Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-07-2013, 12:01   #1 (permalink)
Member: 246072
Thanks Meter: 95
Post Your Successful Lumia 800 (with Usb)NO TP Unlock Log
Lumia 800 No TP rooted with cyclone and patch unlocked with another box
Great update, best of all is that phone isnīt warranty void
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.1.1155
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: XXXXXXXX
Time: 2012, wk01 / 2011, wk27
Box is activated
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is ACTIVATED!
Avaiable Physical Memory: 1.125GB
Avaiable Virtual Memory: 1.774GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
Lumia No TP Root Procedure Started...
If phone is alive, It will be automatically swithced to OSBL mode.
If software can't switch to OSBL mode, or phone is generally DEAD do folllowing:
1. Turn OFF device, wait 15 seconds afterwards
2. Eject USB cable, wait 10 seconds
3. Press and hold Volume-UP button
4. Insert USB Cable. OSBL should be booted.
Booting CMT...
[Nokia USB Connectivity]: WinUSB Port opened OK!
OSBL Details
Protocol: v1.0
Version: v256.4
Build: 10
Timestamp: 29-09-2011 14:38:56
OSBL Bootloader Ready
USB&UART Tracing set
RSA Signature Calculated for QCB Boot, Writing...
OSBL Certificate Details
Magic:		WP70
Version:		0
Signer Server ID:	0x98031573
Signer Timestamp:	28-09-2011 14:52:12
Signer S/N:	23
Signer User ID:	10046114
Auth Level:	Care
Data Encryption:	0
Image Index:	0
Asic Index:	0
Type:		Image Write
Hashtable Parsed OK
Certificate Accepted
[ASIC 0, Storage 4,1] Writing 850.552kB @ 0x000000000007D200
Write taken 1.139s (Average speed: 6117,31kBits/s)
Restoring Modem from BACKUP_RAMFS_IMAGE...
Restore OK
Restarting
Old 08-07-2013, 12:03   #2 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,174
Lumia 800 (with Usb)NO TP Unlocked
Root with Cyclone
Unlock with NSS
The Following 10 Users Say Thank You to NADEEM GONDAL For This Useful Post:
Old 10-06-2013, 16:11   #3 (permalink)
Member: 1919721
Thanks Meter: 10
Try to
Originally Posted by NADEEM GONDAL View Post
Instructions:
1. Go to WP7 -> Simlocks Tab
2. Select Product and click ROOT!
3. Press and hold vol+ ke plug USB cable install driver
It should go this way:
4. Download and install NSS from this link
http://forum.gsmhosting.com/vbb/f528...4/#post9632072
ASupose to download something??
Where is this?
Old 10-28-2013, 02:17   #4 (permalink)
Member: 1979008
Thanks Meter: 110
give out a working site where to downlord NSS
Old 11-16-2013, 11:32   #5 (permalink)
Member: 91747
Enter Pin Code - 00000000
Bad PIN CODE !!!
And what ???
Old 12-26-2013, 14:56   #6 (permalink)
Member: 504184
Thanks Meter: 54
I unlocked Lumia 800 with NO TP using cyclone box
Booting CMT...
[USB Composite Device]: WinUSB Port opened OK!
Switching to RAW Mode...
OSBL Details
Protocol: v1.1
Version: v257.6
Build: 12
Timestamp: 17/02/2012 13:40:05
Magic: WP70
Version: 0
Signer Timestamp: 28/09/2011 14:52:12
Signer S/N: 23
Auth Level: Care
Data Encryption: 0
Image Index: 0
Asic Index: 0
Type: Image Write
Hashtable Parsed OK
Write taken 1.123s (Average speed: 6204.47kBits/s)
Restore OK
Restarting MCU...
Rooting Finished!
Looking for phone...Not found!
Can't read IMEI, backup will be skipped.
Looking for NAND disk...Done.
Trying to parse partition tables...Done.
FAT16 absolute address: 0x001F4200
FAT16 partition size: 0x0927C000
Searching locations...Done.
Found 1 locations to modify, processing:
Reading sector 0...Done.
Modify sector...Done.
Updating sector...Done.
Modification written. Please follow those steps:
1. Disconnect USB cable and remove the battery
2. Insert not supported simcard and power on the phone
3. If asked for PIN code, enter 00000000
4. If asked for PUK code, enter 0000000000
5. After unlock success, connect to USB, enter OSBL mode
6. Press Unlock again to restore the phone to original
Old 02-20-2014, 17:11   #7 (permalink)
Member: 2132644
where is link for download please
Old 02-21-2014, 05:55   #8 (permalink)
Member: 482140
Old 03-14-2014, 06:17   #9 (permalink)
Member: 2147390
Am i blind???
Where is the NSS Pro download link?
Old 03-16-2014, 09:29   #10 (permalink)
Member: 1014710
Thanks Meter: 27
here NSS https://drive.google.com/file/d/0B5o...it?usp=sharing
Old 07-02-2014, 18:48   #11 (permalink)
Member: 663979
Hi I now inserted wrong sim card and it says Enter Pin. I entered pin (00000000) 10 x times now its asking for puk code.
Old 07-04-2014, 21:03   #12 (permalink)
Member: 1040508
Thanks Meter: 4
I have got the same, I entered 10 timex (00000000) pin code, and after it 32 times puk code and now it blocked... ****in' ****...
Old 07-11-2014, 16:38   #13 (permalink)
Member: 390671
Thanks Meter: 29
If it doesnt work, you just need to go over the unlock process again and it will work
Page generated in 0.34565 seconds with 7 queries
