Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Sep 2010
Member: 1390215 Status: Offline Thanks: 2
| Problem flashing N70 rm-84 (Solved) Hello i try to flash N70 RM-84 but dont power on at finish. i use some diferent flash files from navfirm. rm84_50609201.c0 RM84_50609201.V01 Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.03, (Jun 1 2012 21:15:43, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C00034F7 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40 Initializing security card... Card Serial Number: DA000209 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.08v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.78v PASSED VBAT Voltage 1.42v PASSED VBAT Voltage 4.95v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 99 Avaiable Physical Memory: 3.1023GB Avaiable Virtual Memory: 1.803GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: EC842ECBBE2E9F56C2160FD8EC94E2FD810718E7 APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_BOOT_ROM_CRC: AB5E4ADB APE_SECURE_ROM_CRC: 27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 0140010BD46C5A51EC0A6E611B8585C017A76E51 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! Searching for BootCode: Single Line 8Bit RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: Single Line 8Bit FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Searching for BootCode: Single Line 8Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x0098003600A500C0, Toshiba, NAND Requested Algorithm: OMAP1610 GBBM-1.8.1 ALG (APE) FlashContent[0,APE]: 00020000000600000000000000000000, NAND Searching for BootCode: Single Line 8Bit FlashChip 0x00980036 (Toshiba), Size: 64MBytes, VPP: 21V h3_sam_nand_gbbm.fg, Type: Algorithm, Rev: 0.1.33.0, Algo: OMAP1610 GBBM-1.8.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Flashbus Write baud set to 5.0Mbits Storing NPC... CMT CCC Not Found CMT HWC Not Found Storing VARIANT... CMT PARTNERC Not Found Processing APE Part... Storing Product Code... Storing PSN... Storing HWID... APE NPC Not Found APE CCC Not Found APE HWC Not Found APE VARIANT Not Found APE PARTNERC Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing rm84_50609201.c0 (CMT)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: EC842ECBBE2E9F56C2160FD8EC94E2FD810718E7 APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_BOOT_ROM_CRC: AB5E4ADB APE_SECURE_ROM_CRC: 27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 0140010BD46C5A51EC0A6E611B8585C017A76E51 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! rm84_50609201.c0, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1610 GBBM-1.8.1 ALG Searching for BootCode: Single Line 8Bit RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: Single Line 8Bit FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0052AB0D, NOR EraseArea[0,CMT]: 0x006A0000-0x006BFFFF, NOR EraseArea[0,CMT]: 0x006DF000-0x006EFFFF, NOR EraseArea[0,CMT]: 0x00700000-0x007EFFFF, NOR Waiting 320s for erasure finish... Erase taken 45.271s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Skipping CMT PAPUBKEYS Certificate (already sent)... Programming Status OK! All blocks written OK! Time taken 40.217s Flashing Speed: 6500.99 kBit/S Restarting MCU... Processing rm84_50609201.c0 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: EC842ECBBE2E9F56C2160FD8EC94E2FD810718E7 APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_BOOT_ROM_CRC: AB5E4ADB APE_SECURE_ROM_CRC: 27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 0140010BD46C5A51EC0A6E611B8585C017A76E51 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! rm84_50609201.c0, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1610 GBBM-1.8.1 ALG Searching for BootCode: Single Line 8Bit RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: Single Line 8Bit FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Searching for BootCode: Single Line 8Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x0098003600A500C0, Toshiba, NAND Requested Algorithm: OMAP1610 GBBM-1.8.1 ALG (APE) FlashContent[0,APE]: 00020000000600000000000000000000, NAND Searching for BootCode: Single Line 8Bit FlashChip 0x00980036 (Toshiba), Size: 64MBytes, VPP: 21V h3_sam_nand_gbbm.fg, Type: Algorithm, Rev: 0.1.33.0, Algo: OMAP1610 GBBM-1.8.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x00000000-0x0000FFFF, NAND EraseArea[0,APE]: 0x00010000-0x0001FFFF, NAND EraseArea[0,APE]: 0x00020000-0x000203FF, NAND EraseArea[0,APE]: 0x00050000-0x03ECFFFF, NAND Waiting 320s for erasure finish... Erase taken 5.70s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing APE KEYS Certificate... Writing APE X-LOADER Certificate... Writing APE PRIMAPP Certificate... Writing APE SOS+LOADER Certificate... Writing APE SOS+XZIP Certificate... Writing APE PASUBTOC Certificate... Writing APE PAPUBKEYS Certificate... Skipping APE PAPUBKEYS Certificate (already sent)... Writing APE SOS*CORE Certificate... Programming Status OK! All blocks written OK! Time taken 88.141s Flashing Speed: 2966.28 kBit/S Restarting MCU... Processing RM84_50609201.V01 (CMT)... Processing RM84_50609201.V01 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: EC842ECBBE2E9F56C2160FD8EC94E2FD810718E7 APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_BOOT_ROM_CRC: AB5E4ADB APE_SECURE_ROM_CRC: 27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 0140010BD46C5A51EC0A6E611B8585C017A76E51 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! RM84_50609201.V01, Type: Flash Image, Algo: BB5, OMAP1610 GBBM-1.8.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: Single Line 8Bit RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: Single Line 8Bit FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Searching for BootCode: Single Line 8Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x0098003600A500C0, Toshiba, NAND Requested Algorithm: OMAP1610 GBBM-1.8.1 ALG (APE) FlashContent[0,APE]: 00020000000600000000000000000000, NAND Searching for BootCode: Single Line 8Bit FlashChip 0x00980036 (Toshiba), Size: 64MBytes, VPP: 21V h3_sam_nand_gbbm.fg, Type: Algorithm, Rev: 0.1.33.0, Algo: OMAP1610 GBBM-1.8.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x01DE0000-0x028FFFFF, NAND EraseArea[0,APE]: 0x02900000-0x03ECFFFF, NAND Waiting 320s for erasure finish... Erase taken 2.652s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 33.509s Flashing Speed: 2145.02 kBit/S Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 08-16-1999 12:20 |
| HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 07-16-1999 00:44 |
| 5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 07-07-1999 12:27 |
