09-17-2009, 21:00 | #32 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Ok.. now we know where is the problem.. I must do some tests but i can't do them before tomorrow morning when i'll be in my workshop. I'm sorry but I thing for tonight we can stop BR Alex |
09-17-2009, 22:32 | #35 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16943 Status: Offline Thanks Meter: 35 | hi i can open a new post and i'm sorry but is a little question. is there any way when i unlock bb5+ to stop the unlock secuence for i can input the code #7 manually to the phone? thanks |
09-20-2009, 23:03 | #40 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | You are wellcome.. at least now i know how to move if it happens again.. learned a lot from this experience. BR Alex Last edited by moulnisky; 09-20-2009 at 23:19. |
The Following User Says Thank You to moulnisky For This Useful Post: |
09-21-2009, 01:53 | #41 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: Somewhere in the World Age: 54
Member: 9848 Status: Offline Thanks Meter: 144 | Quote:
Worked with E71 and E51 without any problem. | |
09-21-2009, 09:28 | #43 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | If you have all the back-up as suggested in the 1st post of this thread and a good TMA adapter or similar tool I can give you the full procedure to fix it BR Alex |
09-21-2009, 10:43 | #44 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | As requested by Pm I put here the full procedure to get out the 5800 (Should work as well with the N85 using obviously the proper ENO file) from the WD in the procedure in the 1st Post goes wrong for any reason. It is a cross-flash solution so, please, be carefull in doing it following the steps one by one as suggested. The condition to do the job are: a) the mobile must be already with the firmware 30 or 31 and working but with watch dog problem and the unlocking code calculated must be keps in a side b) you must have the full PM back-up of the mobile, all the certs, the RPL from Phone and ready a full PM120 and 308 of the mobile in original state plus an RPL made using the function "create rpl from PM" of Cyclone. If you have all this things and obviously a Cyclone box you can go on.. if not don't try!!!! c) You may need a TMA adapter to do the job.. if you don't have it just leave. ok. let's start downloading this file which has inside all the files we need to do the job http://rapidshare.com/files/28293637...covery_kit.zip and unzip it in the folder where we normal keep the firmwares with the final path \RM-346\ (Sample c:\Program files\Nokia\Phoenix\Products\RM-346\) step 1: flash the mobile with the erase file 5800_Erase_256MB_kashi4gul with "Skip APE" Thicked. once you erased the mobile do check flashing bus to see if you can read the mobile on the fbus.. if not connect your tma adapter and add 2,2Kohm (Switch 2 ON all the others OFF) unplug the cable and plug it again and retry to check the flashing bus step 2: flash the mobile as E71 v300 product code 0559569 with "skip APE" thicked ONLY COR and PPM. the mobile now should be readable and you can see the infos with damaged imei as you are working on a RM-346 step 3: write the PM 120 and 308 you have from the original back-up step 4: flash it again with the 5800 firmware V30 or 31 was in origin in the mobile (Note: if you are trying to recover a mobile and flash it again with the version V20 or V21, "Downgrade" must be thicked.) step 5: write back all the certs step 6: write back the RPL of the security we made using the function "create rpl from PM" if you now read the infos in the mobile the logs will be perfect with the mobile locked again as before step 7: go in the tab BB5 security and click on sx4 auth.. the mobile should get the sx4 auth without any problem step 8: go in the tab common/info, SX4 bypass NOT THICKED and click on write PM selecting as pm the file RM-356_N5800_no120_no308.pm you found in the zip file. Job done.. you can connect the battery back and after the mobile starts input the unlocking code, you put in a side before, using the mobile keyboard. BR Alex Last edited by moulnisky; 10-07-2009 at 18:51. |
The Following 43 Users Say Thank You to moulnisky For This Useful Post: |
09-21-2009, 11:10 | #45 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Bucharest, Romania Age: 39
Member: 857353 Status: Offline Thanks Meter: 14 | Alex, it is necessary to write files related to the same product code? I'm asking you that because for some version you don't find some product codes! I mean I have 5800 with 30 firmware and for that firmware I can't find files for that product code! |
The Following User Says Thank You to nunu.gabriel For This Useful Post: |
Nokia 5800 XM RM-356 firmware 30 and 31.0.101 - service manual | pitone02 | Nokia Base Band 5 ( BB-5 ) | 1 | 11-06-2009 23:03 |
Anybody unlocked N96 ver 30. without WD problem | harim_1981 | Genie Universal | 3 | 10-06-2009 05:52 |
Anybody unlocked N96 ver 30. without WD problem | harim_1981 | Genie Universal | 0 | 09-30-2009 17:08 |
Problems in Unlock 5800 - refuses password | johnete | Cyclonebox | 14 | 09-30-2009 13:16 |
n96 problem in unlocking | ..::Mobile Smoker::.. | Genie Universal | 3 | 03-20-2009 13:35 |
