06-18-2011, 23:08 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 389266 Status: Offline Thanks Meter: 17 | Problem 6210s-1 simlock problem Code: Started Phone Security Analysis... MCU Version V ICPR71_09w12.7 MCU Date 19-06-09 Product RM-367 (Nokia 6210 Navigator) Manufacturer (c) Nokia IMEI 352914027786629 Mastercode 146321267 Reading Security Block... Security block OK and saved to "RM-367_352914027786629_18062011_043409 p.m..SecurityBlock.PM" Step 1 : Testing SIMLOCK -- SIMLOCK PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. -- SIMLOCK PROBLEM -- Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) Additionaly, Checking HWC/CCC Certs... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 10E00104C9710052BF1AB68F85A01C7FF8647906 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 4AA07663215C623237BF8A43EC71D55819B7DC6E APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits HWC Looks OK! CCC Looks OK! Restarting MCU... -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "10E00104C9710052BF1AB68F85A01C7FF8647906.C0000ADE" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Analyze finished! Code: "10E00104C9710052BF1AB68F85A01C7FF8647906.C0000ADE" Exists, That is good... MCU Version V ICPR71_09w12.7 MCU Date 19-06-09 Product RM-367 (Nokia 6210 Navigator) Manufacturer (c) Nokia IMEI 352914027786629 Mastercode 146321267 Reading Security Block... Security block OK and saved to "RM-367_352914027786629_18062011_045944 p.m..SecurityBlock.PM" SX4 Status: Not authorized (74) Started mutual authenthication with card... Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [1,0] Written, Length: 114 bytes, Status: Not accepted, Code: 19 [1,2] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,4] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,5] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,6] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,8] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,13] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,16] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,18] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,20] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,22] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,23] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,24] Written, Length: 84 bytes, Status: Not accepted, Code: 19 [1,25] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,26] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,28] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,29] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,31] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,33] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,34] Written, Length: 80 bytes, Status: Not accepted, Code: 19 [1,35] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,37] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,39] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,44] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,45] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [309,1] Written, Length: 2 bytes, Status: Not accepted, Code: 19 [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,5] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,7] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,8] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,17] Written, Length: 12 bytes, Status: Not accepted, Code: 19 Write PM Finished, Record written OK: 0, Record written NOT OK: 33 I can not write a pm, it seems that not authenticate sx4 I have tried many times took several days to help this problem thank you very much for your help sorry bad my english luck Last edited by ptt; 06-24-2011 at 22:57. Reason: add CODE tag |
06-19-2011, 03:55 | #3 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,125 | First try what ptt said.. If still same then follow this thread http://forum.gsmhosting.com/vbb/f528...-rap4-1290576/ |
06-24-2011, 16:47 | #4 (permalink) |
Member: 389266 Status: Offline Thanks Meter: 17 | thanks for answering friends * problem detected = unstable mode local * solution 1 - flash file eno 2 - full flash 3 - cyclone box + authsx4 + pm 1-309 4 - full phone thanks team ******************************************* Now I have the same problem E71x unstable local mode + phone star-up failed contact the retailer I can not find your file for ENO rm-462 e71x help me thanks |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
