View Poll Results: add new gpu ati 6xxx in log to code | |||
yes | 442 | 91.70% | |
no | 43 | 8.92% | |
Multiple Choice Poll. Voters: 482. You may not vote on this poll |
04-07-2011, 12:12 | #227 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Good job from Lavarow side. The coders are working on their update and with their timescale so, please, leave them doing their job BR Alex |
04-07-2011, 12:33 | #231 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Somewhere in the World Age: 54
Member: 9848 Status: Offline Thanks Meter: 144 | Perhaps Nokia blocked some SX-5 serial numbers used in log to unlock code calculation. This number should be editable like it's now the case by Genie codtofinal app. |
04-07-2011, 12:33 | #232 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | I don't know how you did this bruteforce but it is completely wrong The SHA1 of the code found is 658f44e1d2f6390a901ea1da5fe26975eb7b2efc and not 95E7BE004803E3C39D89A7677D8ADA6148608D93 as present in the file So you must do the BF again BR Alex |
04-07-2011, 12:55 | #234 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | removed the file attached but I can't help you about the server. Just pass me again the cod file and I'll calculate you the nck code once ready BR Alex |
04-07-2011, 16:06 | #235 (permalink) |
Freak Poster Join Date: May 2009
Member: 1036343 Status: Offline Thanks Meter: 13 | Just a little suggestion: if you keep having errors on ighashgpu just put a bit down the frequency of the second GPU (Sample 1st gpu 900mhz, 2nd GPU 850mhz) BR Alex BROTHER CAN U SHOW ME HOW TO PUT DOWN THE frequency of the GPU , MY PC CARD HD 5970 ALWAYS CRASH IT MAKE ME SICK , MY PC USE MOTHER BOARD GIGABIY X58A-UDR3 CPU = i7 DUAL CORE 3.2GHZ , 6G RAM , PSU SILENT PRO GOLD 1200W ,,,,,, IT ALWAYS CARSH IN EVERY 20SECOND ,,, HELP ME OUT HOW TO SET UP THE CARD PLS !!!!!!!!!!!!!!!!! THANKSSSSSSSSSSSSSSSS ALOT |
04-07-2011, 16:06 | #236 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | Question I read the following with my CycloneBox: Code: MCU Version V ICPR72_10w04.5 MCU Date 22-03-10 Product RM-588 (Nokia 5230) Manufacturer (c) Nokia IMEI 353424044739964 Mastercode 1342717117 IMEI Spare 3A35240444379906 IMEI SV 3335240444379916F1000000 CNT 20.0.005_005_U205 PSN AIA164852 Product Code 0592214 Module Code 0204359 Basic Product Code 0582715 PSD 0000000000000000 LPSN 0 APE SW V 20.0.005 APE Variant V 20.0.005V 20.0.005 20.0.005.205.05 APE Test rm588_ENO_x_09wk43v0.050 APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 0512 RFIC 17141716 DSP simon_ICPR72_10w05 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F Auto Selecting Flash Files on User Request... Product Code: 0592214 Scanning avaiable products... No flash paths set! Go to Settings -> Paths and set them! Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 05D0010BA69C8E5204D00DF09EEDFC480214CD6C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000231, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7DC72D3FDC552426A4479BC820097D304CFB6C15 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... PAPUBKEYS Hash for CMT: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Allowed starting calculation with ighashgpu, so which one it's the correct one? I know it's a 5230 but, I can use this method for sending to someone with supercomputer isn't it? Regards |
04-07-2011, 16:16 | #238 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | SL3 Code Range scanned, no valid Unlock Code found, contact Support [ solved ] BB5 Unlock Started... MCU Version V ICPR72_09w44.18 MCU Date 28-05-10 Product RM-505 (Nokia N97) Manufacturer (c) Nokia IMEI 354225037458507 Mastercode 277262760 Simlock Server SIMLOCK SERVER Simlock Key 2080100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 20801F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 20801F Connecting to Cyclone Server... Cyclone Server (1.0.0.656), Cyclone Box Team 2008-2011 - Ready. Happy Eid Milad un Nabi Checking job status... BB5 Unlock Failed -> SL3 Code Range scanned, but no valid Unlock Code found, please contact Support Team for assistance. |
04-07-2011, 16:16 | #239 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Hi, the hash for the code calculation are not the one you can read with a check flashing bus but some hashes crypted in the PM120 You need the proper loaders and software to extract them BR Alex |
04-07-2011, 16:18 | #240 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | IMEI: 354225037458507 Finished at: 2011-04-02 19:02:25 Refunded OK BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
All 4 locks on 6110 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-19-2010 02:44 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
i can unlock all nokia 5110/6110/6150 | spterminator | Main Sales Section | 0 | 07-30-1999 03:05 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
