Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
View Poll Results: add new gpu ati 6xxx in log to code
yes 410 91.72%
no 40 8.95%
Multiple Choice Poll. Voters: 447. You may not vote on this poll
Old 02-21-2011, 00:38   #31 (permalink)
Member: 1223057
ok, I think i understand: so the second cooler is using hot air! Not good....
by factory cooler you mean just normal cooling fan or fan on case?
Old 02-21-2011, 01:39   #32 (permalink)
Member: 1500108
I mean this one as factory cooler/fan
http://www.legox.com/wp-content/uplo...on-HD-5970.jpg
Old 02-21-2011, 04:12   #33 (permalink)
Member: 305558
How about with 1 overclocked 5970 only?....
Old 02-21-2011, 09:53   #34 (permalink)
Member: 1500108
with no overclocked 5970 i had worst time than 2x 5870
Old 02-21-2011, 10:19   #35 (permalink)
Member: 1500108
just overclocked the 5970, just to 800mhz and im having 26.7, 28.1 salts
Old 02-21-2011, 13:59   #36 (permalink)
orheiz's Avatar
Member: 1028392
It doesn't matter how many seconds/salt you have if you will not get the code... I've got "not found" 2 times with the same log and after i switched to xxkey and i got result for first time. XXkey is slower (5-8sec more) but more chance to get the code. Recommended OC max 10-20%
Old 02-21-2011, 14:59   #37 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Use one of this (CoolIt OMNI for HD 5970) for the card which gets more hot.. it is not too expensive and you can install it in less then 15 minutes.
Only need is the space for 1 12cm fan
Alex
Old 02-21-2011, 15:59   #38 (permalink)
Member: 1026122
Hi, i have bought a lot of hardware to check the sl3 unlocking procedure. I have now 2 5970 and 3 5870 and i have tested them in differente configurations. I get the best stability with 11.1 ccc drivers, with 11.2 the system crashes. I have used 3 motherboards, 2 amd and 1 intel, both amd with 4 cores and the intel with 6 cores, i have not apreciated difference in this.
2x 5970hd with art cooling. the problem is that 1 art cooling xtreme colapses the other, then the 5970 with less air conduction crashes.
2x5970hd 1 with art cooling xtreme and 1 with factory cooler. Best performance and best results, time around 20 secs/salt. Very expensive. I used a 1250w psu.
1x5970hd with art cooling xtreme and 1 5870hd with factory cooler. Best performance/price relation. Im having around 29 secs/salt using a 850 psu.
2x5870 around 39 secs, cheap , you can do it work with a 600-750 psu
I dont need 1 5970 and 2 5870 anymore, im happy with my results now, and i dont need more to unlock 5 or 6 cells a week.
Im using 1 amd phenom 2x2 565 with 4 cores working at 3.4 ghz, 4gb ddr3 pny and 850w modular psu. i have spent around 1000€ in this hardware with 1 5970 and 1 5870
Thanks for the post...
So I like to go for 1 pc...What you will tell us to buy...
I like to buy less then $1000.So what are the configuration should I want to buy.
(In the forum So much of details but I like to hear from you)
thanks.
Old 02-21-2011, 17:33   #39 (permalink)
orheiz's Avatar
Member: 1028392
With oc maybe you will not get the code with log2cod .. check my posts....
Old 02-25-2011, 00:22   #40 (permalink)
Member: 1500108
9850 and no cod, perhaps you are right and overclock doesnt help
Old 02-25-2011, 15:53   #41 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Just a little suggestion: if you keep having errors on ighashgpu just put a bit down the frequency of the second GPU (Sample 1st gpu 900mhz, 2nd GPU 850mhz)
Alex
Old 03-15-2011, 09:47   #42 (permalink)
nunu.gabriel's Avatar
Member: 857353
POST ALL the questions about ighashgpu and ATI card configuration ONLY HERE
In my country ati hd 5970 is out of stock, I found only 5870. The question is 2 X 5870 at 1GB are ok for brute force?
Note: Any new thread related to the thread title, starting today, will be merged to this one or deleted directly.
Thanks for understanding
Old 03-15-2011, 10:34   #43 (permalink)
SiRoYa's Avatar
Member: 16107
2 x ATI 5870 = 1 ATI 5970
The Following 2 Users Say Thank You to SiRoYa For This Useful Post:
Old 03-15-2011, 11:06   #44 (permalink)
Member: 367723
in 1x5970 what is the diffarent between 1gb and 2gb
speed same or ?
cyclone team waiting for reply.
Old 03-15-2011, 16:06   #45 (permalink)
Member: 759248
truth in influencing the GB, ie 1GB, 2GB or 4GB. There is influence in that it does not matter with reference only to the GPU
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
All 4 locks on 6110 steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 04-19-2010 02:44
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.25550 seconds with 13 queries
