View Poll Results: add new gpu ati 6xxx in log to code | |||
yes | 442 | 91.70% | |
no | 43 | 8.92% | |
Multiple Choice Poll. Voters: 482. You may not vote on this poll |
01-28-2011, 06:02 | #16 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
01-28-2011, 07:57 | #20 (permalink) | |
Banned Join Date: Jan 2009 Location: deep inside hell's fire
Member: 944613 Status: Offline Thanks Meter: 14 | Quote:
a gpu or a cpu will work quite in range up to 100 degrees celcius, the hotter it gets the better the peformance (law of any semiconductor) but around 110 and up the processor will litreally burn in flames lol mAking them work around 90 degrees should be sweet br 11252412121518120151825 919 21311 914 25152118 1497820 13185 | |
01-28-2011, 11:53 | #22 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: Little apt called Alhambra
Member: 13748 Status: Offline Thanks Meter: 84 | Quote:
Last time I tried to go faster than 850 psu burn cause the change of watts nedded and couldn´t make cooler than 85º Can I ask what psu do you have? I´m using a 720Watts for Mainboard+5970 and second 540Watts for a 5850 and HD, Fans... etc... and burned one was, of course, the 720w psu. thx | |
01-28-2011, 13:28 | #23 (permalink) | |||
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | Quote:
Thanks for info sir ! But to setup Fan speed manually , it doesn't allow , this option is bright im using : MSI AUTOBURNER can u give me instruction ??? Quote:
POST 12 Quote:
I'll check exact Brand tomorrow , im at home now.. LITTLE MASTER | |||
01-28-2011, 13:53 | #24 (permalink) |
Registered User Join Date: Aug 2007 Location: TEA||Tukang Endog Asin Age: 13
Member: 559397 Status: Offline Thanks Meter: 53 | INTEL Pentium E5700 3.0ghz GIGABYTE GA-G41M-COMBO VISIPRO 2GB PC-6400 ASUS EAH5970/G/2DIS/2GD5 CORSAIR CX Series : CMPSU-600CXEU, 600W, Active PFC, Single Rail +12V Which should be considered to add |
01-29-2011, 00:02 | #26 (permalink) | |
No Life Poster Join Date: May 2009
Member: 1028392 Status: Offline Thanks Meter: 87 | Quote:
Fan speed % ? | |
02-20-2011, 01:21 | #27 (permalink) |
Insane Poster Join Date: Jan 2011 Location: madrid spain
Member: 1500108 Status: Offline Thanks Meter: 13 | My pc configuration for sl3 unlocking. Hi, i have bought a lot of hardware to check the sl3 unlocking procedure. I have now 2 5970 and 3 5870 and i have tested them in differente configurations. I get the best stability with 11.1 ccc drivers, with 11.2 the system crashes. I have used 3 motherboards, 2 amd and 1 intel, both amd with 4 cores and the intel with 6 cores, i have not apreciated difference in this. 2x 5970hd with art cooling. the problem is that 1 art cooling xtreme colapses the other, then the 5970 with less air conduction crashes. 2x5970hd 1 with art cooling xtreme and 1 with factory cooler. Best performance and best results, time around 20 secs/salt. Very expensive. I used a 1250w psu. 1x5970hd with art cooling xtreme and 1 5870hd with factory cooler. Best performance/price relation. Im having around 29 secs/salt using a 850 psu. 2x5870 around 39 secs, cheap , you can do it work with a 600-750 psu I dont need 1 5970 and 2 5870 anymore, im happy with my results now, and i dont need more to unlock 5 or 6 cells a week. Im using 1 amd phenom 2x2 565 with 4 cores working at 3.4 ghz, 4gb ddr3 pny and 850w modular psu. i have spent around 1000€ in this hardware with 1 5970 and 1 5870 |
The Following User Says Thank You to zpanish For This Useful Post: |
02-21-2011, 01:30 | #30 (permalink) |
Member: 1500108 Status: Offline Thanks Meter: 13 | yes, thats right, ill hope to explain it well. with the artic cooling xtreme the 5970 fits on 3 slots. The cooler ****s fresh air over the heatpipes and cooling surface, then the hot air go around, you need fresh air to do the work. When you put 2 of these together the coolers of the first is very close to the back of the other (that is hot as hell) then the coolers dont have fresh air, but also the air they take is very hot. When the gpus went over 102º they crashed. With 1 5970 with artic cooling and 1 with factory cooler the space between both cards is higuer, in the other hand the factory cooler works in a different way, it takes fres air in the end of the card and **** it out of the box, then it can do a correct job , doent matter if there is a card at 70º close. With this configuration u can get 70º 70º 60º 60º with 100% fan speed. The cons is the noise of the factory fan |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
All 4 locks on 6110 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-19-2010 02:44 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
i can unlock all nokia 5110/6110/6150 | spterminator | Main Sales Section | 0 | 07-30-1999 03:05 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
