View Poll Results: add new gpu ati 6xxx in log to code | |||
yes | 442 | 91.70% | |
no | 43 | 8.92% | |
Multiple Choice Poll. Voters: 482. You may not vote on this poll |
07-30-2011, 13:03 | #768 (permalink) | |
No Life Poster Join Date: Jun 2008
Member: 803622 Status: Offline Thanks Meter: 41 | Quote:
what speed you get for your 5970 and the 6990. I have 2 x 6990 and my speed is 8190 - 8200M/s default config and fan running at 95%, some time i get code in 3hr, max 11hr. please share your configuration with us. Thanks | |
07-30-2011, 14:30 | #769 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | Configuration is Normal with i5 processors.. But the thing is ..u r already getting good speed..with 2x hd6990 dont tweak much this will make them non stable |
07-30-2011, 17:17 | #770 (permalink) |
Freak Poster Join Date: May 2009 Location: spain
Member: 1040105 Status: Offline Thanks Meter: 16 | hi, i'm trying my new pc for bf i5 3.1ghz 4gb ram 1250 w psu ati 5970 i have this values. gpu clock: 725 mhz memroy clock: 1000 mhz fan speed: 80% activity: 99% temp: 72ºC 3.200 3 days 12 hours is normal? the temp and anothers values? thanks... |
07-30-2011, 17:20 | #771 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
BR Alex | |
The Following User Says Thank You to moulnisky For This Useful Post: |
07-30-2011, 17:26 | #772 (permalink) |
Member: 1040105 Status: Offline Thanks Meter: 16 | thanks moulnisky in few days i have a 5870 to add to this pc i need watercooled system? i know that the answer is yes, could you say me what i need for watercooled for these card?? remember that all i know for watercooled is 0. xDD thanks another one. |
07-30-2011, 17:32 | #773 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | it depends on your local temperature and on the main board If the mainboard has at least 2 empty slots between the 2 cards and the case is well ventilated it wouldn't be essential. Just be sure the cards go at the same clock or you will have code not found problems BR Alex |
07-30-2011, 17:39 | #774 (permalink) |
Member: 1040105 Status: Offline Thanks Meter: 16 | here at south of spain the temp at summer is about 40º i have 2 slot free between cards. but i want watercooled is it is not very expensive im looking ur post #526 Ok, lets do the shopping list to watercool 2 5970 cards (Basic system) From the dangerden website you need to buy: SKUProductItem priceQuantityTotal FIT-SLI-11CrossSLI Danger Den ******** $12.95 x 2 = $25.90 GPU-6899DD-5970 Water Block Options:Fitting Size: None RamSinks: None - I'll use stock back plate Optional SLI Fitting: No Thanks Video Card Brand: sapphire $119.95 x 1 =$119.95 GPU-6899DD-5970 Water Block Options:Fitting Size: 1/2" OD ******** RamSinks: None - I'll use stock back plate Optional SLI Fitting: No Thanks Video Card Brand: $123.95 x 1 =$123.95 Subtotal: $269.80 Shipping cost: $69.77 Total: $339.57 from watercooling.co.uk you must buy insetead Qty: 1 Product: XSPC Dual 750 Bay Pump Reservoir Rev2 Multi Fascia Cost: £49.99 Qty: 1 Product: XSPC RS360 Radiator - Black Cost: £41.70 Qty: 1 Product: Alphacool 3x120mm Coolmove Power 2000rpm Fan Pack Cost: £13.10 Qty: 2 Product: 1/4" BSPP - 3/8" ID - 1/2" OD Compression Fitting Cost: £1.99 Qty: 2 Product: 10mm (3/8\') 90° Angled Fitting G1/4 Rotary - Black Nickel With O-Ring Cost: £3.32 Qty: 4 Product: PrimoChill Black Steel Spring Clips - 1/2" OD Cost: £0.58 Qty: 3 Product: Primochill tubing PrimoFlex Pro 13/10 (3/8\"ID) UV-active blue - 1m Cost: £4.53 Qty: 2 Product: Thermochill EC6 Non Conductive Coolant - UV Blue Cost: £7.65 ----------------------------------------------------------- Shipping method: Standard 3-5 Day Delivery costing £8.99 Subtotal: £158.74 VAT total: £31.75 Total: £190.49 This is the basic configuration for your watercooling system. BR Alex please could u say me if this is correct?? or i need changes at it? thannks another one |
07-30-2011, 20:19 | #775 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | In your setup if you mix a 5970 with a 5870 something will change. You need 2 different waterblocks for the setuo and you can't use the SLI ******** as they wouldn't go in line. You can use a 5970 waterblock by EK in copper/acetal (cost about 100 pounds) and an xspc waterblock for the 5870 (about 40-50 pounds). you will need 2 more 10mm (3/8\') 90° Angled Fitting G1/4 Rotary - Black Nickel With O-Ring and 2 more 1/4" BSPP - 3/8" ID - 1/2" OD Compression Fitting All the part from dangerden can be cancelled. BR Alex |
07-31-2011, 07:36 | #776 (permalink) |
Member: 575900 Status: Offline Thanks Meter: 3,177 | The New Asus P6xxx series Board r Good alot of Space Between PCiex slot ...and all slots r 16x...very ideal for water cooling or Air cooling systems Personally using |
07-31-2011, 08:30 | #777 (permalink) | |
Building a quite nasty system on it Looks like, as well, with the drivers 11.7 AMD/ATI now supports 8 GPUs and are not needed any more neither the dummy plugs to make the lot working. I'll test this shortly. The problem been finding a big case with at least 8 slots and support for 2 PSU and looks like I found it. first 2 cards now arrived I'll see if I can make working 4 of them in that case (Target is 17.000 mh/s aka 1 mobile in max 16 hours and 20 minutes with a single computer) BR Alex | |
07-31-2011, 08:36 | #778 (permalink) |
Member: 575900 Status: Offline Thanks Meter: 3,177 | Here r Mine ...in that case r 3 Vantilators...Big onces..and they work well for my country Pakistan ...each with 2x Hd6990 Am Using 1500W PSU ..and it works fine for now |
07-31-2011, 13:30 | #779 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | I'm using p7p55 Mobo with 2x6990 and 1200W PSu and working fine !! with last ver of Oclhash is giving 7xxx MH/s... With my collection have 40k MH/s... eanugh for now...but thinking to Add more in short |
07-31-2011, 13:51 | #780 (permalink) | |
This time I'm going for a world record bro hope I can get there BR Alex | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
All 4 locks on 6110 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-19-2010 02:44 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
i can unlock all nokia 5110/6110/6150 | spterminator | Main Sales Section | 0 | 07-30-1999 03:05 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
