBit/S
Processing rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx (APE)...
Processing rm645_071.005_U000.000_prd.uda.fpsx (CMT)...
rm645_071.005_U000.000_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x0AE40000-0x0F63FFFF, ONENAND
Erase taken 0.359s
TurboCache Loaded!
All blocks written OK! Time taken 0.750s
Flashing Speed: 14815.55 kBit/S
Processing rm645_071.005_U000.000_prd.uda.fpsx (APE)...
Restarting MCU...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Phone not detected at USB -> Timeout, no any compatible USB device detected.
Old 06-07-2013, 06:35   #2 (permalink)
Member: 1798336
Thanks Meter: 4
here is the logs
try another version sir maybe your firmware old or corrupt..
use another version here
also here
Old 06-07-2013, 09:26   #3 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
backup all certs
erase npc
full backup pm
full erase
flash again
restore certs
restore pm
repair sd and let cyclone to write pm
The Following User Says Thank You to Mr.3. For This Useful Post:
Old 06-07-2013, 09:30   #4 (permalink)
Member: 1105644
while in factory set mood ,remove the usb cable and insert within a second ..see what happens
Old 06-07-2013, 10:00   #5 (permalink)
Crazy Poster
Member: 1351426
Thanks Meter: 8
pls dnt downgrade i have d solution flash with rm645_071.005_prd.core.fpsx rm645_071.005_12.01_MEA_I_prd.rofs2.fpsx rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx rm645_071.005_U000.000_prd.uda.fpsx RM645_ENO_10wk48v0.001.fpsx just download this files and enjoy 1000000000000000 sure
Page generated in 0.19402 seconds with 8 queries
