Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 06-29-2009, 12:42   #1 (permalink)
Member: 309128
problem nokia 6500s aftre unlock contact service
problem in cyclone after unlock contact service
BB5 Unlock Started...
MCU Version V 06.60
MCU Date 07-03-08
Product RM-240
Manufacturer (c) Nokia
IMEI 352027022142969
Mastercode 17212744
Simlock Server SIMLOCK SERVER
Simlock Key 2081000000000000
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 20810F
Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 64710F
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 2060020F405402549DAF5DDCDE1B9F6CA3EB446C
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_ROM_ID: 273F6D55DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 4.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: A69838E8C5F20150E64E2E6E06DE6E50B26B593F
APE Boot skipped on user request
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support...
Restarting MCU...
Booting RAP...
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Received Security Block OK !
Bypassing SX4...
Booting RAP...
Box VPP disabled
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Writing Security Block...
Writing Simlock Key...
SP Accepted, doing reset to update block...
Booting RAP...
Box VPP disabled
Restoring NPC...
Restarting MCU...
SX4 Bypass Finished
MCU Version V 06.60
MCU Date 07-03-08
Product RM-240
Mastercode 17212744
Simlock Key 0010100000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: OPENED Type: MCC-MNC Data: 00101F
Unlock finished!
plz help me ???
Old 06-29-2009, 13:03   #2 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
write pm back up ....and phone should OK
Post reasult plz
BR,
Old 06-29-2009, 13:21   #3 (permalink)
Imran Bhatti's Avatar
Member: 266874
Sonork: 100.1581444
same like u i face this problem today but i have backup of pm so wrote it back the phone was back in normal position.
Old 06-29-2009, 13:29   #4 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
did you update the firmware and answered yes when doing the unzip of the update it asked to overwrite?
Please have a check at both and remember to use the yellow adaptor and if you have any a good solution for the power and / or Bsi problem like the TMA adapter or similar.
Alex
Old 06-30-2009, 05:56   #5 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Its really strange i never ever get Contact service After Unlocking any Supported BB5 phones...
Only Trick is do it in proper way with correct cable adapter and Needed Mode
Old 07-02-2009, 04:32   #6 (permalink)
Member: 327741
bb5 Contact service
donload here 100%
http://www.ziddu.com/download/543389...RRRPL.rar.html
Old 07-09-2009, 17:33   #7 (permalink)
Member: 309128
no same problem thankssss
Old 07-09-2009, 22:36   #8 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Oh, believe me it's almost not possible, however if u occur such problem jiust write Unlock PM again and Unlock again...
Nokia 6500s v59.60 contact service plz help me hibba MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 12-06-2009 10:01
///// Nokia 6500s RM-240 Contact Service Repaired sucessfully with UB //// Fiton Universalbox 1 12-01-2009 14:30
nokia 6500s aftre flash contact service espoir1283 Cyclonebox 7 06-24-2009 22:27
nokia 6500s after unlock contact service prem2007 Nokia Base Band 5 ( BB-5 ) 0 05-01-2009 12:37
6500 after unlock contact service iyass Genie Universal 17 03-28-2009 22:24
Page generated in 0.35667 seconds with 11 queries
