Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
View Poll Results: add new gpu ati 6xxx in log to code
yes 442 91.70%
no 43 8.92%
Multiple Choice Poll. Voters: 482. You may not vote on this poll
Old 05-21-2012, 22:22   #1396 (permalink)
Member: 1286421
Thanks Meter: 18
Originally Posted by jakussi View Post
nvcuda.dll is missing
ifou use nvidia gpu install driver for nvidia gpu
Old 05-22-2012, 00:31   #1397 (permalink)
Member: 1747553
Sonork: camecana
Originally Posted by fox6666 View Post
If I have two super computer, how do I set up the hardware side.
Allow them to work together to achieve greater efficiency.
Please teach me, thanks very much.
pc1 6990x2
pc2 7970x2
you can calculate 50% on each computer
PC1
oclHashcat-lite32 --pw-skip=000000000000000 EA77BFEE313B79EF6CAFD9C5D47E1165C90C099C:003534020 498197900 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --outfile=353402049819791.cod
pause
PC2
oclHashcat-lite32 --pw-skip=500000000000000 EA77BFEE313B79EF6CAFD9C5D47E1165C90C099C:003534020 498197900 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --outfile=353402049819791.cod
pause
Old 05-23-2012, 00:32   #1398 (permalink)
Member: 1571557
Thanks Meter: 10
Re upstairs
Thank you, brother.
I give it a try.
If there is encountered a problem and ask again.
Old 05-23-2012, 00:48   #1399 (permalink)
Member: 1571557
Thanks Meter: 10
Carefully looked at the command, it seems to be two computers to work separately from it.
If one computer, find the results to another computer continues to work.
Old 05-24-2012, 01:08   #1400 (permalink)
Member: 1166423
Thanks Meter: 38
pc for unlock sl3
Can you write a configuration of the computer to unlock the nokia SL3
thanks
Old 05-24-2012, 22:53   #1401 (permalink)
Member: 1571557
Thanks Meter: 10
My computer configuration?
PC1 = HD6990 X 2
PC2 = HD7970 X 2
Old 05-24-2012, 22:58   #1402 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 13,976
better way is this one
PC1
oclHashcat-lite32 EA77BFEE313B79EF6CAFD9C5D47E1165C90C099C:003534020 498197900 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 200 --outfile=y:\Public\353402049819791.cod
pause
PC2
oclHashcat-lite32 EA77BFEE313B79EF6CAFD9C5D47E1165C90C099C:003534020 498197900 -1 09080706050403020100 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 200 --outfile=y:\Public\353402049819791.cod
pause
Where y:\Public is shared folder between the 2 servers.
using these lines the computer will go one onward and one backward: they must find the code anyway before they met. as well no problems if the speed of the computers is not the same.. the faster will do more work then the other one and they will finish always together
using the common folder will make the 2nd computer stopping once the 1st one found the code or vice versa
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 05-24-2012, 23:15   #1403 (permalink)
LIEREN's Avatar
Member: 917576
Sonork: QQ:366688456
Thanks Meter: 533
PC1 = HD6990 X 2
PC2 = HD7970 X 2
hi moulnisky sir
How to set up two computers connected together ? he want do this
b.r
lieren
The Following User Says Thank You to LIEREN For This Useful Post:
Old 05-24-2012, 23:29   #1404 (permalink)
moulnisky's Avatar
Member: 947561
Hi bro,
he should configure the lan, change the advanced lan setting and assign a drive letter to the shared folder
Not an hard job for who is used to manage windows
Alex
Old 05-24-2012, 23:37   #1405 (permalink)
LIEREN's Avatar
Member: 917576
Thanks Meter: 533
Originally Posted by moulnisky View Post
Hi bro,
Alex
haha hope he can get you the help~
b.r
lieren
Old 05-24-2012, 23:55   #1406 (permalink)
Member: 1571557
Thanks Meter: 10
Thank you, with the help of the masters.
Thanks a million
I went to try
br.
fox6666
Old 05-25-2012, 12:19   #1407 (permalink)
Member: 1571557
Thanks Meter: 10
Today I had a new problem. Again to ask the master.
If I calculate the power outage in the process, leading to not continue.
What command can be restored to the calculation of the past?
For example: the computer started working, I go to bed. Up in the morning, found that the computer stopped working, I do not know his work where.
At this point, I want to let the computer how to continue his unfinished work it?
Thank you
br
Old 05-25-2012, 15:12   #1408 (permalink)
Azhar Nazeer's Avatar
Member: 862582
Sonork: 100.1604840
Thanks Meter: 68
plz share your hardware configuration.
Old 05-25-2012, 15:24   #1409 (permalink)
moulnisky's Avatar
Member: 947561
Thank you
br
Just use the --restore option
if you made the BF using oclhashcat-lite32.exe then the command will be
oclhashcat-lite32.exe --restore
if you instead used oclhashcat-lite64.exe the command will be
oclhashcat-lite64.exe --restore
Alex
The Following 2 Users Say Thank You to moulnisky For This Useful Post:
Old 05-25-2012, 23:00   #1410 (permalink)
Member: 1451787
Thanks Meter: 6
oclhascat0.09 sl3
I oclhashcat 0.09 and I want to make many phone one after another can and how????
All 4 locks on 6110 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 04-19-2010 03:44
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 40 each 30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 06:46
i can unlock all nokia 5110/6110/6150 spterminator Main Sales Section 0 07-30-1999 04:05
all for GSM: http://fly.to/spear spear GSM Mobile Links 0 07-11-1999 23:01
Page generated in 0.47290 seconds with 10 queries
