Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 07-27-2012, 03:20   #2761 (permalink)
Member: 1488173
Thumbs up Nokia 6555 flashing 4 usb done !!
Full Flashing nokia 6555 4 usb succesfully !!!
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.04, (Jun 10 2012 18:37:23, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0006897
HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk48
Initializing security card...
Card Serial Number: D008006A
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage    4,86v    PASSED
MCU Voltage    3,29v    PASSED
Core Voltage    1,77v    PASSED
VBAT Voltage    0,01v    PASSED
VBAT Voltage    4,83v    PASSED
Box VPP disabled
VPP Voltage    0,04v    PASSED
Internal Box VPP Enabled
VPP Voltage    4,83v    PASSED
Box VPP disabled
VPP Voltage    0,02v    PASSED
External Box VPP Enabled
VPP Voltage    0,02v    FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 98
Avaiable Physical Memory: 1.1023GB
Avaiable Virtual Memory: 1.885GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Selecting USB Flashing Method...
Proceeding with Dead USB Mode
Press power-on shortly to run USB Boot ROM
[Nokia USB Flashing Generic]: Port opened OK!
Old ROM Detected
CMT_SYSTEM_ASIC_ID:    000000010000022600010006010C192101003000
CMT_EM_ASIC_ID:        00000295
CMT_EM_ASIC_ID:        00000B22
CMT_PUBLIC_ID:        26E001153754025410CC679577236D89E37ED29E
CMT_ASIC_MODE_ID:    00
CMT_ROOT_KEY_HASH:    BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC:    273F6D55
CMT_SECURE_ROM_CRC:    DFAAF68F
DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5
Sending RAW Loader...
Sending CMT UPDAPP Certificate and Data...
[Nokia BB5 ADL Loader USB Generic]: Port opened OK!
ADL Server Startup Confirmed OK!
Processing rm289__03.43.mcusw (CMT)...
rm289__03.43.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Started flash erase
EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x01380000-0x014FFFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR
Erase taken 51.875s
Writing all blocks...
Initializing TurboCache...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
All blocks written OK! Time taken 130.219s
Flashing Speed: 1142,65 kBit/S
Processing rm289__03.43.ppm_nat (CMT)...
rm289__03.43.ppm_nat, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Started flash erase
EraseArea[0,CMT]: 0x01500000-0x01BBFFFF, NOR
Erase taken 15.703s
TurboCache Loaded!
All blocks written OK! Time taken 40.734s
Flashing Speed: 1127,50 kBit/S
Processing rm289__03.43.image_n_attus (CMT)...
rm289__03.43.image_n_attus, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Started flash erase
EraseArea[0,CMT]: 0x01FC0000-0x03F9FFFF, NOR
EraseArea[0,CMT]: 0x01BC0000-0x01FBFFFF, NOR
Erase taken 99.266s
TurboCache Loaded!
All blocks written OK! Time taken 83.157s
Flashing Speed: 1123,57 kBit/S
Restarting CMT...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
[Generic Phone]: Port opened OK!
[Nokia 6555 USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version    V 03.43
MCU Date    16-11-07
Product        RM-289 (Nokia 6556B CLASSIC CABLE 6555)
Manufacturer    (c) Nokia
IMEI        359823011323708
Mastercode    3760562676
IMEI Spare    3A95280311237300
IMEI SV        3395280311237300F5000000
PPM        V 03.43, 16-11-07, RM-289, (c) Nokia, NAT
CNT        Content: ATT USA v1, 14-08-07, RM-289, (c) Nokia
PSN        MLE920720
Product Code    0553268
Module Code    0203197
Basic Product Code    0553267
PSD        0000000000000000
LPSN        0
RETU        15
TAHVO        22
AHNE        30
HW        5005
RFIC        17141715
DSP        GA_RAP_PB_2006_wk41v26_03
LCD        SEIKO
BT        06cc-P9.1
Simlock Server    SIMLOCK SERVER
Simlock Key    0010100000000000
Simlock Profile    8000000000000000
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Simlock [1,1]    State: OPENED    Type: MCC-MNC    Data: 00101F
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Last edited by ptt; 07-27-2012 at 22:00. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 07-28-2012, 10:00   #2762 (permalink)
gulshan-iqbal's Avatar
Member: 388033
Sonork: 100.1624864
Thumbs up N95 RM-159 Successfully Unlocked :-)
Initializing box...
Box Serial Number: C0005xxx
HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk23
Card Serial Number: D008xxxx
Card is activated
Box is activated
USB Voltage	4.75v	PASSED
MCU Voltage	3.28v	PASSED
Core Voltage	1.80v	PASSED
VBAT Voltage	1.34v	PASSED
VBAT Voltage	4.91v	PASSED
Box VPP disabled
VPP Voltage	0.04v	PASSED
VPP Voltage	4.97v	PASSED
Box VPP disabled
VPP Voltage	0.02v	FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Avaiable Physical Memory: 864.372MB
Avaiable Virtual Memory: 1.897GB
Avaiable Pagefile: 2.757GB
Booting CMT...
APE_SYSTEM_ASIC_ID:	24200705
APE_ASIC_MODE_ID:	00
APE_PUBLIC_ID:		E0F38F2241373D4957C30D03D271545B5FD5844A
APE_ROOT_KEY_HASH:	BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT_SYSTEM_ASIC_ID:	000000010000022600010006400C192101021103
CMT_PUBLIC_ID:		1B70000EEC6E0058F5B5F82BE68A008C46FBFD3C
CMT_ROOT_KEY_HASH:	CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC:	A8C1D671
CMT_SECURE_ROM_CRC:	3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x00012C7E00006921, AMD, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip 0x00012C7E (AMD), Size: 16MBytes, VPP: 9V
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.12.8.0, Algo: XSR 1.5
TurboCache Loaded!
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
MCU Version	V 06wk41v50.2
MCU Date	28-01-08
Product		RM-159 (Nokia N95)
IMEI		356996017916973
Mastercode	6675764535
IMEI Spare	3A65990671199607
IMEI SV		3365990671199617F4000000
PPM		21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
PSN		SJH436029
Product Code	0547869
Basic Product Code	0537959
LPSN		0
WLAN MAC	001CD45A46F1
APE Variant	21.0.01641.01
APE Test		rm159_eno_2007wk16v0.150
APE HW		1
APE ADSP	256
APE BT		HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.
RETU		15
TAHVO		22
AHNE		11
HW		5900j21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
PCI		j21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
UEM		21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
UPP		21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
RFIC		17141714
DSP		ICPR62_08w02j21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
LCD		21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
BT		21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
ADSP Sw		21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
ADSP DevID		21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
ADSP RevID		21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
AEM		21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
Flip MCUSW		21.0.01641.01k rm159_eno_2007wk16v0.150qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
Simlock Key	2341500000000000
Simlock Profile	0000000000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 23415F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 23415F
Auto Selecting Flash Files on User Request...
Product Code: 0547869
No Flash Datapackage installed for this Phone!
BB5 Unlock Started...
MCU Date	28-01-08
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Reading Security Block...
Security block OK and saved to "RM-159_356996017916973_7282012_105734 AM.SecurityBlock.PM"
"1B70000EEC6E0058F5B5F82BE68A008C46FBFD3C.C0005CBB" Exists, That is good...
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: RPL Calculation
Asking box to calculate RPL...
Received RPL from Box OK!
Writing Simlock...
Simlock ACCEPTED OK !
MCU Date	28-01-08
Simlock Key	2440700000000000
Simlock Profile	8000000000000006
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [1,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [1,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [1,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [1,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [2,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [2,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [2,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [2,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [3,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [3,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [3,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [3,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [3,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [4,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [4,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [4,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [4,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [4,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [5,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [5,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [5,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [5,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [5,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [6,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [6,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [6,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [6,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [6,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [7,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [7,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [7,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [7,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [7,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Unlock finished! Time taken 7.125s
Last edited by ptt; 07-28-2012 at 12:27. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 07-28-2012, 11:33   #2763 (permalink)
Gsm-Rocky's Avatar
Member: 1500648
Sonork: 100.1605046
Arrow Cyclone Box Nokia 110 (RM-827) USB Flashing Successfully
Here is the Screenshot:
http://img560.imageshack.us/img560/4...lonebox110.jpg
Here are the Logs:
If PC Can't detect any new device, probably your phone is erased. Do following if needed:
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
X-Gold: Ready, MCU ID Block: 1FB300020303010100FF
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Quantum_Bootloader_10.49_M1S1
[EBL] : Ready
Setting Baudrate to 6500000bps...
Baudrate Accepted (6500000bps)
Flash Chip 0x00898982, Intel, Size: 64MBytes
Processing "rm827__03.04.mcusw_ebl_psi.fls"...
Sending Certificate...
Certificate Accepted
Erasing 0x40000000-0x4001FFFF...
Flashing at 0x40000000...
Flashed 131072 bytes OK
Erasing 0x40040000-0x4005FFFF...
Flashing at 0x40040000...
Erasing 0x40060000-0x4015FFFF...
Flashing at 0x40060000...
Flashed 1048576 bytes OK
Erasing 0x40280000-0x41BBFFFF...
Flashing at 0x40280000...
Flashed 25952256 bytes OK
Erasing 0x43E20000-0x43E5FFFF...
Processing rm827__03.04.ppm_s3 (XGold2)...
Checking rm827__03.04.ppm_s3...
Flash file sorted Okay.
1 file(s) embedded into image.
Processing "package_s3.ppm_ebl_psi.fls"...
Erasing 0x41BC0000-0x421BFFFF...
Flashing at 0x41BC0000...
Flashed 4642128 bytes OK
Processing rm827__03.04.image_s3_059P3R0 (XGold2)...
Checking rm827__03.04.image_s3_059P3R0...
Processing "package_s3_059P3R0.image.fls"...
Erasing 0x421C0000-0x43E1FFFF...
Flashing at 0x421C0000...
Flashed 16646144 bytes OK
Erasing 0x43E60000-0x43F3FFFF...
[Nokia C2-00 USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version    V 03.04
MCU Date    20-04-12
Product        RM-827 (Nokia RM-827)
IMEI        353257050359008
Mastercode    742264562
IMEI Spare    3A35520705530900
IMEI SV        3335520705530900F2000000
PPM        V 03.04, 20-04-12, RM-827, (c) Nokia            , S3
CNT        Content: s3_059P3R0, V 03.04, 20-04-12, RM-827, (c) Nokia
PSN        9A02EE5AH
Product Code    059N2R0
Module Code    0205081
Basic Product Code    059K3X3
LPSN        0
HW        1100
RFIC        68
LCD        TPO
BT        19b5-22012
Asic        11
HW Signature    9EE19BB4AA84D854
Simlock Profile    800000000004000B
Simlock Aux    000B0000
Simlock IMEI    00003532570503590000
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Br.
Last edited by ptt; 07-28-2012 at 12:29. Reason: MOVE TO THE RIGHT TREAD - REMOVE [IMG] TAG TXT LOG IS ENOUGH & BETTER
The Following 2 Users Say Thank You to Gsm-Rocky For This Useful Post:
Old 07-29-2012, 22:31   #2764 (permalink)
kardel's Avatar
Member: 1391333
Smile Downgrade Nokia Sl3 USB (X2-01 Rm-709) Successfull Cyclone Box
Process steps to follow
1. - Backup RPL & PM (if you have another box apart from cyclone, also recommend making backup to other box and keep them in case something)
2. - Full Erase
3. - Flahs with the desired version
4. - Write PM
5. - Write RPL
6. - Again Write PM
7. - Repair SD to "Authorize / Repair SD Keys"
nothing better to explain that a video, here the video made by me which details the steps above ....
Cyclone Box - Downgrade Nokia SL3 via USB (X2-01 RM-709) - YouTube
if they have questions they can ask ....
luck and I hope they serve a lot ...
Greetings!
The Following User Says Thank You to kardel For This Useful Post:
Old 07-30-2012, 19:16   #2765 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Nokia 6700s RM-576: all back-ups, read hash and unlock done via USB
[Nokia 6700 slide USB Phonet]: Port opened OK!
MCU Version V ICPR82_10w18.4
MCU Date 25-05-10
Product  RM-576 (Nokia 6700 slide)
IMEI  354866045935513
Mastercode 106112213
IMEI Spare 3A45680654395501
IMEI SV  3345680654395531F3000000
PPM  256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
PSN  KEZ108850
Product Code 059B2H3
Module Code 0204314
Basic Product Code 0580659
LPSN  0
APE SW  033.014
APE Variant 033.014033.014.01.01033.014.318.01
APE Test  0.A28
APE HW  256
APE ADSP 256
APE BT  HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.
RETU  35
TAHVO  00
AHNE  11
HW  2004o256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
PCI  o256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
UEM  256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
UPP  256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
RFIC  |Vapaus_5.1 | Mikki_1.1
DSP  ICPR82_10w18.4
LCD  256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
BT  256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
ADSP Sw  256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
ADSP DevID  256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
ADSP RevID  256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
AEM  256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
Flip MCUSW  256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256i033.014j(#033.014033.014.01.01033.014.318.01u, @>/k0.A28¥$rm576_033.014_UPink003.000_prd
Simlock Key 2341000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23410F
Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23410F
Product Code: 059B2H3
Starting PM read in range 0-512...
[1] Reading 28 records
[1,0] Reading 114 bytes
[1,2] Reading 10 bytes
[1,4] Reading 110 bytes
[1,6] Reading 10 bytes
[1,7] Reading 214 bytes
[1,8] Reading 110 bytes
[1,13] Reading 10 bytes
[1,16] Reading 208 bytes
[1,18] Reading 208 bytes
[1,20] Reading 208 bytes
[1,22] Reading 16 bytes
[1,23] Reading 4 bytes
[1,24] Reading 84 bytes
[1,26] Reading 110 bytes
[1,28] Reading 10 bytes
[1,29] Reading 10 bytes
[1,31] Reading 208 bytes
[1,33] Reading 36 bytes
[1,34] Reading 376 bytes
[1,35] Reading 16 bytes
[1,37] Reading 4 bytes
[1,39] Reading 36 bytes
[1,40] Reading 16 bytes
[1,41] Reading 182 bytes
[1,42] Reading 4 bytes
[1,43] Reading 36 bytes
[1,44] Reading 182 bytes
[1,45] Reading 182 bytes
[2] Reading 1 records
[2,0] Reading 2080 bytes
[4] Reading 9 records
[4,1] Reading 1020 bytes
[4,3] Reading 10 bytes
[4,4] Reading 8 bytes
[4,5] Reading 8 bytes
[4,6] Reading 8 bytes
[4,9] Reading 5 bytes
[4,18] Reading 80 bytes
[4,19] Reading 4 bytes
[4,28] Reading 2 bytes
[6] Reading 1 records
[6,0] Reading 32 bytes
[8] Reading 9 records
[8,0] Reading 2 bytes
[8,1] Reading 16 bytes
[8,2] Reading 16 bytes
[8,3] Reading 128 bytes
[8,4] Reading 128 bytes
[8,7] Reading 4 bytes
[8,8] Reading 8 bytes
[8,9] Reading 8 bytes
[8,10] Reading 32 bytes
[11] Reading 5 records
[11,0] Reading 4 bytes
[11,1] Reading 4 bytes
[11,2] Reading 4 bytes
[11,3] Reading 4 bytes
[11,4] Reading 1058 bytes
[12] Reading 1 records
[12,0] Reading 102 bytes
[26] Reading 2 records
[26,0] Reading 16 bytes
[26,1] Reading 68 bytes
[31] Reading 1 records
[31,4] Reading 16 bytes
[44] Reading 1 records
[44,0] Reading 1 bytes
[50] Reading 3 records
[50,0] Reading 2 bytes
[50,1] Reading 22 bytes
[50,2] Reading 22 bytes
[54] Reading 1 records
[54,0] Reading 2 bytes
[88] Reading 1 records
[88,0] Reading 36 bytes
[96] Reading 2 records
[96,0] Reading 2 bytes
[96,1] Reading 20 bytes
[107] Reading 6 records
[107,0] Reading 41 bytes
[107,1] Reading 89 bytes
[107,2] Reading 89 bytes
[107,3] Reading 70 bytes
[107,25] Reading 236 bytes
[107,26] Reading 12 bytes
[117] Reading 3 records
[117,5] Reading 10 bytes
[117,6] Reading 8 bytes
[117,8] Reading 64 bytes
[120] Reading 4 records
[120,0] Reading 88 bytes
[120,1] Reading 160 bytes
[120,2] Reading 130 bytes
[120,3] Reading 112 bytes
[153] Reading 7 records
[153,0] Reading 68 bytes
[153,1] Reading 68 bytes
[153,2] Reading 68 bytes
[153,3] Reading 68 bytes
[153,4] Reading 68 bytes
[153,5] Reading 68 bytes
[153,6] Reading 68 bytes
[193] Reading 4 records
[193,2] Reading 8 bytes
[193,3] Reading 32 bytes
[193,4] Reading 32 bytes
[193,9] Reading 64 bytes
[217] Reading 1 records
[217,0] Reading 32 bytes
[239] Reading 4 records
[239,0] Reading 2 bytes
[239,1] Reading 3284 bytes
[239,6] Reading 218 bytes
[239,21] Reading 218 bytes
[308] Reading 7 records
[308,0] Reading 1 bytes
[308,1] Reading 8192 bytes
[308,3] Reading 1 bytes
[308,4] Reading 1 bytes
[308,6] Reading 1 bytes
[308,7] Reading 1 bytes
[308,9] Reading 40 bytes
[309] Reading 8 records
[309,0] Reading 4 bytes
[309,1] Reading 2 bytes
[309,2] Reading 12 bytes
[309,3] Reading 36 bytes
[309,4] Reading 12 bytes
[309,5] Reading 12 bytes
[309,7] Reading 12 bytes
[309,17] Reading 12 bytes
[322] Reading 1 records
[322,0] Reading 1 bytes
[334] Reading 1 records
[334,0] Reading 1 bytes
[341] Reading 3 records
[341,0] Reading 1 bytes
[341,3] Reading 4 bytes
[341,4] Reading 4416 bytes
[354] Reading 1 records
[354,0] Reading 18 bytes
[356] Reading 2 records
[356,0] Reading 2 bytes
[356,1] Reading 8 bytes
[360] Reading 3 records
[360,0] Reading 1 bytes
[360,1] Reading 2 bytes
[360,2] Reading 3 bytes
[369] Reading 1 records
[369,0] Reading 40 bytes
PM Read OK, Time taken 6.485s
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Trying to store Simlock...
Reading Configuration Key...
Hashing...
Reading SHA1-RSA Signature...
Reading SHA1-HMAC Signature...
Storing Simlock...
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
Security block OK and saved to "RM-576_354866045935513_30072012_145901.SecurityBlock.PM"
WARNING: "1270000F6FA20344945BBAAED7DE3A09F1073294.B0001D43" Not Exists, Will read it...
Reading CYC file from phone...
Booting CMT...
Switching to RAW Mode...
Old ROM Detected
CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104
CMT_EM_ASIC_ID:  00000C35
CMT_EM_ASIC_ID:  00000C30
CMT_PUBLIC_ID:  1270000F6FA20344945BBAAED7DE3A09F1073294
CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B
CMT_BOOT_ROM_CRC: E693EF0D
CMT_SECURE_ROM_CRC: AC22615B
CMT Ready!
New_RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.48.1, Algo: BB5
Waiting for USB Boot ROM Answer...
ROM Ret: 0xFFFD125D
ROM CMT dwAddr: 0x10004FF0
ROM CMT dwLength: 0x00627837
Seems ROM Initialized OK!
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR
FlashChip[0,CMT]: 0x0098004000000031, Toshiba, ONENAND
Sending Auxiliary Loader...
Auxiliary Loader Sent!
Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs
Custom loader running OK! Working...
If phone doesn't powering into Local Mode now for some reason do following:
1. Re-insert battery
2. Power it on, when asked use Ovi/Pc Suite Mode
Readed OK, Saving to "1270000F6FA20344945BBAAED7DE3A09F1073294.B0001D43"
Storing Additional Data...
Checking Superdongle Key...
Encrypting Superdongle Key...
Storing Superdongle Key...
Checking CMLA Key...
Storing CMLA Key...
Booting CMT...
Old ROM Detected
CMT Ready!
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5
ROM Ret: 0xFFFD125D
FlashChip 0x00980040 (Toshiba), Size: 256MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6
TurboCache Loaded!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Waiting for FUR Client become avaiable...
FUR Avaiable!
CMT FUR Ready!
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
PAPUBKEYS Hash for CMT: B1302F79239A2431E816565B36374B1F676A23AC
APE Subsystem Not Found
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
CMT PARTNERC Not Found
Restarting MCU...
RPL Saved OK
MCU Date 25-05-10
PSN  KEZ108850
Module Code 0204314
LPSN  0
APE SW  033.014
APE Test  0.A28
APE HW  256
APE ADSP 256
RETU  35
TAHVO  00
AHNE  11
HW  2004
DSP  ICPR82_10w18.4
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Reading SL3 LOG File...
MCU Date 25-05-10
Analyzing Profile Bits...
Phone can be NCK unlocked using KEYPAD
Phone can be NCK unlocked using FBUS
15 Digits NCK Found
"1270000F6FA20344945BBAAED7DE3A09F1073294.B0001D43" Exists, That is good...
Success!
Sending BB5 NCK Code...
NCK[7] - ACCEPTED
MCU Date 25-05-10
PSN  KEZ108850
Module Code 0204314
LPSN  0
APE SW  033.014
APE Test  0.A28
APE HW  256
APE ADSP 256
RETU  35
TAHVO  00
AHNE  11
DSP  ICPR82_10w18.4
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: 23410F
Simlock [2,1] State: OPENED Type: MCC-MNC Data: 23410F
Simlock NCK #pw+0[€j79760546673+7#
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 07-30-2012, 19:30   #2766 (permalink)
dapx's Avatar
Member: 1064967
Unlock 5130 RM-495 Done!
MCU Version	V 05.80
MCU Date	18-12-08
Product		RM-495 (Nokia 5130 XpressMusic)
IMEI		358318034
Mastercode	660532110
IMEI Spare	3A85130843085107
IMEI SV		3385130843085127F6000000
PPM		V 05.80, 18-12-08, RM-495, (c) Nokia            , UA
CNT		Content: ua_blue_movistar_argentina, V 05.80, 18-12-08, RM-495, (c) Nokia            , ,
PSN		GEM578637
Product Code	0580811
Module Code	0204024
Basic Product Code	0567773
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		4000
RFIC		06540601
DSP		ICPR72_08w50
LCD		SEIKO
BT		2222-143C
Simlock Key	7220700000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 72207F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 21407F
Simlock [3,1]	State: CLOSED	Type: MCC-MNC	Data: 21402F
NCK[7] - ACCEPTED
MCU Version	V 05.80
MCU Date	18-12-08
IMEI		358318034
PSN		GEM578637
Module Code	0204024
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		4000
RFIC		06540601
DSP		ICPR72_08w50
LCD		SEIKO
BT		2222-143C
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 72207F
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 21407F
Simlock [3,1]	State: OPENED	Type: MCC-MNC	Data: 21402F
Simlock NCK	#pw+6M2s29422251834+7#
The Following User Says Thank You to dapx For This Useful Post:
Old 07-30-2012, 21:32   #2767 (permalink)
Member: 190067
c3 unlocked
[Nokia C3-00 USB Phonet]: Port opened OK!
MCU Version    V 08.63
MCU Date    25-03-11
Product        RM-614 (Nokia C3-00)
IMEI        358628049375096
Mastercode    6321616534
IMEI Spare    3A85260894730509
IMEI SV        3385260894730539F2000000
PPM        V 08.63, 25-03-11, RM-614, (c) Nokia            , C1
CNT        Content: Vodafone UK v3 sl, V 08.63, 25-03-11, RM-614, (c) Nokia
PSN        08BA725AY
Product Code    059B782
Module Code    0204418
Basic Product Code    059D7N6
LPSN        0
WLAN MAC    6CA780B95E51
HW        1008
RFIC        9
LCD        SEIKO
BT        4217-v529
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Product Code: 059B782
NCK[7] - ACCEPTED
MCU Version    V 08.63
MCU Date    25-03-11
PSN        08BA725AY
Module Code    0204418
LPSN        0
HW        1008
RFIC        9
LCD        SEIKO
BT        4217-v529
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Simlock [1,1]    State: OPENED    Type: MCC-MNC    Data: 23415F
Simlock NCK    #pw+4rZ^63850007824+7#
Last edited by ptt; 07-30-2012 at 22:18. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 08-02-2012, 02:56   #2768 (permalink)
Member: 388033
Sonork: 100.1624864
Thumbs up BlackBerry 8520 Unlock Successful :-)
Started Blackberry Code Calculation procedure at 3:51:41 AM
Service Tag: 06FC7C1AC4253B2B27A90E073666C1D6
MEP-2: 2569607429888572
Calculations Left: 97
All Done!
Last edited by ptt; 08-02-2012 at 22:12. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 08-03-2012, 10:07   #2769 (permalink)
Member: 135871
succesfull read log
Hello. Only cyclone created successfull LBF log
MCU Version	V 10.40
MCU Date	27-04-10
Product		RM-578 (Nokia 2730 classic)
IMEI		353396040271442
Mastercode	716224523
IMEI Spare	3A35930604724104
IMEI SV		3335930604724154F8000000
PPM		V 10.40, 27-04-10, RM-578, (c) Nokia            , BOR
CNT		Content: ORANGE PL, V 10.40, 27-04-10, RM-578, (c) Nokia            , ,
PSN		098D78CAI
Product Code	0591380
Module Code	0204322
Basic Product Code	0580665
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		3003
RFIC		17141716
DSP		ICPR72_10w01_Tommy
LCD		SEIKO
BT		2.31-SP2.26
Simlock Key	2600300000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 26003F
Product Code: 0591380
Scanning avaiable products...
No flash paths set! Go to Settings -> Paths and set them!
MCU Version	V 10.40
MCU Date	27-04-10
15 Digits NCK Found
read it...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006030C192101023000
CMT_EM_ASIC_ID:		00000296
CMT_PUBLIC_ID:		02C00112478900560DA26EBB76737C968426BAF2
CMT_ROOT_KEY_HASH:	9DDBFCFE6E73CED7D8C6268C8EB85723
CMT Ready!
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Using OLD BB5 FLASHING PROTOCOL
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Old Loader Detected
Readed OK, Saving to "02C00112478900560DA26EBB76737C968426BAF2.C0005F54"
Success!
Thanks Team
Old 08-03-2012, 19:08   #2770 (permalink)
dapx's Avatar
Member: 1064967
Full Flash USB C6-01 RM-601 Done!
[Nokia C6-01 USB Phonet]: Port opened OK!
MCU Version	V 79_sr1_11w42.5
MCU Date	25-11-11
Product		RM-601 (Nokia C6-01)
IMEI		353758046
Mastercode	372573234
IMEI Spare	3A35570864262309
IMEI SV		3335570864262339F3000000
PSN		CYE498483
Product Code	059C3P8
Module Code	0204365
Basic Product Code	0592342
LPSN		0
WLAN MAC	AC81F3888261
APE SW		111.030.0609
APE Variant	111.030.0609111.030.0609.23.01111.030.0609.C00.01
APE Test		0.063
APE HW		256
APE ADSP	256
APE BT		HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 2184.
RETU		40
TAHVO		00
AHNE		11
HW		0600
RFIC		|Alli_4.3.4
DSP		79_SR1_11w42.5
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Product Code: 059C3P8
This is Valid BB5 Product
No variant found with given Product Code, selecting first one
Processing RM-601_111.030.0609_79u_prd.core.fpsx (CMT)...
Booting CMT...
Old ROM Detected
CMT_EM_ASIC_ID:		00001040
CMT_EM_ASIC_ID:		00001030
CMT_PUBLIC_ID:		024001162AE9584075CED6F05CD6DF8896F08D2B
CMT Ready!
RM-601_111.030.0609_79u_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
ROM Ret: 0xFFFD125D
FlashChip[0,CMT]: 0x00EC006000000032, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0060 (Samsung), Size: 1024MBytes, VPP: Not Supported
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: C436DE8B3DEA6D6C6CCE9CBE15F7C501BB822D02
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND
EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND
EraseArea[0,CMT]: 0x00DC0000-0x0DAFFFFF, ONENAND
EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 1.828s
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS+PMML Certificate...
Writing CMT SOS+DECOMP Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT SOS+IVE3A Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT LDSP Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 20.16s
Flashing Speed: 50180,21 kBit/S
Processing RM-601_111.030.0609_79u_prd.core.fpsx (APE)...
Processing RM-601_111.030.0609_23.01_Latin_America_79u_prd.rofs2.fpsx (CMT)...
RM-601_111.030.0609_23.01_Latin_America_79u_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x090C0000-0x0CBFFFFF, ONENAND
Erase taken 0.235s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 6.625s
Flashing Speed: 60430,34 kBit/S
Processing RM-601_111.030.0609_23.01_Latin_America_79u_prd.rofs2.fpsx (APE)...
Processing RM-601_111.030.0609_C00.01_79u_prd.rofs3.fpsx (CMT)...
RM-601_111.030.0609_C00.01_79u_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x01378000-0x0139FFFF, ONENAND
EraseArea[0,CMT]: 0x0CC00000-0x0DAFFFFF, ONENAND
Erase taken 0.125s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
Writing CMT SOS+IVE3B Certificate...
All blocks written OK! Time taken 0.516s
Flashing Speed: 359,92 kBit/S
Processing RM-601_111.030.0609_C00.01_79u_prd.rofs3.fpsx (APE)...
Processing RM-601_111.030.0609_U04.01_79u.uda.fpsx (CMT)...
RM-601_111.030.0609_U04.01_79u.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x0DB00000-0x2E0FFFFF, ONENAND
Erase taken 1.969s
TurboCache Loaded!
All blocks written OK! Time taken 22.515s
Flashing Speed: 50586,77 kBit/S
Processing RM-601_111.030.0609_U04.01_79u.uda.fpsx (APE)...
Processing RM601_APE_ONLY_ENO_11w32_v0.064.fpsx (CMT)...
RM601_APE_ONLY_ENO_11w32_v0.064.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x008C0000-0x00DBFFFF, ONENAND
Erase taken 0.31s
TurboCache Loaded!
Writing CMT SOS*ENO Certificate...
All blocks written OK! Time taken 0.922s
Flashing Speed: 44041,93 kBit/S
Processing RM601_APE_ONLY_ENO_11w32_v0.064.fpsx (APE)...
Restarting MCU...
Factory defaults OK
Reading info...
MCU Date	25-11-11
IMEI		353758046
PSN		CYE498483
Module Code	0204365
LPSN		0
APE SW		111.030.0609
APE Test		0.064
APE HW		256
APE ADSP	256
RETU		40
TAHVO		00
AHNE		11
HW		0600
RFIC		|Alli_4.3.4
DSP		79_SR1_11w42.5
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Old 08-04-2012, 08:10   #2771 (permalink)
.::TR_LAZ::.'s Avatar
Member: 178227
Sonork: 100.1597371
Thumbs up 6700c camera Accepted! Repair Finished
Product Code: 0594432
Variant found for readen Product Data!
Analyzing Dynamic Camera Configuration...
--> Primary Camera Not Exists
Secondary Camera: ISL2TI020000093E2F30XXXXXX
Secondary Camera Configuration is destroyed, writing factory one...
Writing Configuration...
Configuration Accepted!
Dynamic Camera Configuration Analyze/Repair Finished!
TR_LAZ
Last edited by ptt; 08-05-2012 at 00:40. Reason: ADD [CODE] [/CODE] TAG TO THE LOG -- USE NORMAL SIZE FONT NOBODY IS BLIND HERE
Old 08-04-2012, 11:39   #2772 (permalink)
kashif_nawaz81's Avatar
Member: 246429
successfully flash on ver 10.91, and flash with ver 10.91 BY USB
http://i49.tinypic.com/vex06h.jpg
HERE IS LOG
Initializing box...
Box Serial Number: C00064C8
Card Serial Number: D0080107
Card is activated
Box is activated
USB Voltage    4.83v    PASSED
MCU Voltage    3.29v    PASSED
Core Voltage    1.79v    PASSED
VBAT Voltage    1.42v    PASSED
VBAT Voltage    4.76v    PASSED
Box VPP disabled
VPP Voltage    4.79v    PASSED
Box VPP disabled
VPP Voltage    0.02v    PASSED
VPP Voltage    0.00v    FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 525.684MB
Avaiable Virtual Memory: 1.840GB
Avaiable Pagefile: 1.862GB
Step 1, Dumping Unique Data
WARNING: Failed to read RAP Public ID
Booting CMT...
Failed to Boot CMT -> Failed to get First Boot Block
Prepare phone failed with message -> Failed to Boot CMT
Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone)
Failed to Proceed with New Downgrade -> Failed to Read Unique Data
Processing rm694__10.90.mcusw (XGold2)...
Checking rm694__10.90.mcusw...
Booting X-Gold via USB...
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Quantum_Bootloader_10.46_M1S1
[EBL] : Ready
Processing "rm694__10.90.mcusw_ebl_psi.fls"...
Erasing 0x40280000-0x41BFFFFF...
Flashed 26214400 bytes OK
Processing rm694__10.90.ppm_m_a (XGold2)...
Checking rm694__10.90.ppm_m_a...
Processing "package_m_a.ppm_ebl_psi.fls"...
Erasing 0x41C00000-0x422FFFFF...
Flashing at 0x41C00000...
Flashed 4459256 bytes OK
Processing rm694__10.90.image_m_a_059D1B3 (XGold2)...
Checking rm694__10.90.image_m_a_059D1B3...
Processing "package_m_a_059D1B3.image.fls"...
Erasing 0x42300000-0x43E1FFFF...
Flashing at 0x42300000...
Flashed 14417920 bytes OK
[Nokia USB Phonet]: Port opened OK!
Factory defaults OK
Last edited by ptt; 08-05-2012 at 00:41. Reason: ADD [CODE] [/CODE] TAG TO THE LOG - REMOVE [IMG] TAG - TXT LOG IS ENOUGH
Old 08-06-2012, 10:21   #2773 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Nokia ASHA 201 RM-799 back-up and read log file
MCU Version V 11.21
MCU Date 16-01-12
Product  RM-799 (Nokia RM-799)
IMEI  352829050618731
Mastercode 1276723
IMEI Spare 3A25280905167803
IMEI SV  3325280905167803F3000000
PPM  V 11.21, 16-01-12, RM-799, (c) Nokia            , C1
CNT  Content: Vodafone GB payg sl, V 11.21, 16-01-12, RM-799, (c) Nokia
PSN  1591D18BI
Product Code 059N5H9
Module Code 0205022
Basic Product Code 059J2K2
LPSN  0
HW  2200
RFIC  Dummy RFIC version
LCD  TPO
BT  19e2-47026
Asic  11
HW Signature 2C75E24EB4D32067
Simlock Profile 800000000003000B
Simlock IMEI 00003528290506187300
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Product Code: 059N5H9
[4] Reading 10 records
[4,1] Reading 800 bytes
[4,26] Reading 132 bytes
[8] Reading 10 records
[8,11] Reading 4 bytes
[8,12] Reading 4 bytes
[11,4] Reading 241 bytes
[13] Reading 167 records
[13,0] Reading 1 bytes
[13,1] Reading 2 bytes
[13,2] Reading 1 bytes
[13,3] Reading 2 bytes
[13,4] Reading 1 bytes
[13,5] Reading 1 bytes
[13,6] Reading 1 bytes
[13,7] Reading 1 bytes
[13,8] Reading 2 bytes
[13,9] Reading 1 bytes
[13,10] Reading 1 bytes
[13,11] Reading 48 bytes
[13,12] Reading 4 bytes
[13,13] Reading 1 bytes
[13,14] Reading 1 bytes
[13,15] Reading 886 bytes
[13,16] Reading 2 bytes
[13,17] Reading 1 bytes
[13,18] Reading 1 bytes
[13,19] Reading 8 bytes
[13,20] Reading 1 bytes
[13,21] Reading 1 bytes
[13,22] Reading 1 bytes
[13,23] Reading 1 bytes
[13,24] Reading 1 bytes
[13,25] Reading 2 bytes
[13,26] Reading 1 bytes
[13,27] Reading 1 bytes
[13,28] Reading 1 bytes
[13,29] Reading 1 bytes
[13,30] Reading 1 bytes
[13,31] Reading 1 bytes
[13,32] Reading 1 bytes
[13,33] Reading 1 bytes
[13,34] Reading 1 bytes
[13,35] Reading 1 bytes
[13,36] Reading 1 bytes
[13,37] Reading 4 bytes
[13,38] Reading 1 bytes
[13,39] Reading 1 bytes
[13,40] Reading 1 bytes
[13,41] Reading 1 bytes
[13,42] Reading 4 bytes
[13,43] Reading 4 bytes
[13,44] Reading 1 bytes
[13,45] Reading 4 bytes
[13,46] Reading 4 bytes
[13,47] Reading 1 bytes
[13,48] Reading 4 bytes
[13,49] Reading 1 bytes
[13,50] Reading 1 bytes
[13,51] Reading 1 bytes
[13,52] Reading 2 bytes
[13,53] Reading 4 bytes
[13,54] Reading 4 bytes
[13,55] Reading 1 bytes
[13,56] Reading 1 bytes
[13,57] Reading 1 bytes
[13,58] Reading 2 bytes
[13,59] Reading 1 bytes
[13,60] Reading 4 bytes
[13,61] Reading 4 bytes
[13,62] Reading 1 bytes
[13,63] Reading 4 bytes
[13,64] Reading 4 bytes
[13,65] Reading 1 bytes
[13,66] Reading 4 bytes
[13,67] Reading 4 bytes
[13,68] Reading 1 bytes
[13,69] Reading 1 bytes
[13,70] Reading 1 bytes
[13,71] Reading 4 bytes
[13,72] Reading 4 bytes
[13,73] Reading 1 bytes
[13,74] Reading 4 bytes
[13,75] Reading 2 bytes
[13,76] Reading 2 bytes
[13,77] Reading 2 bytes
[13,78] Reading 1 bytes
[13,79] Reading 1 bytes
[13,80] Reading 1 bytes
[13,81] Reading 1 bytes
[13,82] Reading 1 bytes
[13,83] Reading 2 bytes
[13,84] Reading 1 bytes
[13,85] Reading 4 bytes
[13,86] Reading 4 bytes
[13,87] Reading 2 bytes
[13,88] Reading 1 bytes
[13,89] Reading 4 bytes
[13,90] Reading 4 bytes
[13,91] Reading 2 bytes
[13,92] Reading 1 bytes
[13,93] Reading 4 bytes
[13,94] Reading 4 bytes
[13,95] Reading 2 bytes
[13,96] Reading 1 bytes
[13,97] Reading 4 bytes
[13,98] Reading 4 bytes
[13,99] Reading 2 bytes
[13,100] Reading 4 bytes
[13,101] Reading 2 bytes
[13,102] Reading 1 bytes
[13,103] Reading 4 bytes
[13,104] Reading 4 bytes
[13,105] Reading 4 bytes
[13,106] Reading 4 bytes
[13,107] Reading 4 bytes
[13,108] Reading 2 bytes
[13,109] Reading 4 bytes
[13,110] Reading 4 bytes
[13,111] Reading 4 bytes
[13,112] Reading 2 bytes
[13,113] Reading 4 bytes
[13,114] Reading 4 bytes
[13,115] Reading 1 bytes
[13,116] Reading 1 bytes
[13,117] Reading 1 bytes
[13,118] Reading 4 bytes
[13,119] Reading 4 bytes
[13,120] Reading 1 bytes
[13,121] Reading 1 bytes
[13,122] Reading 1 bytes
[13,123] Reading 8 bytes
[13,124] Reading 1 bytes
[13,125] Reading 1 bytes
[13,126] Reading 1 bytes
[13,127] Reading 1 bytes
[13,128] Reading 1 bytes
[13,129] Reading 4 bytes
[13,130] Reading 4 bytes
[13,131] Reading 1 bytes
[13,132] Reading 1 bytes
[13,133] Reading 2 bytes
[13,134] Reading 1 bytes
[13,135] Reading 2 bytes
[13,136] Reading 1 bytes
[13,137] Reading 1 bytes
[13,138] Reading 4 bytes
[13,139] Reading 4 bytes
[13,140] Reading 1 bytes
[13,141] Reading 1 bytes
[13,142] Reading 1 bytes
[13,143] Reading 1 bytes
[13,144] Reading 4 bytes
[13,145] Reading 8 bytes
[13,146] Reading 4 bytes
[13,147] Reading 4 bytes
[13,148] Reading 1 bytes
[13,149] Reading 1 bytes
[13,150] Reading 1 bytes
[13,151] Reading 1 bytes
[13,152] Reading 1 bytes
[13,153] Reading 1 bytes
[13,154] Reading 1 bytes
[13,155] Reading 1 bytes
[13,156] Reading 1 bytes
[13,157] Reading 1 bytes
[13,158] Reading 1 bytes
[13,159] Reading 2 bytes
[13,160] Reading 2 bytes
[13,161] Reading 1 bytes
[13,162] Reading 1 bytes
[13,163] Reading 1 bytes
[13,164] Reading 1 bytes
[13,165] Reading 1 bytes
[13,166] Reading 1 bytes
[42] Reading 27 records
[42,0] Reading 2 bytes
[42,1] Reading 12 bytes
[42,2] Reading 36 bytes
[42,3] Reading 36 bytes
[42,4] Reading 36 bytes
[42,5] Reading 36 bytes
[42,6] Reading 36 bytes
[42,7] Reading 40 bytes
[42,8] Reading 40 bytes
[42,9] Reading 40 bytes
[42,10] Reading 40 bytes
[42,11] Reading 40 bytes
[42,12] Reading 40 bytes
[42,13] Reading 40 bytes
[42,14] Reading 40 bytes
[42,15] Reading 40 bytes
[42,16] Reading 40 bytes
[42,17] Reading 40 bytes
[42,18] Reading 40 bytes
[42,19] Reading 40 bytes
[42,20] Reading 40 bytes
[42,21] Reading 40 bytes
[42,22] Reading 40 bytes
[42,23] Reading 40 bytes
[42,24] Reading 40 bytes
[42,25] Reading 40 bytes
[42,26] Reading 40 bytes
[107,0] Reading 21 bytes
[107,2] Reading 69 bytes
[107,25] Reading 136 bytes
[116] Reading 17 records
[116,0] Reading 2 bytes
[116,1] Reading 12 bytes
[116,2] Reading 36 bytes
[116,3] Reading 36 bytes
[116,4] Reading 36 bytes
[116,5] Reading 36 bytes
[116,6] Reading 36 bytes
[116,7] Reading 40 bytes
[116,8] Reading 40 bytes
[116,9] Reading 40 bytes
[116,10] Reading 40 bytes
[116,11] Reading 40 bytes
[116,12] Reading 40 bytes
[116,13] Reading 40 bytes
[116,14] Reading 40 bytes
[116,15] Reading 40 bytes
[116,16] Reading 40 bytes
[120,0] Reading 56 bytes
[218] Reading 1 records
[218,0] Reading 2 bytes
[238] Reading 1 records
[238,1] Reading 1 bytes
[301] Reading 17 records
[301,0] Reading 2 bytes
[301,1] Reading 12 bytes
[301,2] Reading 36 bytes
[301,3] Reading 36 bytes
[301,4] Reading 36 bytes
[301,5] Reading 36 bytes
[301,6] Reading 36 bytes
[301,7] Reading 40 bytes
[301,8] Reading 40 bytes
[301,9] Reading 40 bytes
[301,10] Reading 40 bytes
[301,11] Reading 40 bytes
[301,12] Reading 40 bytes
[301,13] Reading 40 bytes
[301,14] Reading 40 bytes
[301,15] Reading 40 bytes
[301,16] Reading 40 bytes
[308] Reading 9 records
[308,1] Reading 1 bytes
[308,5] Reading 10 bytes
[308,8] Reading 1 bytes
[339] Reading 2 records
[339,0] Reading 511 bytes
[339,1] Reading 511 bytes
[341] Reading 5 records
[341,4] Reading 4390 bytes
[341,5] Reading 4 bytes
[341,6] Reading 2380 bytes
[354,0] Reading 15 bytes
[355] Reading 1 records
[355,0] Reading 19298 bytes
[362] Reading 2 records
[362,0] Reading 1 bytes
[362,1] Reading 144 bytes
[364] Reading 27 records
[364,0] Reading 2 bytes
[364,1] Reading 12 bytes
[364,2] Reading 36 bytes
[364,3] Reading 36 bytes
[364,4] Reading 36 bytes
[364,5] Reading 36 bytes
[364,6] Reading 36 bytes
[364,7] Reading 40 bytes
[364,8] Reading 40 bytes
[364,9] Reading 40 bytes
[364,10] Reading 40 bytes
[364,11] Reading 40 bytes
[364,12] Reading 40 bytes
[364,13] Reading 40 bytes
[364,14] Reading 40 bytes
[364,15] Reading 40 bytes
[364,16] Reading 40 bytes
[364,17] Reading 40 bytes
[364,18] Reading 40 bytes
[364,19] Reading 40 bytes
[364,20] Reading 40 bytes
[364,21] Reading 40 bytes
[364,22] Reading 40 bytes
[364,23] Reading 40 bytes
[364,24] Reading 40 bytes
[364,25] Reading 40 bytes
[364,26] Reading 40 bytes
[365] Reading 17 records
[365,0] Reading 2 bytes
[365,1] Reading 12 bytes
[365,2] Reading 36 bytes
[365,3] Reading 36 bytes
[365,4] Reading 36 bytes
[365,5] Reading 36 bytes
[365,6] Reading 36 bytes
[365,7] Reading 40 bytes
[365,8] Reading 40 bytes
[365,9] Reading 40 bytes
[365,10] Reading 40 bytes
[365,11] Reading 40 bytes
[365,12] Reading 40 bytes
[365,13] Reading 40 bytes
[365,14] Reading 40 bytes
[365,15] Reading 40 bytes
[365,16] Reading 40 bytes
[373] Reading 1 records
[373,0] Reading 44 bytes
[383] Reading 166 records
[383,1] Reading 256 bytes
[383,3] Reading 256 bytes
[383,4] Reading 256 bytes
[383,5] Reading 256 bytes
[383,6] Reading 256 bytes
[383,7] Reading 256 bytes
[383,8] Reading 256 bytes
[383,9] Reading 256 bytes
[383,10] Reading 256 bytes
[383,11] Reading 256 bytes
[383,12] Reading 256 bytes
[383,13] Reading 256 bytes
[383,14] Reading 256 bytes
[383,15] Reading 256 bytes
[383,16] Reading 256 bytes
[383,17] Reading 256 bytes
[383,18] Reading 256 bytes
[383,19] Reading 256 bytes
[383,20] Reading 256 bytes
[383,21] Reading 256 bytes
[383,22] Reading 256 bytes
[383,23] Reading 256 bytes
[383,24] Reading 256 bytes
[383,25] Reading 256 bytes
[383,26] Reading 256 bytes
[383,27] Reading 256 bytes
[383,28] Reading 256 bytes
[383,29] Reading 256 bytes
[383,30] Reading 256 bytes
[383,31] Reading 256 bytes
[383,32] Reading 256 bytes
[383,33] Reading 256 bytes
[383,34] Reading 256 bytes
[383,35] Reading 256 bytes
[383,36] Reading 256 bytes
[383,37] Reading 256 bytes
[383,38] Reading 256 bytes
[383,39] Reading 256 bytes
[383,40] Reading 256 bytes
[383,41] Reading 256 bytes
[383,42] Reading 256 bytes
[383,43] Reading 256 bytes
[383,44] Reading 256 bytes
[383,45] Reading 256 bytes
[383,46] Reading 256 bytes
[383,47] Reading 256 bytes
[383,48] Reading 256 bytes
[383,49] Reading 256 bytes
[383,50] Reading 256 bytes
[383,51] Reading 256 bytes
[383,52] Reading 256 bytes
[383,53] Reading 256 bytes
[383,54] Reading 256 bytes
[383,55] Reading 256 bytes
[383,56] Reading 256 bytes
[383,57] Reading 256 bytes
[383,58] Reading 256 bytes
[383,59] Reading 256 bytes
[383,60] Reading 256 bytes
[383,61] Reading 256 bytes
[383,62] Reading 256 bytes
[383,63] Reading 256 bytes
[383,64] Reading 256 bytes
[383,65] Reading 256 bytes
[383,66] Reading 256 bytes
[383,67] Reading 256 bytes
[383,68] Reading 256 bytes
[383,69] Reading 256 bytes
[383,70] Reading 256 bytes
[383,71] Reading 256 bytes
[383,72] Reading 256 bytes
[383,73] Reading 256 bytes
[383,74] Reading 256 bytes
[383,75] Reading 256 bytes
[383,76] Reading 256 bytes
[383,77] Reading 256 bytes
[383,78] Reading 256 bytes
[383,79] Reading 256 bytes
[383,80] Reading 256 bytes
[383,81] Reading 256 bytes
[383,82] Reading 256 bytes
[383,83] Reading 256 bytes
[383,84] Reading 256 bytes
[383,85] Reading 256 bytes
[383,86] Reading 256 bytes
[383,87] Reading 256 bytes
[383,88] Reading 256 bytes
[383,89] Reading 256 bytes
[383,90] Reading 256 bytes
[383,91] Reading 256 bytes
[383,92] Reading 256 bytes
[383,93] Reading 256 bytes
[383,94] Reading 256 bytes
[383,95] Reading 256 bytes
[383,96] Reading 256 bytes
[383,97] Reading 256 bytes
[383,98] Reading 256 bytes
[383,99] Reading 256 bytes
[383,100] Reading 256 bytes
[383,101] Reading 256 bytes
[383,102] Reading 256 bytes
[383,103] Reading 256 bytes
[383,104] Reading 256 bytes
[383,105] Reading 256 bytes
[383,106] Reading 256 bytes
[383,107] Reading 256 bytes
[383,108] Reading 256 bytes
[383,109] Reading 256 bytes
[383,110] Reading 256 bytes
[383,111] Reading 256 bytes
[383,112] Reading 256 bytes
[383,113] Reading 256 bytes
[383,114] Reading 256 bytes
[383,115] Reading 256 bytes
[383,116] Reading 256 bytes
[383,117] Reading 256 bytes
[383,118] Reading 256 bytes
[383,119] Reading 256 bytes
[383,120] Reading 256 bytes
[383,121] Reading 256 bytes
[383,122] Reading 256 bytes
[383,123] Reading 256 bytes
[383,124] Reading 256 bytes
[383,125] Reading 256 bytes
[383,126] Reading 256 bytes
[383,127] Reading 256 bytes
[383,128] Reading 256 bytes
[383,129] Reading 256 bytes
[383,130] Reading 256 bytes
[383,131] Reading 256 bytes
[383,132] Reading 256 bytes
[383,133] Reading 256 bytes
[383,134] Reading 256 bytes
[383,135] Reading 256 bytes
[383,136] Reading 256 bytes
[383,137] Reading 256 bytes
[383,138] Reading 256 bytes
[383,139] Reading 256 bytes
[383,140] Reading 256 bytes
[383,141] Reading 256 bytes
[383,142] Reading 256 bytes
[383,143] Reading 256 bytes
[383,144] Reading 256 bytes
[383,145] Reading 256 bytes
[383,146] Reading 256 bytes
[383,147] Reading 256 bytes
[383,148] Reading 256 bytes
[383,149] Reading 256 bytes
[383,150] Reading 256 bytes
[383,151] Reading 256 bytes
[383,152] Reading 256 bytes
[383,153] Reading 256 bytes
[383,154] Reading 256 bytes
[383,155] Reading 256 bytes
[383,156] Reading 256 bytes
[383,157] Reading 256 bytes
[383,158] Reading 256 bytes
[383,159] Reading 256 bytes
[383,160] Reading 256 bytes
[383,161] Reading 256 bytes
[383,162] Reading 256 bytes
[383,163] Reading 256 bytes
[383,164] Reading 256 bytes
[383,165] Reading 256 bytes
[383,166] Reading 256 bytes
[383,167] Reading 256 bytes
[390] Reading 162 records
[390,0] Reading 256 bytes
[390,2] Reading 256 bytes
[390,3] Reading 256 bytes
[390,4] Reading 256 bytes
[390,5] Reading 256 bytes
[390,6] Reading 256 bytes
[390,7] Reading 256 bytes
[390,8] Reading 256 bytes
[390,9] Reading 256 bytes
[390,10] Reading 256 bytes
[390,11] Reading 256 bytes
[390,12] Reading 256 bytes
[390,13] Reading 256 bytes
[390,14] Reading 256 bytes
[390,15] Reading 256 bytes
[390,16] Reading 256 bytes
[390,17] Reading 256 bytes
[390,18] Reading 256 bytes
[390,19] Reading 256 bytes
[390,20] Reading 256 bytes
[390,21] Reading 256 bytes
[390,22] Reading 256 bytes
[390,23] Reading 256 bytes
[390,24] Reading 256 bytes
[390,25] Reading 256 bytes
[390,26] Reading 256 bytes
[390,27] Reading 256 bytes
[390,28] Reading 256 bytes
[390,29] Reading 256 bytes
[390,30] Reading 256 bytes
[390,31] Reading 256 bytes
[390,32] Reading 256 bytes
[390,33] Reading 256 bytes
[390,34] Reading 256 bytes
[390,35] Reading 256 bytes
[390,36] Reading 256 bytes
[390,37] Reading 256 bytes
[390,38] Reading 256 bytes
[390,39] Reading 256 bytes
[390,40] Reading 256 bytes
[390,41] Reading 256 bytes
[390,42] Reading 256 bytes
[390,43] Reading 256 bytes
[390,44] Reading 256 bytes
[390,45] Reading 256 bytes
[390,46] Reading 256 bytes
[390,47] Reading 256 bytes
[390,48] Reading 256 bytes
[390,49] Reading 256 bytes
[390,50] Reading 256 bytes
[390,51] Reading 256 bytes
[390,52] Reading 256 bytes
[390,53] Reading 256 bytes
[390,54] Reading 256 bytes
[390,55] Reading 256 bytes
[390,56] Reading 256 bytes
[390,57] Reading 256 bytes
[390,58] Reading 256 bytes
[390,59] Reading 256 bytes
[390,60] Reading 256 bytes
[390,61] Reading 256 bytes
[390,62] Reading 256 bytes
[390,63] Reading 256 bytes
[390,64] Reading 256 bytes
[390,65] Reading 256 bytes
[390,66] Reading 256 bytes
[390,67] Reading 256 bytes
[390,68] Reading 256 bytes
[390,69] Reading 256 bytes
[390,70] Reading 256 bytes
[390,71] Reading 256 bytes
[390,72] Reading 256 bytes
[390,73] Reading 256 bytes
[390,74] Reading 256 bytes
[390,75] Reading 256 bytes
[390,76] Reading 256 bytes
[390,77] Reading 256 bytes
[390,78] Reading 256 bytes
[390,79] Reading 256 bytes
[390,80] Reading 256 bytes
[390,81] Reading 256 bytes
[390,82] Reading 256 bytes
[390,83] Reading 256 bytes
[390,84] Reading 256 bytes
[390,85] Reading 256 bytes
[390,86] Reading 256 bytes
[390,87] Reading 256 bytes
[390,88] Reading 256 bytes
[390,89] Reading 256 bytes
[390,90] Reading 256 bytes
[390,91] Reading 256 bytes
[390,92] Reading 256 bytes
[390,93] Reading 256 bytes
[390,94] Reading 256 bytes
[390,95] Reading 256 bytes
[390,96] Reading 256 bytes
[390,97] Reading 256 bytes
[390,98] Reading 256 bytes
[390,99] Reading 256 bytes
[390,100] Reading 256 bytes
[390,101] Reading 256 bytes
[390,102] Reading 256 bytes
[390,103] Reading 256 bytes
[390,104] Reading 256 bytes
[390,105] Reading 256 bytes
[390,106] Reading 256 bytes
[390,107] Reading 256 bytes
[390,108] Reading 256 bytes
[390,109] Reading 256 bytes
[390,110] Reading 256 bytes
[390,111] Reading 256 bytes
[390,112] Reading 256 bytes
[390,113] Reading 256 bytes
[390,114] Reading 256 bytes
[390,115] Reading 256 bytes
[390,116] Reading 256 bytes
[390,117] Reading 256 bytes
[390,118] Reading 256 bytes
[390,119] Reading 256 bytes
[390,120] Reading 256 bytes
[390,121] Reading 256 bytes
[390,122] Reading 256 bytes
[390,123] Reading 256 bytes
[390,124] Reading 256 bytes
[390,125] Reading 256 bytes
[390,126] Reading 256 bytes
[390,127] Reading 256 bytes
[390,128] Reading 256 bytes
[390,129] Reading 256 bytes
[390,130] Reading 256 bytes
[390,131] Reading 256 bytes
[390,132] Reading 256 bytes
[390,133] Reading 256 bytes
[390,134] Reading 256 bytes
[390,135] Reading 256 bytes
[390,136] Reading 256 bytes
[390,137] Reading 256 bytes
[390,138] Reading 256 bytes
[390,139] Reading 256 bytes
[390,140] Reading 256 bytes
[390,141] Reading 256 bytes
[390,142] Reading 256 bytes
[390,143] Reading 256 bytes
[390,144] Reading 256 bytes
[390,145] Reading 256 bytes
[390,146] Reading 256 bytes
[390,147] Reading 256 bytes
[390,148] Reading 256 bytes
[390,149] Reading 256 bytes
[390,150] Reading 256 bytes
[390,151] Reading 256 bytes
[390,152] Reading 256 bytes
[390,153] Reading 256 bytes
[390,154] Reading 256 bytes
[390,155] Reading 256 bytes
[390,156] Reading 256 bytes
[390,157] Reading 256 bytes
[390,158] Reading 256 bytes
[390,159] Reading 256 bytes
[390,160] Reading 256 bytes
[390,161] Reading 256 bytes
[390,162] Reading 256 bytes
[391] Reading 163 records
[391,0] Reading 256 bytes
[391,2] Reading 256 bytes
[391,3] Reading 256 bytes
[391,4] Reading 256 bytes
[391,5] Reading 256 bytes
[391,6] Reading 256 bytes
[391,7] Reading 256 bytes
[391,8] Reading 256 bytes
[391,9] Reading 256 bytes
[391,10] Reading 256 bytes
[391,11] Reading 256 bytes
[391,12] Reading 256 bytes
[391,13] Reading 256 bytes
[391,14] Reading 256 bytes
[391,15] Reading 256 bytes
[391,16] Reading 256 bytes
[391,17] Reading 256 bytes
[391,18] Reading 256 bytes
[391,19] Reading 256 bytes
[391,20] Reading 256 bytes
[391,21] Reading 256 bytes
[391,22] Reading 256 bytes
[391,23] Reading 256 bytes
[391,24] Reading 256 bytes
[391,25] Reading 256 bytes
[391,26] Reading 256 bytes
[391,27] Reading 256 bytes
[391,28] Reading 256 bytes
[391,29] Reading 256 bytes
[391,30] Reading 256 bytes
[391,31] Reading 256 bytes
[391,32] Reading 256 bytes
[391,33] Reading 256 bytes
[391,34] Reading 256 bytes
[391,35] Reading 256 bytes
[391,36] Reading 256 bytes
[391,37] Reading 256 bytes
[391,38] Reading 256 bytes
[391,39] Reading 256 bytes
[391,40] Reading 256 bytes
[391,41] Reading 256 bytes
[391,42] Reading 256 bytes
[391,43] Reading 256 bytes
[391,44] Reading 256 bytes
[391,45] Reading 256 bytes
[391,46] Reading 256 bytes
[391,47] Reading 256 bytes
[391,48] Reading 256 bytes
[391,49] Reading 256 bytes
[391,50] Reading 256 bytes
[391,51] Reading 256 bytes
[391,52] Reading 256 bytes
[391,53] Reading 256 bytes
[391,54] Reading 256 bytes
[391,55] Reading 256 bytes
[391,56] Reading 256 bytes
[391,57] Reading 256 bytes
[391,58] Reading 256 bytes
[391,59] Reading 256 bytes
[391,60] Reading 256 bytes
[391,61] Reading 256 bytes
[391,62] Reading 256 bytes
[391,63] Reading 256 bytes
[391,64] Reading 256 bytes
[391,65] Reading 256 bytes
[391,66] Reading 256 bytes
[391,67] Reading 256 bytes
[391,68] Reading 256 bytes
[391,69] Reading 256 bytes
[391,70] Reading 256 bytes
[391,71] Reading 256 bytes
[391,72] Reading 256 bytes
[391,73] Reading 256 bytes
[391,74] Reading 256 bytes
[391,75] Reading 256 bytes
[391,76] Reading 256 bytes
[391,77] Reading 256 bytes
[391,78] Reading 256 bytes
[391,79] Reading 256 bytes
[391,80] Reading 256 bytes
[391,81] Reading 256 bytes
[391,82] Reading 256 bytes
[391,83] Reading 256 bytes
[391,84] Reading 256 bytes
[391,85] Reading 256 bytes
[391,86] Reading 256 bytes
[391,87] Reading 256 bytes
[391,88] Reading 256 bytes
[391,89] Reading 256 bytes
[391,90] Reading 256 bytes
[391,91] Reading 256 bytes
[391,92] Reading 256 bytes
[391,93] Reading 256 bytes
[391,94] Reading 256 bytes
[391,95] Reading 256 bytes
[391,96] Reading 256 bytes
[391,97] Reading 256 bytes
[391,98] Reading 256 bytes
[391,99] Reading 256 bytes
[391,100] Reading 256 bytes
[391,101] Reading 256 bytes
[391,102] Reading 256 bytes
[391,103] Reading 256 bytes
[391,104] Reading 256 bytes
[391,105] Reading 256 bytes
[391,106] Reading 256 bytes
[391,107] Reading 256 bytes
[391,108] Reading 256 bytes
[391,109] Reading 256 bytes
[391,110] Reading 256 bytes
[391,111] Reading 256 bytes
[391,112] Reading 256 bytes
[391,113] Reading 256 bytes
[391,114] Reading 256 bytes
[391,115] Reading 256 bytes
[391,116] Reading 256 bytes
[391,117] Reading 256 bytes
[391,118] Reading 256 bytes
[391,119] Reading 256 bytes
[391,120] Reading 256 bytes
[391,121] Reading 256 bytes
[391,122] Reading 256 bytes
[391,123] Reading 256 bytes
[391,124] Reading 256 bytes
[391,125] Reading 256 bytes
[391,126] Reading 256 bytes
[391,127] Reading 256 bytes
[391,128] Reading 256 bytes
[391,129] Reading 256 bytes
[391,130] Reading 256 bytes
[391,131] Reading 256 bytes
[391,132] Reading 256 bytes
[391,133] Reading 256 bytes
[391,134] Reading 256 bytes
[391,135] Reading 256 bytes
[391,136] Reading 256 bytes
[391,137] Reading 256 bytes
[391,138] Reading 256 bytes
[391,139] Reading 256 bytes
[391,140] Reading 256 bytes
[391,141] Reading 256 bytes
[391,142] Reading 256 bytes
[391,143] Reading 256 bytes
[391,144] Reading 256 bytes
[391,145] Reading 256 bytes
[391,146] Reading 256 bytes
[391,147] Reading 256 bytes
[391,148] Reading 256 bytes
[391,149] Reading 256 bytes
[391,150] Reading 256 bytes
[391,151] Reading 256 bytes
[391,152] Reading 256 bytes
[391,153] Reading 256 bytes
[391,154] Reading 256 bytes
[391,155] Reading 256 bytes
[391,156] Reading 256 bytes
[391,157] Reading 256 bytes
[391,158] Reading 256 bytes
[391,159] Reading 256 bytes
[391,160] Reading 256 bytes
[391,161] Reading 256 bytes
[391,162] Reading 256 bytes
[391,163] Reading 256 bytes
PM Read OK, Time taken 21.797s
MCU Version V 11.21
MCU Date 16-01-12
Mastercode 1276723
XGold213 Detected
15 Digits NCK Found
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Quantum_Bootloader_2.5_M1S1
[EBL] : Ready
Success!
Alex
The Following 3 Users Say Thank You to moulnisky For This Useful Post:
Old 08-07-2012, 15:17   #2774 (permalink)
dani2080's Avatar
Member: 1055074
Thumbs down Nokia 302 read bf data successfully with cyclone in just 1o seconds.
Initializing box...
Box Serial Number: C0002A6B
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32
Card Serial Number: DD00022D
Card Firmware Revision: 0109
Card is activated
Box is activated
USB Voltage 5,04v PASSED
MCU Voltage 3,31v PASSED
Core Voltage 1,78v PASSED
VBAT Voltage 4,99v PASSED
Box VPP disabled
VPP Voltage 4,88v PASSED
Box VPP disabled
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Avaiable Physical Memory: 1.387GB
Avaiable Virtual Memory: 1.886GB
Avaiable Pagefile: 3.366GB
MCU Version V 14.53
MCU Date 20-03-12
Product  RM-813 (Nokia RM-813)
IMEI  352854056937075
Mastercode 4561527273
IMEI Spare 3A25580465390707
IMEI SV  3325580465390707F5000000
PPM  V 14.53, 20-03-12, RM-813, (c) Nokia            , SP
CNT  Content: sp_059L198, V 14.53, 20-03-12, RM-813, (c) Nokia
PSN  9DBABD0AH
Product Code 059P2C8
Module Code 0205095
Basic Product Code 059J0F3
LPSN  0
WLAN MAC E8CBA116D04F
RETU  51
TAHVO  00
AHNE  21
HW  1500
RFIC  |Alli_4.b.1
DSP  104_PM5_14.53
LCD  TPO
BT  4217-v924
Simlock Key 2140100000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F
MCU Version V 14.53
MCU Date 20-03-12
15 Digits NCK Found
WARNING: "20540000FFFB7C405EA828CB287BCFDF68FAB93F.C0002A6B" Not Exists, Will read it...
Booting CMT...
Old ROM Detected
CMT_SYSTEM_ASIC_ID: 000000030000022600010007400C192103032108
CMT_EM_ASIC_ID:  00001051
CMT_EM_ASIC_ID:  00001060
CMT_PUBLIC_ID:  20540000FFFB7C405EA828CB287BCFDF68FAB93F
CMT_ROOT_KEY_HASH: 3AB5DB70B45D23F1ADEEBB5734160706
CMT_BOOT_ROM_CRC: 2CAC45E2
CMT_SECURE_ROM_CRC: 3BC33C8B
CMT Ready!
RAPUv21_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.16.0, Algo: BB5
ROM Ret: 0xFFFD125D
FlashChip[0,CMT]: 0x00EC004000000241, Samsung, ONENAND
Loader: RAPxx CommonBoot v1.07 (C) 2011 KarwosLabs
Readed OK, Saving to "20540000FFFB7C405EA828CB287BCFDF68FAB93F.C0002A6B"
Success!
The Following User Says Thank You to dani2080 For This Useful Post:
Old 08-10-2012, 15:03   #2775 (permalink)
.::SoFtWaRe ZoNe::.'s Avatar
Member: 1615596
Sonork: 100.1607045
Arrow 101 flashing done
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.04, (Jun 10 2012 18:37:57, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B000xxxx
HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27
Box is activated
Started box selftests procedure
USB Voltage 5.04v PASSED
VBAT Voltage 0.43v PASSED
VBAT Voltage 5.00v PASSED
Box VPP disabled
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Avaiable Physical Memory: 976.492MB
Avaiable Virtual Memory: 1.895GB
Avaiable Pagefile: 2.880GB
Initializing FBUS...
All initialized - Ready to work
Failed to read info -> Phone not detected
Processing C:\Program Files\Nokia\Phoenix\Products\...
Found 110 products, Filtering DCT4 Products - wait...
18 Products left after filtering. Ready.
Retrieving Variants for Product RM-769 - wait...
156 Variants Retrieved
Processing pre-flash tasks...
Pre-flash tasks finished
Checking rm769_006.650...
Booting X-Gold via ASC (press power-on if used non-battery cable)...
X-Gold: Ready, MCU ID: 0x3400
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Default_RAM_Bootloader
[EBL] : Ready
Setting Baudrate to 921600bps...
Baudrate Accepted (921600bps)
Flash Chip 0x00EC2404, Samsung, Size: 16MBytes
Processing "hw_f3_rm769_r06.650.fls"...
Erasing 0x00000000-0x0001FFFF...
Flashing at 0x00000000...
Flashed 24576 bytes OK
Erasing 0x00800000-0x00BFFFFF...
Flashing at 0x00800000...
Flashed 4128768 bytes OK
Erasing 0x00C5D000-0x00E5FFFF...
Flashing at 0x00C5D000...
Flashed 1697536 bytes OK
Box VPP disabled
Checking rm7690_nai06.65mc...
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Processing "hw_f3_rm7690_nai06.65mc.fls"...
Erasing 0x00E60000-0x00F5FFFF...
Flashing at 0x00E60000...
Flashed 712832 bytes OK
Box VPP disabled
Checking rm769_006.65mc...
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Processing "hw_f3_rm769_006.65mc.fls"...
Erasing 0x00100000-0x007FFFFF...
Flashing at 0x00100000...
Flashed 5243072 bytes OK
Box VPP disabled
Processing post-flash tasks...
Setting Factory Defaults...
Factory defaults OK
Post-flash tasks finished...
Flash successfully finished!
The Following User Says Thank You to .::SoFtWaRe ZoNe::. For This Useful Post:
Put in this thread all successfull phones unlocked with micro-box hitibiti Basic Micro-Box Software Support 1728 06-17-2013 12:38
Put in this thread all successfull story of Dct4 Imei???? with Mxkey mobilecitycbk MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 06-17-2009 21:28
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box FullFLASHgSMPH Cyclonebox 2 04-13-2009 14:00
Page generated in 0.91248 seconds with 12 queries
