Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 06-22-2012, 13:06   #1 (permalink)
Member: 1300483
plz check logs my n96 was on be4 now comes on with white screen after flash
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.04, (Jun 10 2012 18:37:23, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0002733
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32
Initializing security card...
Card Serial Number: D700012D
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4.95v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.77v PASSED
VBAT Voltage 0.00v PASSED
VBAT Voltage 4.91v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 4.86v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 668.172MB
Avaiable Virtual Memory: 1.504GB
Avaiable Pagefile: 1.264GB
Initializing FBUS...
All initialized - Ready to work
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Proceeding with Recovery Mode...
Booting CMT...
Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem
Prepare phone failed with message -> Failed to Boot CMT
Recovery Mode Failed, storing Certificates Only
Booting CMT...
Failed to Create RPL from phone -> Failed to Boot / Prepare Phone
RPL backup thread finished, continuing...
Pre flash tasks finished, continuing...
Processing RM-247_30.101_prd.core.fpsx (CMT)...
Booting CMT...
Processing Flash Image Failed -> Failed to Boot CMT
Failed to Process all Image files -> Failed to process RM-247_30.101_prd.core.fpsx
Backing up RPL...
Storing Product Code...
Storing PSN...
Storing HWID...
Trying to store Simlock...
Reading Configuration Key...
Hashing...
Reading SHA1-RSA Signature...
Reading SHA1-HMAC Signature...
Storing Simlock...
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
Reading Security Block...
Security block OK and saved to "RM-247_359320022507353_22062012_122234.SecurityBlock. PM"
WARNING: "2090000343A10158409F91EC5FF530ED0860DCFF.C0002733 " Not Exists, Will read it...
Reading CYC file from phone...
Booting CMT...
APE_SYSTEM_ASIC_ID: 008815D3
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: BA8CC87A8B26CF375B55479AD42FE71743363720
APE_ROOT_KEY_HASH: 0BBC4203E2D3B82504C75CB65E906A35
APE_BOOT_ROM_CRC: 137A9A3B
APE_SECURE_ROM_CRC: 33259D2C
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 2090000343A10158409F91EC5FF530ED0860DCFF
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020880400006B21, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
Sending Auxiliary Loader...
Auxiliary Loader Sent!
Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs
Custom loader running OK! Working...
Readed OK, Saving to "2090000343A10158409F91EC5FF530ED0860DCFF.C0002733 "
Storing Additional Data...
Checking Superdongle Key...
Encrypting Superdongle Key...
Storing Superdongle Key...
Checking CMLA Key...
Storing CMLA Key...
Booting CMT...
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5
FlashChip 0x00208804 (ST), Size: 8MBytes, VPP: 9V
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
STn8815_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5
Adding FUR Client (APE, State: Start)...
APE FUR Ready!
FlashChip[0,APE]: 0x0000000000000000, Unknown, RAM
FlashChip[0,APE]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,APE]: 0x002000B100000000, ST, ONENAND
FlashChip 0x002000B1 (ST), Size: 8MBytes, VPP: 21V
STn8815_STNFMS_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: N8815 ALG STNFMS
TurboCache Loaded!
Writing APE KEYS Certificate...
Writing APE PASUBTOC Certificate...
Writing APE ALG Certificate...
APE Algorithm Ready!
Adding FUR Client (APE, State: Ready)...
APE FUR Ready!
Box VPP disabled
Internal APE Phone VPP Enabled
PAPUBKEYS Hash for APE: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
Flashbus Write baud set to 5.0Mbits
Storing NPC...
Storing CCC...
Storing HWC...
Storing VARIANT...
CMT PARTNERC Not Found
Processing APE Part...
Storing PSN...
Storing HWID...
Storing NPC...
Storing CCC...
Storing HWC...
APE VARIANT Not Found
APE PARTNERC Not Found
Restarting MCU...
RPL Saved OK
Booting CMT...
CMT Ready!
RM-247_30.101_prd.core.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5, N8815 ALG STNFMS, BB5
Flashbus Write baud set to 51Kbits
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00080000-0x007A6EE9, NOR
EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR
EraseArea[0,CMT]: 0x00880000-0x00EFFFFF, NOR
Waiting 320s for erasure finish...
Erase taken 60.906s
Writing all blocks...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 36.312s
Flashing Speed: 22487.72 kBit/S
Restarting MCU...
Processing RM-247_30.101_prd.core.fpsx (APE)...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE FUR Ready!
TurboCache Loaded!
APE FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x00000000-0x0007FFFF, NAND
EraseArea[0,APE]: 0x00080000-0x000BFFFF, NAND
EraseArea[0,APE]: 0x000E0000-0x0045FFFF, NAND
EraseArea[0,APE]: 0x00840000-0x0A8FFFFF, NAND
Erase taken 2.594s
TurboCache Loaded!
Writing APE X-LOADER Certificate...
Writing APE PRIMAAPP Certificate...
Writing APE SOS*UPDAPP Certificate...
Writing APE SOS+XZIP Certificate...
Writing APE PAPUBKEYS Certificate...
Writing APE SOS+CORE Certificate...
Writing APE SOS+ROFS1 Certificate...
All blocks written OK! Time taken 183.297s
Flashing Speed: 4454.92 kBit/S
Restarting MCU...
Processing RM-247_30.101_098.1_prd.customer.fpsx (CMT)...
Processing RM-247_30.101_098.1_prd.customer.fpsx (APE)...
Booting CMT...
CMT Ready!
RM-247_30.101_098.1_prd.customer.fpsx, Type: Flash Image, Algo: N8815 ALG STNFMS, BB5, XSR 1.5, BB5
Flashbus Write baud set to 650Kbits
Flashbus Read baud set to 100Kbits
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE FUR Ready!
TurboCache Loaded!
APE FUR Ready!
Box VPP disabled
EraseArea[0,APE]: 0x09A00000-0x0A8FFFFF, NAND
Erase taken 0.281s
TurboCache Loaded!
Writing APE SOS+ROFS3 Certificate...
All blocks written OK! Time taken 0.203s
Flashing Speed: 217.10 kBit/S
Restarting MCU...
Processing RM-247_30.101_002.1_prd.language.fpsx (CMT)...
Processing RM-247_30.101_002.1_prd.language.fpsx (APE)...
Booting CMT...
CMT Ready!
RM-247_30.101_002.1_prd.language.fpsx, Type: Flash Image, Algo: N8815 ALG STNFMS, BB5, XSR 1.5, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE FUR Ready!
TurboCache Loaded!
APE FUR Ready!
Box VPP disabled
EraseArea[0,APE]: 0x07780000-0x099FFFFF, NAND
Erase taken 0.594s
TurboCache Loaded!
Writing APE SOS+ROFS2 Certificate...
All blocks written OK! Time taken 37.328s
Flashing Speed: 4221.21 kBit/S
Restarting MCU...
Processing RM-247_30.101_100.1_prd.uda.fpsx (CMT)...
Processing RM-247_30.101_100.1_prd.uda.fpsx (APE)...
Booting CMT...
CMT Ready!
RM-247_30.101_100.1_prd.uda.fpsx, Type: Flash Image, Algo: N8815 ALG STNFMS, BB5, XSR 1.5, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE FUR Ready!
TurboCache Loaded!
APE FUR Ready!
Box VPP disabled
Erase Partition (APE)
Erase taken 1.437s
TurboCache Loaded!
All blocks written OK! Time taken 25.625s
Flashing Speed: 4203.02 kBit/S
Restarting MCU...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
MCU Version V ICPR72_09w13.3
MCU Date 15-09-09
Product RM-247 (Nokia N96)
Manufacturer (c) Nokia
IMEI 359320022507353
Mastercode 2714423574
IMEI Spare 3A95230022053705
IMEI SV 3395230022053715F0000000
PSN CHH862683
Product Code 0579094
Basic Product Code 0563931
PSD 0000000000000000
LPSN 0
WLAN MAC 0022FC9BE967
APE SW 30.101
APE Variant 30.10130.101.002.130.101.098.1
APE Test ENOSW_4032_PR11.0835_003
APE HW 0
APE ADSP 0
APE BT HCI Version 3 (rev. 4096). LMP Version 3 (rev. 8738). Manufacturer 15.
RETU 15
TAHVO 22
AHNE 11
HW 1001
RFIC 17141715
DSP MC_4032_ICPR72_09w13
Simlock Server SIMLOCK SERVER
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Old 06-22-2012, 13:23   #2 (permalink)
Member: 1300483
some 1 ploz give me quick solution for it plz
Old 06-22-2012, 13:34   #3 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Tick use old protocl/loaders and full flash it again
Alex
Old 07-01-2012, 13:10   #4 (permalink)
Member: 1300483
mate i flashed it with advance box job done cyclone is shieeeet
Old 07-01-2012, 15:12   #5 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
If you can't use the tool then don't use it.
Alex
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Page generated in 0.40902 seconds with 11 queries
