Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
View Poll Results: add new gpu ati 6xxx in log to code
yes 410 91.72%
no 40 8.95%
Multiple Choice Poll. Voters: 447. You may not vote on this poll
Old 12-05-2011, 18:33   #1051 (permalink)
oric's Avatar
Member: 52236
Thank's Mr.Ultimate for Your support and help , but I suppose , that with my cheap 2x ATI Radeon HD5850 1GB I can achieve maximum stable bruteforcing ,overclock them to 950MHz and max. time 2days 20 hours.
The Following User Says Thank You to oric For This Useful Post:
Old 12-05-2011, 19:52   #1052 (permalink)
LOCKED4EVER's Avatar
Member: 950386
Originally Posted by oric View Post
''#6 - Install 11.11 Driver Via CUSTOM installation mode -> Deselect AMD VISION CENTRE RECOMMENDED - BEFORE INSTALLING PLEASE REMOVE ALL CROSSFIRE BRIDGES AND DISCARD THEM - THEY ARE NOT RECOMMENDED AND WILL NO LONGER BE NEEDED. UNPLUG ANY VGA DUMMIES USED - THEY ARE NO LONGER NEEDED. NO MONITOR REQUIRED TO GET ALL GPUS LOADED STABLE ANY MORE.''
For 2x5870 don't REMOVE CROSSFIRE BRIDGES and don't discard them, install AMD VISION CENTRE and active CROSSFIRE .
I did all this! Anyway i disabled crossfire in ATI centre now i see 1 GPU 2 GPU. Which means it has recognised the 2 cards. However soon as i click 32bit bat file the computer turns off
I have wired 2 PSU's together and i get 1300 watt so more than enough power. Wonder what the issue is!
Old 12-05-2011, 20:13   #1053 (permalink)
Member: 950386
Now when i enable crossfire in ATI centre and click on the 32bit bat file it loads and says status cracked! it also says press any key to continue and when i press any key the command program closes down.
Status cant be cracked as it hasn’t even tried to bruteforce the IMEI yet.
Seems as though when I enable crossfire in ATI centre and click 32bit bat file computer shuts off
When I disable crossfire in ATI centre and click 32bit bat file it shows status as cracked and also says press any key to continue but there is no cod file and cards have not been used for bruteforce yet! So status is fake.
Any ideas what the problem is?
Old 12-06-2011, 21:32   #1054 (permalink)
Member: 950386
Problem resolved...the reason why i was getting the above issues (read my last 2 or 3 posts above) was because i placed the crossfire bridge on the wrong connector. I moved the crossfire bridge up to the first connectors on the card and now oclhashcat is now stable.
Well its kind of stable im getting readings of 81c on GPU 1 and 61c on the GPU 2.
Kind Regards
Share The Knowledge
Old 12-07-2011, 00:05   #1055 (permalink)
Member: 950386
Why is the temp going up. it's now at 89c on the 5870 Asus!
Iv switched the cards around and the temp is still going up on The Asus graphics card.
The other card XFX 5870 stays at 63c and never goes any higher!
What is going on?
KR
Old 12-07-2011, 00:31   #1056 (permalink)
selective member algo bruteforce SL3
Mr.Ultimate's Avatar
Member: 665113
Sonork: 100.1583029
What is going on?
KR
welcome to the real GPU STRESS TEMPERATURES LOAD world
since you used log2cod only in the past, it used to jump trough different add.r.e.s.es. while scanning, utilizing your GPUs different way, and interfering alot in the entire process progress hence the workload has never been stable even 99% either, gpus has never experienced the REAL GPGPU STRESS, but now since you use oclhashcat-lite - it runs without interruptions and utilizes GPU's at their top potential at all the time, so the temperatures appear as high as realistically they can be. You should consider to see if there is enough spacing for a free airflow to the card thats runing hot in no matter which PCIE slot, and check the card itself after if thermal GPU compound has to be replaced, because due to ageing of the thermal grease/compound it yields to be cleaned and reapplied (if you go this way, source yourself nice big tube of Arctic-MX3 GPU thermal compound, and re-apply it on the GPU IC crystal carefully after cleaning all the old residues from the GPU IC and the heatsink base plate touching the GPU itself)
Note, Primary Graphics card should always be ~ 5-15C' degrees hotter than the secondarry card so it works little harder managing the secondry cards process together with its own, hence there is extra process/extra heat generated
Old 12-08-2011, 00:42   #1057 (permalink)
Member: 950386
Hi, the spacing i can't do anything about that just the way the board is made unless i get water cooling but i only have 2x5870's and air flow should be good enough.
What i will do is use the card that is generating the most heat on it's own and see if the temps go up. If it doesn’t then this means it cant be the compound.
The Asus 5870 tweak edition i have (card gives you 50% more power than any other 5870) may not like oclhascat and maybe doesn’t respond well to this program! Im getting 89c and when it hits 90c program just shuts down.
Iv changed drivers from 11.11 to 11.9 and 11.1 and still same problem.
Also i will try oclhascat 5 and see what happens. If that doesn’t work i might just do a clean install of the OS system.
My guess is it might be a software problem or a driver issue. The other card i have XFX 5870 is a standard card and responds well 63c. But the expensive well made Asus 5870 and much longer in length gets as hot as my Kettle
Kind Regards
Share The Knowledge
Old 12-08-2011, 10:23   #1058 (permalink)
Member: 665113
Sonork: 100.1583029
Kind Regards
Share The Knowledge
what spacing have you got exactly between cards? 1 slot? 2 slots? NO-SLOTS AT ALL?
on this tweak edition asus 5870
you will only get more speed if your 5870 is dual gpu ASUS ROG ARES version , like one displayed in pics above, which is equivalent to speed of single 5970, but just 3 times more expensive. Then there is no way but just sell it and get yourself few 5970s and nice more powerfull PSU maybe then, there are no liquid cooling made for them, unless you contact Let us help you be cool! and ask them to fabricate custom one for you as I seen prototypes made by them for this specific card, which has later developed to 5970 with simplier hardware design and more stability/less pricey.
Yes , Single card configuration will run cooler no mater which setup you take, as primary card manages other cards part process , the primarry will tend to stay hotter.
oclhashcat-lite closes automatically to prevent your card from BURNING, there is temperature watchdog set in the program to terminate before 90+ degrees temp is reached to cool down the equipment and save your expensive hardware from dumping to trash bin!
Of course you can disable this protection feature or raise your temperature to desired level by adding in command line:
--gpu-watchdog=0 THIS WILL DISABLE TEMPERATURE LIMIT/OVERHEAT PROTECTION
--gpu-watchdog=100
THIS WILL RAISE TEMPERATURE TO 100C' , use these features carefully, you can lower or lift the gpu protection limits by altering the number.
Old 12-08-2011, 15:21   #1059 (permalink)
Member: 1649867
Hi, I need some Help with SL3 bruteforce
Here is the pc configuration
Computer:
Computer Type ACPI x64-based PC
Operating System Microsoft Windows Server 2008 R2 Enterprise
OS Service Pack Service Pack 1
Internet Explorer 9.0.8112.16421
DirectX DirectX 11.0
Computer Name TOOL
Date / Time 2011-12-07 / 08:40
Motherboard:
CPU Type DualCore Intel Core i5 650, 3200 MHz (24 x 133)
Motherboard Name Asus P7H55-M Pro (2 PCI, 1 PCI-E x1, 1 PCI-E x16, 4 DDR3 DIMM, Audio, Video, Gigabit LAN)
Motherboard Chipset Intel Ibex Peak H55, Intel Ironlake
System Memory 3920 MB (DDR3-1333 DDR3 SDRAM)
DIMM1: A-Data 2 GB DDR3-1333 DDR3 SDRAM (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz) (5-5-5-14 @ 380 MHz)
DIMM2: Kingston 99U5474-007.A00LF 1 GB DDR3-1333 DDR3 SDRAM (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
DIMM4: Kingston 99U5474-007.A00LF 1 GB DDR3-1333 DDR3 SDRAM (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
BIOS Type AMI (07/22/10)
Communication Port Communications Port (COM1)
Display:
Video Adapter Intel(R) HD Graphics (1777180 KB)
3D Accelerator Intel GMA HD
Monitor Generic PnP Monitor [NoDB] (H9LZ201377)
Graphics Processor Properties:
Video Adapter Intel Havendale/Clarkdale Processor - Integrated Graphics Controller
GPU Code Name Ironlake (Integrated 8086 / 0042, Rev 18)
GPU Clock 733 MHz
BIOS Settings (ATK):
CPU PLL 1.800 V
CPU Voltage 1.24375 V
DRAM Bus Voltage 1.600 V
iGPU Voltage 1.1500 V
IMC Voltage 1.100 V
PCH 1.050 V
CHA DATA 0.500 X
CHB DATA 0.500 X
BCLK Frequency 133.00 MHz
iGPU Frequency 733.27 MHz
iGPU NOS Frequency 733.27 MHz
DRAM Frequency 1333 MHz
iGPU Mode Max Battery Life
CPU rated ratio 24x
CPU Ratio 24x
iGPU State 1x
Video Adapter Properties:
Device Description Intel(R) HD Graphics
Adapter String Intel(R) HD Graphics
BIOS String Intel Video BIOS
Chip Type Intel(R) HD Graphics (Core i5)
DAC Type Internal
Driver Date 3/30/2010
Driver Version 8.15.10.2104
Driver Provider Intel Corporation
Memory Size 1777180 KB
Installed Drivers:
igdumd64 8.15.10.2104
igd10umd64 8.15.10.2104
igdumdx32 8.15.10.2104
igd10umd32 8.15.10.2104
BIOS Version Build Number: 1949 PC 14.34 11/30/2009 03:51:59
PCI Device 8086-0042 / 1043-8383 (Rev 18)
Process Technology 45 nm
Bus Type Integrated
GPU Clock 733 MHz
RAMDAC Clock 350 MHz
Pixel Pipelines 4
TMU Per Pipeline 1
Unified Shaders 12 (v4.0)
DirectX Hardware Support DirectX v10
Pixel Fillrate 2932 MPixel/s
Texel Fillrate 2932 MTexel/s
and Log2Cod calculator shows this error
GPU Selftest Started...
Trying salt 559
Failed to Try Salt -> dwProcResult != 0
GPU Selftest FAILED! Check drivers/GPU...
Critical Exception While Bruteforce: GPU didn't passed selftests... can't continue!
Plz, I need help, what can I do
Old 12-08-2011, 15:28   #1060 (permalink)
ptt
ptt's Avatar
Member: 348680
Please do some Search / Reading before ask
You Need a Compatible Video adapter ( ATI/AMD or NVIDIA )
Old 12-08-2011, 15:36   #1061 (permalink)
Member: 1649867
Ok, thanks, but I thought that with 730 Mhz will be enough,
So, nothing I can do with this card,??
Old 12-08-2011, 16:09   #1062 (permalink)
ptt
ptt's Avatar
Member: 348680
Is your "card" an ATI/AMD or Nvidia ?
Old 12-08-2011, 16:23   #1063 (permalink)
Member: 1649867
is a onboard video card, don´t worry ptt, i understand that i have to buy a new pc with a video card like ATI 6990 or similar in order to avoid problems, many thanks for your time, when i get the money i will ask you what kind of video card do you recomend me, sorry for my english, i speak spanish,
Many thanks again
Old 12-08-2011, 16:34   #1064 (permalink)
ptt
ptt's Avatar
Member: 348680
No necesitas comprar una PC nueva, a tu motherboard puedes instalarle una Placa de video como la Radeon HD 6990 ( o alguna de las listadas como compatibles )
ASUSTeK Computer Inc. - Motherboards- ASUS P7H55-M PRO
Tarjeta gráfica AMD Radeon
Te recomendaria que comieces a leer este hilo desde el primer post, y vas a ver que encuentras respuestas a practicamente todas tus preguntas.
Old 12-11-2011, 13:41   #1065 (permalink)
Member: 223166
2nd GPU Problem OCLHashcar 0.08
Hi
I have a problem with the speed of 2nd GPU in oclhashcat 0.08, the first GPU speed is 1450 and the second 180 when i don't connect a monitor. If i connect a monitor both speeds are the same (1450). I use a 6870 x2.
Any help??
Any "fake monitor" cheap solution??
Thanks
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
All 4 locks on 6110 steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 04-19-2010 02:44
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.72590 seconds with 13 queries
