Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 02-15-2010, 23:28   #1 (permalink)
Member: 1230268
Sonork: 100.1611300
problem with my box [SOLVED]
hi! all
The problem I have is that the cyclone box gives this error when actulice software 1.0.0.8552. the error is as follows.and the four LEDs are on the box
Old 02-15-2010, 23:31   #2 (permalink)
ptt
ptt's Avatar
Member: 348680
Click "Yes", you need to update your Box FW to v01.21 ( your box have v01.16 ).
Old 02-15-2010, 23:48   #3 (permalink)
Member: 1230268
Sonork: 100.1611300
I did the procedure, click on YES and he says this.
http://img191.imageshack.us/content_...espuesdesi.jpg
http://img33.imageshack.us/content_r...96/4ledson.jpg
again says that box is old and needs firmware be upgraded to v01.21, click yes to proceed with upgraded. I clik yes again and says it has failed Initialization -> No connection was established, or box is not in needed mode. the 4 leds of the box is on.
Old 02-15-2010, 23:55   #4 (permalink)
ptt
ptt's Avatar
Member: 348680
Close the DCT4/WD2/BB5 soft, unplug the box, replug the box ( check if see "Connected [Bootloader Mode]" at the bottom part of the soft ) then go to Box Maintenance and update the FW.
Old 02-16-2010, 00:15   #5 (permalink)
Member: 1230268
Sonork: 100.1611300
Cyclone software to 1.0.0.8340 and says,
Nokia Service Tool Initialization Started DCT4/WD2/BB5, Engine Revision: 1.0.0.8340
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box ...
Box Firmware: V01.16 Cyclone Nokia Application (Jan 25 2010 02:27:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application
Box Serial Number: C000256A
HW Revision: A Suitable for: Production, Case: Plastic Case First, MCU Manufacture Time: 2009, wk27
Initializing security card ...
Card Serial Number: D4000321
Card Firmware Revision: 0109
Initialization has failed -> Security Card is expired.
and when I click on Maintenance Box says:
Box Maintenance procedure started at 18:16:41
Bootloader: Cyclone Secure Bootloader v2.10, (Dec 5 2009 23:39:04), Type: Signed Production Application
Service Tag: 47520B59A5787EDB1940AEF2C198D2DC
Connecting to Cyclone Server
Cyclone Server (1.0.0.589), Cyclone Team Box 2008, 2009, 2010 - Ready.
Info Box ========= =========
Box SN: C000256A
Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty
Box registration status: Registered OK
Paired Card SN: D4000321
First Name: Marvin
Surname: Menendez
Nickname: crazy
Address: Ocotepeque Honduras
Country: Ocotepeque
E-Mail: c.razy32 @ hotmail.com
Reseller: Busntech, Portugal
Warranty Start Date: 2009-11-10
Warranty Period (months): 6
Warranty Stop Date: 2010-05-10
Warranty active: Yes
Updating Security Area ...
Skipped Update Security Area, Not allowed
Main Firmware Updating ...
Skipped Main Firmware Update, Not allowed
Secure Bootloader Updating ...
Secure Bootloader Update Skipped, or Not allowed not needed
Disconnected from Cyclone Server
Maintenance finished successfully Box
Old 02-16-2010, 00:30   #6 (permalink)
ptt
ptt's Avatar
Member: 348680
To solve:
Go to "Card manager" and do a "Fill credits"
The Following User Says Thank You to ptt For This Useful Post:
Old 02-22-2010, 18:15   #7 (permalink)
Member: 1230268
Sonork: 100.1611300
Question
To solve:
thanks for your help.
but do what it says and says this.
and when I click on dct4/wd2/bb5 this other problem.
I can do?
Old 02-22-2010, 18:31   #8 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Pased the infos to be fixed on the server.. when ready I'll let you know so you can update yopur box firmware again
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 02-22-2010, 20:57   #9 (permalink)
Member: 1230268
Sonork: 100.1611300
Alex
I will be very aware of your notice.
Old 02-23-2010, 10:33   #10 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Update your box now from Box maintance
Alex
Old 02-23-2010, 16:47   #11 (permalink)
Member: 1230268
Sonork: 100.1611300
thanks solved my problem.
Old 02-23-2010, 16:49   #12 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
You are welcome
Alex
problem with my box now samsung serie z in my shell kakaomar Z3X-Team Products 1 02-04-2010 16:11
problem with my box !! [ Solved ] abdel-27 Cyclonebox 6 01-24-2010 10:37
Problems with new box...[SOLVED] Bertie*#06# FuriouS TeaM Products 3 06-20-2009 06:54
I have some problem with my box activate. mobile_2003 UST Pro II 1 01-16-2006 20:31
please i have thise problem with my box if i flashed 1600 1110 2600 with latest flas gsm4libya UFS2 + UFS3-Tornadoflasher 3 01-07-2006 13:15
Page generated in 0.40838 seconds with 11 queries
