Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2007 Location: Mexico
Member: 527046 Status: Offline Thanks: 1,154
| problem with C5-03.2 hi cyclone team. i have problems to repair this model. i have rpl and pm backup. but i have problems to repair it. this is security analysis log: Code: Started Phone Security Analysis... MCU Version V ICPR82_11w25.7 MCU Date 05-12-11 Product RM-697 (Nokia C5-03) Manufacturer (c) Nokia IMEI 355934046605250 Mastercode 663311270 Reading Security Block... Security block OK and saved to "RM-697_355934046605250_21062012_11209.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) Additionaly, Checking HWC/CCC Certs... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00000C35 CMT_EM_ASIC_ID: 00000C30 CMT_PUBLIC_ID: 25D0011945DA03447A5F972F452B32CF60CD09B0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.48.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000231, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 78E50A8766EC9CD99D190EEA9676987905B09588 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits !!!!! HWC IS CORRUPTED, ANOTHER REASON OF SECURITY TEST FAILED !!!!! !!!!! CCC IS CORRUPTED, ANOTHER REASON OF SECURITY TEST FAILED !!!!! Restarting MCU... -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "25D0011945DA03447A5F972F452B32CF60CD09B0.B0000A16" Exists, That is good... Checking SUPERDONGLE... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Analyze finished! Warning: At least one Certificate Test failed, but no Local Generic RPL File found, Put it in SX4 folder. Code: SX4 Authorization / SD Repair Procedure Started.... Failed to obtain Phone Unique Data, Will use Server and Original Card MCU Version V ICPR82_11w25.7 MCU Date 05-12-11 Product RM-697 (Nokia C5-03) Manufacturer (c) Nokia IMEI 355934046605250 Mastercode 663311270 SX4 Status: Not authorized (74) Started mutual authenthication with card... Cyclone Server (2.0.0.42), Cyclone Box Team 2008-2012 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Disconnected from Cyclone Server Failed to Authorize SX4 -> Phone not accepted calculated Data 1 please can you help me with this phone. thanks in advance |
| | #2 (permalink) | |||
| hi again, now the phone can power on, and the imei is ok and here's the security analysis log: Quote:
and the phone hasn't field 1 and 309 too. but the problem is with superdongle repair i always got this: Quote:
thanks in advance | |||
| | #5 (permalink) |
| here is info's log: Code: MCU Version V ICPR82_11w25.7 MCU Date 05-12-11 Product RM-697 (Nokia C5-03) Manufacturer (c) Nokia IMEI 355934046605250 Mastercode 663311270 IMEI Spare 3A55390464062505 IMEI SV 3355390464062505F7000000 PSN CPM695571 Product Code 059G3H9 PSD 0000000000000000 LPSN 0 WLAN MAC D4C1FC27C7F8 APE SW V 22.1.007 APE Variant V 22.1.00722.1.00722.1.007 APE HW 256 APE ADSP 256 APE BT HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. RETU 35 TAHVO 00 AHNE 11 HW 3292 RFIC |Vapaus_6.5 | Mikki_1.1 DSP 11w48 Simlock Server SIMLOCK SERVER Simlock Key 3340309996332460 Simlock Profile 9000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 73002F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 72207F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 74807F Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 73212F Simlock [6,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ E000 Data: 740FFF Simlock [7,1] State: CLOSED Type: MCC-MNC Data: 33403F Simlock [8,1] State: CLOSED Type: MCC-MNC Data: 70403F Simlock [9,1] State: CLOSED Type: MCC-MNC Data: 70604F Simlock [10,1] State: CLOSED Type: MCC-MNC Data: 71030F Simlock [11,1] State: CLOSED Type: MCC-MNC Data: 71402F Simlock [12,1] State: CLOSED Type: MCC-MNC Data: 21402F btw, i have problems to write the rpl backup. i got this: Code: Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Handling as SL3 Simlock Data Handling as SIMLOCK1 Format Reading Security Block... Security block OK and saved to "RM-697_355934046605250_21062012_121753.SecurityBlock.PM" 15 Digits NCK Found Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key ACCEPTED OK ! Writing WMDRM PD Data... Failed to Write RPL File -> Phone is not responding for Superdongle Request |
| | #6 (permalink) | |
| i still have the problem with this phone model :S after erase, and flash the device i try to write rpl. but always i got this error: Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
