07-11-2014, 10:20 | #1 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 801055 Status: Offline Thanks Meter: 20 | lumia 800 flashing fault (log) i tried to unlock my lumia 800 and that went wrong.... now i want to flash it with newest software but i cant.... i boths up like it shuold and i can use it like normal... i have NOT formatted the disk but it after my try to unlock it it comes with i need to format the disk when i try to flash it. but when i try to flash it this happens : Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0002DB5 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Initializing security card... Card Serial Number: DC0000F8 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,91v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,80v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,82v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,75v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is ACTIVATED! Avaiable Physical Memory: 3.1023GB Avaiable Virtual Memory: 1.741GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work [USB-sammensat enhed]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! MCU Version 1750.0823.8852.12430 MCU Date N/A Product Lumia Series (Nokia Lumia Series) Manufacturer (c) Nokia IMEI 352826051225631 Mastercode 6166564513 Public ID F2B17A9C8252D74665072923613B19EF Product Code 059N3Z6 Basic Product Code 059K478 Module Code 0205051 NCSd Version 1.9 HW Version 112.1402.2.4 SW Version 1750.0823.8852.12430 PSN Number 0114EEBAB ESN 00000000 WLAN MAC 3C363DC5E7020000 BT ID 3C363DC72EF6000000000000 Battery Life 43% Battery Cycle Count 65535 Battery Temperature 33.5C Battery Voltage 3857mV Battery Flags 296 Battery Standby Current -8mA Battery Max Load Current -844mA Battery Health 842 Battery Average Current 116mA Battery Remaining Capacity 520mAh Battery Full Charge Capacity 1220mAh If phone is alive, It will be automatically swithced to OSBL mode. If software can't switch to OSBL mode, or phone is generally DEAD do folllowing: 1. Turn OFF device, wait 15 seconds afterwards 2. Eject USB cable, wait 10 seconds 3. Press and hold Volume-UP button 4. Insert USB Cable. OSBL should be booted. Booting CMT... [Nokia USB Connectivity]: WinUSB Port opened OK! Switching to RAW Mode... [Nokia USB Connectivity]: WinUSB Port opened OK! BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected. Failed to Boot CMT -> No compatible USB devices detected Prepare phone failed with message -> Failed to Boot CMT Process ESCO Image Failed -> Failed to Boot OSBL Failed to Flash WP7 -> Failed to Flash All ESCO Images |
