02-27-2010, 05:06 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Uzhgorod
Member: 297179 Status: Offline Thanks Meter: 10 | Is it possible, to repair 6500s with such log? [SOLVED - Hardware problem] Code: Started Phone Security Analysis... MCU Version V 10.00 MCU Date 06-03-09 Product RM-240 Manufacturer (c) Nokia IMEI 353076029388496 Mastercode 5043113437 Reading Security Block... Security block OK and saved to "RM-240_353076029388496_27.02.2010_55753.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "1420000DA6980254456F3810850966BF1D292585.C00005E7" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! |
02-27-2010, 11:31 | #2 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Simlock & IMEI are OK, do as soft indicates: Quote:
02-27-2010, 11:47 | #3 (permalink) |
Member: 297179 Status: Offline Thanks Meter: 10 | I did it few times, but same result, I think problem is here Code: Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) |
02-27-2010, 12:01 | #4 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Try writing HWC & CCC, then do SX4 auth and write PM with fields 1 & 309 search here, for HWC & CCC : http://forum.gsmhosting.com/vbb/showthread.php?t=926980 Here you can get a good PM, ready to use: http://forum.gsmhosting.com/vbb/show...92&postcount=6 If doesnt works, post the logs of the operation. BR |
02-27-2010, 13:00 | #5 (permalink) |
Member: 297179 Status: Offline Thanks Meter: 10 | I did it, now phone blink on "Nokia" and have such log. I think its hardware problem? Or may be soft? Code: Started Phone Security Analysis... MCU Version V 10.00 MCU Date 06-03-09 Product RM-240 Manufacturer (c) Nokia IMEI 353076029388496 Mastercode 5043113437 Reading Security Block... Security block OK and saved to "RM-240_353076029388496_27.02.2010_135827.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "1420000DA6980254456F3810850966BF1D292585.C00005E7" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! |
02-27-2010, 16:24 | #8 (permalink) |
Member: 297179 Status: Offline Thanks Meter: 10 | Problem solved. That was hardware problem, I removed 3g small camera and now all is OK. I thik this was original problem of phone, but someone before me erased certificates, so I thougth that it was security soft problem. Thanks to all, close the thread. |
Is it possible to repair K550 GDFS with SEtool or Cruiser? | NawabN Sahoo | Sony Ericsson | 3 | 09-28-2009 14:08 |
is it possible to repair Q380 with out pinfinder? | lorenzo roberto | Infinity-Box | 1 | 12-29-2008 08:27 |
Is it possible to repair E250 Imei with UST PRO 2 ? | MisterX GSMFREE | UST Pro II | 5 | 12-09-2008 08:29 |
Is it possible to repair killed Alc 332 with USB-Smart? | Mobilusis | Alcatel (USB-Smart) | 0 | 06-14-2006 20:34 |
is it possible to repair 4locks t65 with tornado | mobile star | UFS2 + UFS3-Tornadoflasher | 6 | 05-29-2005 20:15 |
