Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
View Poll Results: add new gpu ati 6xxx in log to code
yes 411 91.74%
no 40 8.93%
Multiple Choice Poll. Voters: 448. You may not vote on this poll
Old 01-28-2011, 05:02   #16 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Originally Posted by Little_Master View Post
I got 3 PC
All Have :
Intel i7 CPU
500 GB - Hard DRIVE
6GB - DDR3 RAM
900 Walt - POWER SUPPLY
HD5970 4GB ( LIMITED EDITION ) Graphic Card ( one in each PC
Speed getting : 35-36 sec per salt
GPU Usage with Brute Force : 98%
GPU Temprature : 77-80%
Overclock Set to 900mhz
Memory Clock 1200mhz
LITTLE MASTER
Whats mean by 77-80% temp,would you explain please in celcius.
Old 01-28-2011, 05:11   #17 (permalink)
Little_Master's Avatar
Member: 1205146
Sonork: 100.1601660
this is in celcious sir ..
computer reading one 5970 Graphic Cards as 2 GPU
one gpu temprature 72-75 c
sendond 77-80 c
I KNOW IT'S TOO HOT , MY CPU CASE IS ALWAYS OPEN
LITTLE MASTER
Old 01-28-2011, 05:15   #18 (permalink)
Member: 209722
sendond 77-80 c
LITTLE MASTER
Oh i got it
you are lucky one who have no burning for GPU at this temp.
Old 01-28-2011, 06:45   #19 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
I have an xfx HD 5970 4gb limited edition too but the temperature is never more then 61°
set the fan in manual to 95%
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 01-28-2011, 06:57   #20 (permalink)
Member: 944613
Oh i got it
a gpu or a cpu will work quite in range up to 100 degrees celcius, the hotter it gets the better the peformance (law of any semiconductor) but around 110 and up the processor will litreally burn in flames lol
mAking them work around 90 degrees should be sweet
br
11252412121518120151825 919 21311 914 25152118 1497820 13185
Old 01-28-2011, 10:35   #21 (permalink)
DaWizard's Avatar
Member: 61557
Nokia 2730c done with SL3 Brute Force in LESS THAN 2 hours.
What a LUCK !!!
Thanks to All Teams to support SL3
LITTLE MASTER
bro
what is the spec of your pc brother. . can youshare it with us
BR,
Cheers
Old 01-28-2011, 10:53   #22 (permalink)
Member: 13748
I got 3 PC
All Have :
Intel i7 CPU
500 GB - Hard DRIVE
6GB - DDR3 RAM
LITTLE MASTER
900Mhz?
Last time I tried to go faster than 850 psu burn cause the change of watts nedded and couldn´t make cooler than 85º
Can I ask what psu do you have?
I´m using a 720Watts for Mainboard+5970 and second 540Watts for a 5850 and HD, Fans... etc... and burned one was, of course, the 720w psu.
thx
Old 01-28-2011, 12:28   #23 (permalink)
Member: 1205146
Sonork: 100.1601660
Alex
Thanks for info sir !
But to setup Fan speed manually , it doesn't allow , this option is bright
im using : MSI AUTOBURNER
can u give me instruction ???
Originally Posted by DaWizard View Post
bro
BR,
Cheers
Already posted here sir :
POST 12
Originally Posted by Trixxie View Post
900Mhz?
thx
I'll check exact Brand tomorrow , im at home now..
LITTLE MASTER
Old 01-28-2011, 12:53   #24 (permalink)
Member: 559397
INTEL Pentium E5700 3.0ghz
GIGABYTE GA-G41M-COMBO
VISIPRO 2GB PC-6400
ASUS EAH5970/G/2DIS/2GD5
CORSAIR CX Series : CMPSU-600CXEU, 600W, Active PFC, Single Rail +12V
Which should be considered to add
Old 01-28-2011, 15:44   #25 (permalink)
MihaiGsm2003's Avatar
Member: 62032
Sonork: 1582666
sendond 77-80 c
LITTLE MASTER
Use watercooler, is verygood, max 50º c activity 90%, quietly!!!
Old 01-28-2011, 23:02   #26 (permalink)
orheiz's Avatar
Member: 1028392
I got 3 PC
All Have :
Intel i7 CPU
500 GB - Hard DRIVE
6GB - DDR3 RAM
LITTLE MASTER
Cpu Volt?
Fan speed % ?
Old 02-20-2011, 00:21   #27 (permalink)
Member: 1500108
My pc configuration for sl3 unlocking.
Hi, i have bought a lot of hardware to check the sl3 unlocking procedure. I have now 2 5970 and 3 5870 and i have tested them in differente configurations. I get the best stability with 11.1 ccc drivers, with 11.2 the system crashes. I have used 3 motherboards, 2 amd and 1 intel, both amd with 4 cores and the intel with 6 cores, i have not apreciated difference in this.
2x 5970hd with art cooling. the problem is that 1 art cooling xtreme colapses the other, then the 5970 with less air conduction crashes.
2x5970hd 1 with art cooling xtreme and 1 with factory cooler. Best performance and best results, time around 20 secs/salt. Very expensive. I used a 1250w psu.
1x5970hd with art cooling xtreme and 1 5870hd with factory cooler. Best performance/price relation. Im having around 29 secs/salt using a 850 psu.
2x5870 around 39 secs, cheap , you can do it work with a 600-750 psu
I dont need 1 5970 and 2 5870 anymore, im happy with my results now, and i dont need more to unlock 5 or 6 cells a week.
Im using 1 amd phenom 2x2 565 with 4 cores working at 3.4 ghz, 4gb ddr3 pny and 850w modular psu. i have spent around 1000€ in this hardware with 1 5970 and 1 5870
The Following User Says Thank You to zpanish For This Useful Post:
Old 02-20-2011, 22:32   #28 (permalink)
Member: 7610
Sonork: 100.1575451
if you want to sell anything post me private message
thank you
Old 02-21-2011, 00:06   #29 (permalink)
Member: 1223057
zpanish, are you saying you have tried 2 x Artic Cooling extreme with 2 x HD5970 and this does not work well?
Old 02-21-2011, 00:30   #30 (permalink)
Member: 1500108
yes, thats right, ill hope to explain it well.
with the artic cooling xtreme the 5970 fits on 3 slots. The cooler ****s fresh air over the heatpipes and cooling surface, then the hot air go around, you need fresh air to do the work. When you put 2 of these together the coolers of the first is very close to the back of the other (that is hot as hell) then the coolers dont have fresh air, but also the air they take is very hot. When the gpus went over 102º they crashed.
With 1 5970 with artic cooling and 1 with factory cooler the space between both cards is higuer, in the other hand the factory cooler works in a different way, it takes fres air in the end of the card and **** it out of the box, then it can do a correct job , doent matter if there is a card at 70º close.
With this configuration u can get 70º 70º 60º 60º with 100% fan speed. The cons is the noise of the factory fan
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
All 4 locks on 6110 steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 04-19-2010 02:44
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.48566 seconds with 13 queries
