Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 12-24-2012, 18:54   #2881 (permalink)
Member: 98928
110 rm-827 flashing & reset ok
HER THE LOG:
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
[Nokia USB Flashing Generic]: Port opened OK!
Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only
Booting CMT...
XGold223 ROM Detected
Failed to Boot CMT -> Failed to get First Boot Block
Prepare phone failed with message -> Failed to Boot CMT
Failed to Create RPL from phone -> Failed to Boot / Prepare Phone
RPL backup thread finished, continuing...
Pre flash tasks finished, continuing...
Processing rm827__03.28.mcusw (XGold2)...
Checking rm827__03.28.mcusw...
Flash file sorted Okay.
1 file(s) embedded into image.
Booting X-Gold via USB...
If PC Can't detect any new device, probably your phone is erased. Do following if needed:
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
X-Gold: Ready, MCU ID Block: 1FB300020303010100FF
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Quantum_Bootloader_10.49_M1S1
[EBL] : Ready
Setting Baudrate to 6500000bps...
Baudrate Accepted (6500000bps)
Flash Chip 0x00898982, Intel, Size: 64MBytes
Processing "rm827__03.28.mcusw_ebl_psi.fls"...
Sending Certificate...
Certificate Accepted
Erasing 0x40000000-0x4001FFFF...
Flashing at 0x40000000...
Flashed 131072 bytes OK
Erasing 0x40040000-0x4005FFFF...
Flashing at 0x40040000...
Erasing 0x40060000-0x4015FFFF...
Flashing at 0x40060000...
Flashed 1048576 bytes OK
Erasing 0x40280000-0x41BBFFFF...
Failed to Process E-Gold Command -> EBL Transaction Problem, Failed to Write Packet
Failed to process Image File -> Get Erase Status Command not accepted, May be Physical Chip Error.
Failed to Process all Image files -> Failed to process Image File
Backing up RPL...
Booting CMT...
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Flashing at 0x40280000...
Flashed 25952256 bytes OK
Erasing 0x43E20000-0x43E5FFFF...
Processing rm827__03.28.ppm_m3 (XGold2)...
Checking rm827__03.28.ppm_m3...
Processing "package_m3.ppm_ebl_psi.fls"...
Erasing 0x41BC0000-0x421BFFFF...
Flashing at 0x41BC0000...
Flashed 3119228 bytes OK
Processing rm827__03.28.image_m3_059N2R4_v2 (XGold2)...
Checking rm827__03.28.image_m3_059N2R4_v2...
Processing "package_m3_059N2R4.image.fls"...
Erasing 0x421C0000-0x43E1FFFF...
Flashing at 0x421C0000...
Flashed 15728640 bytes OK
Erasing 0x43E60000-0x43F3FFFF...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
[Nokia C2-00 USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version	V 03.28
MCU Date	13-07-12
Product		RM-827 (Nokia RM-827)
Manufacturer	(c) Nokia
IMEI		354150051912546
Mastercode	7463404054
IMEI Spare	3A45510015195204
IMEI SV		3345510015195214F1000000
PPM		V 03.28, 13-07-12, RM-827, (c) Nokia            , M3
CNT		Content: m3_059N2R4, V 03.28, 13-07-12, RM-827, (c) Nokia
PSN		5BCAD86BI
Product Code	059N2R4
Module Code	0205081
Basic Product Code	059K3X3
PSD		0000000000000000
LPSN		0
HW		2100
RFIC		68
LCD		TPO
BT		19b5-22012
Asic		11
HW Signature	6D2EE56FFF8DAC02
Simlock Server	SIMLOCK SERVER
Simlock Key	0010100000000000
Simlock Profile	800000000004000B
Simlock Aux	000B0000
Simlock IMEI	00003541500519125400
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [1,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [1,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [1,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [1,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [2,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [2,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [2,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [2,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [3,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [3,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [3,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [3,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [3,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [4,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [4,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [4,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [4,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [4,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [5,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [5,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [5,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [5,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [5,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [6,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [6,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [6,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [6,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [6,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [7,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [7,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [7,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [7,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [7,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Old 12-25-2012, 16:13   #2882 (permalink)
Member: 98928
nokia 700 rm-670 flashing ok
her the log:
[Nokia 700 USB Phonet]: Port opened OK!
MCU Version	V 79u_sr2_12w09_4
MCU Date	29-03-12
Product		RM-670 (Nokia 700)
IMEI		351956050420007
Mastercode	15526565
IMEI Spare	3A15590605240000
IMEI SV		3315590605240010F8000000
PSN		C7G965196
Product Code	059G1Q9
Module Code	0204685
Basic Product Code	059H178
LPSN		0
WLAN MAC	3C363D1A0A7C
APE SW		112.010.1404
APE Variant	112.010.1404112.010.1404.10.01112.010.1404.C00.01
APE Test		0.041
APE HW		256
APE ADSP	256
APE BT		HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 2576.
RETU		40
TAHVO		00
AHNE		21
HW		1006
RFIC		|Alli_4.b.1
DSP		79u_sr2_12w09
Simlock Key	2440700000000000
Simlock Profile	0000000000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Auto Selecting Flash Files on User Request...
Product Code: 059G1Q9
This is Valid BB5 Product
Retrieving Variants for Product RM-670 - wait...
1 Variants Retrieved
No variant found with given Product Code, selecting first one
Backing up RPL...
Storing Product Code...
Storing PSN...
Storing HWID...
Trying to store Simlock...
Reading Configuration Key...
Hashing...
Reading SHA1-RSA Signature...
Reading SHA1-HMAC Signature...
Storing Simlock...
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
Reading Security Block...
Security block OK and saved to "RM-670_351956050420007_12252012_060634 ã.SecurityBlock.PM"
WARNING: "0C390000FFFB7C4059EB27E6734CBCF4CC3DC37E.C0000B47" Not Exists, Will read it...
Reading CYC file from phone...
Booting CMT...
Switching to RAW Mode...
Old ROM Detected
CMT_SYSTEM_ASIC_ID:	000000030000022600010007400C192103032108
CMT_EM_ASIC_ID:		00001040
CMT_EM_ASIC_ID:		00001060
CMT_PUBLIC_ID:		0C390000FFFB7C4059EB27E6734CBCF4CC3DC37E
CMT_ASIC_MODE_ID:	00
CMT_ROOT_KEY_HASH:	3AB5DB70B45D23F1ADEEBB5734160706
CMT_BOOT_ROM_CRC:	2CAC45E2
CMT_SECURE_ROM_CRC:	3BC33C8B
CMT Ready!
RAPUv21_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.16.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Waiting for USB Boot ROM Answer...
ROM Ret: 0xFFFD125D
ROM CMT dwAddr: 0x10004FF0
ROM CMT dwLength: 0x00627837
Seems ROM Initialized OK!
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC006000000032, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
Sending Auxiliary Loader...
Auxiliary Loader Sent!
Loader: RAPxx CommonBoot v1.07 (C) 2011 KarwosLabs
Custom loader running OK! Working...
If phone doesn't powering into Local Mode now for some reason do following:
1. Re-insert battery
2. Power it on, when asked use Ovi/Pc Suite Mode
Readed OK, Saving to "0C390000FFFB7C4059EB27E6734CBCF4CC3DC37E.C0000B47"
Storing Additional Data...
Checking Superdongle Key...
Encrypting Superdongle Key...
Storing Superdongle Key...
Checking CMLA Key...
Storing CMLA Key...
Booting CMT...
Old ROM Detected
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPUv21_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5
ROM Ret: 0xFFFD125D
FlashChip 0x00EC0060 (Samsung), Size: 1024MBytes, VPP: Not Supported
RAPUv21_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Box TX2 Data Pin set to: Service Pin 3
Waiting for FUR Client become avaiable...
FUR Avaiable!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: BD43E84B21F8AC7B9C66EA939355891E2A08044A
APE Subsystem Not Found
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
Storing PARTNERC...
Restarting MCU...
RPL Saved OK
Processing RM-670_113.010.1506_79u_prd.core.fpsx (CMT)...
Booting CMT...
Old ROM Detected
CMT Ready!
RM-670_113.010.1506_79u_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
ROM Ret: 0xFFFD125D
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND
EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND
EraseArea[0,CMT]: 0x010C0000-0x170FFFFF, ONENAND
EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 2.464s
Writing all blocks...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS+PMML Certificate...
Writing CMT SOS+DECOMP Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT SOS+IVE3A Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT LDSP Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 24.383s
Flashing Speed: 45780.12 kBit/S
Processing RM-670_113.010.1506_79u_prd.core.fpsx (APE)...
Processing RM-670_113.010.1506_10.01_MEA_A_79u_prd.rofs2.fpsx (CMT)...
RM-670_113.010.1506_10.01_MEA_A_79u_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x0D1C0000-0x135BFFFF, ONENAND
Erase taken 0.422s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 9.484s
Flashing Speed: 50158.84 kBit/S
Processing RM-670_113.010.1506_10.01_MEA_A_79u_prd.rofs2.fpsx (APE)...
Processing RM-670_113.010.1506_C00.01_79u_prd.rofs3.fpsx (CMT)...
RM-670_113.010.1506_C00.01_79u_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x01678000-0x0169FFFF, ONENAND
EraseArea[0,CMT]: 0x135C0000-0x170FFFFF, ONENAND
Erase taken 0.343s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
Writing CMT SOS+IVE3B Certificate...
All blocks written OK! Time taken 0.546s
Flashing Speed: 323.53 kBit/S
Processing RM-670_113.010.1506_C00.01_79u_prd.rofs3.fpsx (APE)...
Processing RM-670_113.010.1506_U03.01_79u.uda.fpsx (CMT)...
RM-670_113.010.1506_U03.01_79u.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x17100000-0x2E0FFFFF, ONENAND
Erase taken 1.420s
TurboCache Loaded!
All blocks written OK! Time taken 31.590s
Flashing Speed: 50567.50 kBit/S
Processing RM-670_113.010.1506_U03.01_79u.uda.fpsx (APE)...
Restarting MCU...
Factory defaults OK
Reading info...
MCU Version	V 79u_sr2_12w20.8
MCU Date	20-08-12
Mastercode	15526565
IMEI SV		3315590605240030F0000000
PSN		C7G965196
Module Code	0204685
LPSN		0
APE SW		113.010.1506
APE Variant	113.010.1506113.010.1506.10.01113.010.1506.C00.01
APE Test		0.041
APE HW		256
APE ADSP	256
APE BT		HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.
RETU		40
TAHVO		00
AHNE		21
HW		1006
RFIC		|Alli_4.b.1
DSP		79u_sr2_12w20_2
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Old 12-26-2012, 15:41   #2883 (permalink)
dapx's Avatar
Member: 1064967
Unlock C3-00 RM-614
[Nokia C3-00 USB Phonet]: Port opened OK!
MCU Version	V 08.63
MCU Date	25-03-11
Product		RM-614 (Nokia C3-00)
IMEI		35193505
Mastercode	253333757
IMEI Spare	3A15390505959100
IMEI SV		3315390505959130F2000000
PPM		V 08.63, 25-03-11, RM-614, (c) Nokia            , L
CNT		Content: claro AR v3, V 08.63, 25-03-11, RM-614, (c) Nokia
PSN		CGP024595
Product Code	059C238
Module Code	0204418
Basic Product Code	0587486
LPSN		0
WLAN MAC	045A95330BC6
HW		4000
RFIC		9
LCD		SEIKO
BT		4217-v529
Simlock Key	7223100000000000
Simlock Profile	8000000000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 722310
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 74810F
Simlock [3,1]	State: CLOSED	Type: MCC-MNC	Data: 74402F
oclHashCat Format Detected
COD File Seems to be Valid, Calculating...
Codes for IMEI: 35193505
#pw+554093098512940+1#
#pw+114929307270995+2#
#pw+592467420058482+3#
#pw+956282080292712+4#
#pw+021055871501407+5#
#pw+590868690050830+6#
#pw+                        +7#
Sending BB5 NCK Code...
NCK[7] - ACCEPTED
MCU Version	V 08.63
MCU Date	25-03-11
IMEI		35193505
PSN		CGP024595
Module Code	0204418
LPSN		0
HW		4000
RFIC		9
LCD		SEIKO
BT		4217-v529
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 722310
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 74810F
Simlock [3,1]	State: OPENED	Type: MCC-MNC	Data: 74402F
Simlock NCK	#pw+7To734520874380+7#
Unlock C3-00 RM-614
MCU Version	V 08.63
MCU Date	25-03-11
IMEI		359301048
Mastercode	1723766032
IMEI Spare	3A95030184674809
IMEI SV		3395030184674839F2000000
PSN		CD20E5FAI
Product Code	059K4P4
Module Code	0204418
Basic Product Code	059D7P2
LPSN		0
WLAN MAC	9CCAD96F67CC
HW		2010
RFIC		9
LCD		SEIKO
BT		4217-v529
Simlock Key	7220700000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 72207F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 21407F
Simlock [3,1]	State: CLOSED	Type: MCC-MNC	Data: 21402F
Simlock [4,1]	State: CLOSED	Type: MCC-MNC	Data: 73002F
Simlock [5,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 732123
Simlock [6,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ E000	Data: 740FFF
Simlock [7,1]	State: CLOSED	Type: MCC-MNC	Data: 70604F
Simlock [8,1]	State: CLOSED	Type: MCC-MNC	Data: 70403F
Simlock [9,1]	State: CLOSED	Type: MCC-MNC	Data: 33403F
Simlock [10,1]	State: CLOSED	Type: MCC-MNC	Data: 71030F
Simlock [11,1]	State: CLOSED	Type: MCC-MNC	Data: 71402F
Simlock [12,1]	State: CLOSED	Type: MCC-MNC	Data: 71606F
Simlock [13,1]	State: CLOSED	Type: MCC-MNC	Data: 74807F
Simlock [14,1]	State: CLOSED	Type: MCC-MNC	Data: 73404F
Codes for IMEI: 359301048
#pw+701287437435575+1#
#pw+613871139864964+2#
#pw+855759555144188+3#
#pw+579076323045867+4#
#pw+955769425900753+5#
#pw+617049770769283+6#
#pw+                        +7#
NCK[7] - ACCEPTED
MCU Version	V 08.63
MCU Date	25-03-11
IMEI		359301048
PSN		CD20E5FAI
Module Code	0204418
LPSN		0
HW		2010
RFIC		9
LCD		SEIKO
BT		4217-v529
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 72207F
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 21407F
Simlock [3,1]	State: OPENED	Type: MCC-MNC	Data: 21402F
Simlock [4,1]	State: OPENED	Type: MCC-MNC	Data: 73002F
Simlock [5,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 732123
Simlock [6,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ E000	Data: 740FFF
Simlock [7,1]	State: OPENED	Type: MCC-MNC	Data: 70604F
Simlock [8,1]	State: OPENED	Type: MCC-MNC	Data: 70403F
Simlock [9,1]	State: OPENED	Type: MCC-MNC	Data: 33403F
Simlock [10,1]	State: OPENED	Type: MCC-MNC	Data: 71030F
Simlock [11,1]	State: OPENED	Type: MCC-MNC	Data: 71402F
Simlock [12,1]	State: OPENED	Type: MCC-MNC	Data: 71606F
Simlock [13,1]	State: OPENED	Type: MCC-MNC	Data: 74807F
Simlock [14,1]	State: OPENED	Type: MCC-MNC	Data: 73404F
Simlock NCK	#pw+9E4D94867713697+7#
Codes for IMEI: 3586280425
#pw+066925677757767+1#
#pw+691578878864768+2#
#pw+128181429014647+3#
#pw+105270268446641+4#
#pw+144058623393819+5#
#pw+563437216455882+6#
#pw+169352135XXXXXX+7#
Old 12-28-2012, 18:54   #2884 (permalink)
dapx's Avatar
Member: 1064967
Unlock X2-01 RM-709
[Nokia X2-01 USB Phonet]: Port opened OK!
MCU Version	V 08.63
MCU Date	25-03-11
Product		RM-709 (Nokia X2-01)
IMEI		358615042
Mastercode	4565715472
IMEI Spare	3A85160524899506
IMEI SV		3385160524899536F2000000
PPM		V 08.63, 25-03-11, RM-709, (c) Nokia            , L
CNT		Content: telecom AR SL SKD, V 08.63, 25-03-11, RM-709, (c) Nokia
PSN		052087DAY
Product Code	059K1C2
Module Code	0204674
Basic Product Code	059J9S5
LPSN		0
HW		1001
RFIC		9
LCD		SEIKO
BT		2.31-SP2.31
Simlock Key	7223400000000000
Simlock Key Cnt	2
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 72234F
Codes for IMEI: 358615042
#pw+501997484836635+1#
#pw+247946318378412+2#
#pw+460948316935698+3#
#pw+646683099872841+4#
#pw+908809317279298+5#
#pw+194503796325181+6#
#pw+                        +7#
NCK[7] - ACCEPTED
MCU Version	V 08.63
MCU Date	25-03-11
IMEI		358615042
PSN		052087DAY
Module Code	0204674
LPSN		0
HW		1001
RFIC		9
LCD		SEIKO
BT		2.31-SP2.31
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 72234F
Simlock NCK	#pw+3P>e27834255568+7#
Old 12-28-2012, 23:27   #2885 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
nokia 113 flashed with success...; )
Processing rm871__03.09.mcusw (XGold2)...
Checking rm871__03.09.mcusw...
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Flash Chip 0x00EC3012, Samsung, Size: 64MBytes
Processing "rm871__03.09.mcusw_ebl_psi.fls"...
Processing rm871__03.09.ppm_e2 (XGold2)...
Checking rm871__03.09.ppm_e2...
Processing "package_e2.ppm_ebl_psi.fls"...
Flashed 4080676 bytes OK
Processing rm871__03.09.image_e2_059N130_059P748_236_03 (XGold2)...
Checking rm871__03.09.image_e2_059N130_059P748_236_03...
Processing "rm871__03.09.image_e2_059N130_059P748_236_03.fls"...
Flashed 13893632 bytes OK
Factory defaults OK
Reading info...
Failed to read info -> Phone not detected
Last edited by ptt; 12-28-2012 at 23:38. Reason: MOVE TO THE RIGHT THREAD / PLACE & ADD [CODE] [/CODE] TAG TO THE LOG
Old 12-31-2012, 02:16   #2886 (permalink)
Member: 1680232
Sonork: 100.1611221
BB5 Unlock Started...
MCU Version	V 04.51
MCU Date	11-01-07
Product		RM-147 (Nokia 5300)
Manufacturer	(c) Nokia.
IMEI		354823010022983
Mastercode	707673332
Simlock Server	SIMLOCK SERVER VERSION 63
Simlock Key	3102000000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310160
Simlock [2,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310200
Simlock [3,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310210
Simlock [4,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310220
Simlock [5,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310230
Simlock [6,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310240
Simlock [7,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310250
Simlock [8,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310260
Simlock [9,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310270
Simlock [10,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310300
Simlock [11,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310310
Simlock [12,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310490
Simlock [13,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310530
Simlock [14,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310580
Simlock [15,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310590
Simlock [16,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310640
Simlock [17,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310660
Simlock [18,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310800
Security block OK and saved to "RM-147_354823010022983_12292012_33236 PM.SecurityBlock.PM"
WARNING: "0E400209B5605E564B74B6450113CDA596C5AE91.C000554C" Not Exists, Will read it...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006010C192101001101
CMT_EM_ASIC_ID:		00000232
CMT_EM_ASIC_ID:		00000352
CMT_PUBLIC_ID:		0E400209B5605E564B74B6450113CDA596C5AE91
CMT_ROOT_KEY_HASH:	BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC:	191EC665
CMT_SECURE_ROM_CRC:	DFAAF68F
CMT Ready!
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Old Loader Detected
Readed OK, Saving to "0E400209B5605E564B74B6450113CDA596C5AE91.C000554C"
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: NCK Calculation (new method)
#pw+274199686369918+1#
#pw+732661956923956+2#
#pw+084943355749409+3#
#pw+953360337359019+4#
#pw+157812075234668+5#
#pw+512621185893732+6#
#pw+860195167040573+7#
Sending NCK Codes..
NCK[1] - ACCEPTED
NCK[2] - Not locked on given lock level
NCK[3] - Not locked on given lock level
NCK[4] - Not locked on given lock level
NCK[5] - Unlocked Already
NCK[6] - Unlocked Already
NCK[7] - Unlocked Already
MCU Version	V 04.51
MCU Date	11-01-07
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310160
Simlock [2,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310200
Simlock [3,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310210
Simlock [4,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310220
Simlock [5,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310230
Simlock [6,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310240
Simlock [7,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310250
Simlock [8,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310260
Simlock [9,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310270
Simlock [10,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310300
Simlock [11,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310310
Simlock [12,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310490
Simlock [13,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310530
Simlock [14,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310580
Simlock [15,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310590
Simlock [16,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310640
Simlock [17,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310660
Simlock [18,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310800
Unlock finished! Time taken 10.516s
Last edited by ptt; 12-31-2012 at 20:52. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 12-31-2012, 05:26   #2887 (permalink)
Temporary banned !!
Member: 846616
Asha 311 Flash done by cyclone box
Backing up RPL...
Booting CMT...
Old ROM Detected
CMT_SYSTEM_ASIC_ID:    000000030000022600010007400C192103042108
CMT_EM_ASIC_ID:        00001051
CMT_PUBLIC_ID:        A2780080FFFB3C40DF2312820EFF08C87CED2F05
CMT_ROOT_KEY_HASH:    6D956B2D26FEC3C784E216492B7CC90A
CMT_SECURE_ROM_CRC:    1CB478AF
CMT Ready!
RAPUv21_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5
ROM Ret: 0xFFFD125D
FlashChip[0,CMT]: 0x00EC004000000241, Samsung, ONENAND
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
RAPUv21_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28
Storing NPC...
Storing CCC...
Storing HWC...
CMT PARTNERC Not Found
Restarting MCU...
RPL Saved OK
Processing rm714__05.92.mcusw (CMT)...
Booting CMT...
[Nokia USB Phonet]: Port opened OK!
Old ROM Detected
CMT Ready!
rm714__05.92.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6
ROM Ret: 0xFFFD125D
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00040000-0x000403FF, ONENAND
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, ONENAND
EraseArea[0,CMT]: 0x00140000-0x004BFFFF, ONENAND
EraseArea[0,CMT]: 0x004C0000-0x0073FFFF, ONENAND
EraseArea[0,CMT]: 0x00740000-0x0173FFFF, ONENAND
EraseArea[0,CMT]: 0x00160000-0x0017FFFF, ONENAND
EraseArea[0,CMT]: 0x03E40000-0x0447FFFF, ONENAND
EraseArea[0,CMT]: 0x0F080000-0x0F67FFFF, ONENAND
EraseArea[0,CMT]: 0x01740000-0x02ABFFFF, ONENAND
EraseArea[0,CMT]: 0x02AC0000-0x02F3FFFF, ONENAND
Erase taken 0.657s
TurboCache Loaded!
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Writing CMT MCUSW1 Certificate...
Writing CMT ISA+DYNSW Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT ISA+EXTDRV Certificate...
All blocks written OK! Time taken 6.640s
Flashing Speed: 42110.94 kBit/S
Processing rm714__05.92.mcusw (APE)...
Processing rm714__05.92.ppm_v (CMT)...
rm714__05.92.ppm_v, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x02F40000-0x03E3FFFF, ONENAND
Erase taken 0.110s
TurboCache Loaded!
All blocks written OK! Time taken 2.172s
Flashing Speed: 48609.68 kBit/S
Processing rm714__05.92.ppm_v (APE)...
Processing rm714__05.92.image_v_059F7P9 (CMT)...
rm714__05.92.image_v_059F7P9, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x04480000-0x0F07FFFF, ONENAND
Erase taken 2.484s
TurboCache Loaded!
All blocks written OK! Time taken 10.125s
Flashing Speed: 65378.58 kBit/S
Processing rm714__05.92.image_v_059F7P9 (APE)...
Restarting MCU...
Factory defaults OK
Last edited by ptt; 12-31-2012 at 20:54. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 12-31-2012, 13:47   #2888 (permalink)
dapx's Avatar
Member: 1064967
Unlock 5230 RM-594
MCU Version	V ICPR72_10w21.3.1
MCU Date	08-09-10
Product		RM-594 (Nokia 5230)
IMEI		3548270406
Mastercode	22371644
IMEI Spare	3A45280704960906
IMEI SV		3345280704960916F6000000
CNT		21.2.103_001_U295
PSN		0B6EF72AA
Product Code	0596628
Module Code	0204358
Basic Product Code	0584531
LPSN		0
APE SW		V 21.2.103
APE Variant	V 21.2.103V 21.2.103 21.2.103.295.01
APE Test		09wk43v0.060_4GBit
APE HW		256
APE ADSP	256
RETU		16
TAHVO		22
AHNE		11
HW		0522
RFIC		17141716
DSP		ICPR72_10w16p1
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 74402F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 74402F
Simlock [3,1]	State: CLOSED	Type: 3F007F206F07FFFF @ FC00	Data: 722310
Simlock [4,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 722310
Simlock [5,1]	State: CLOSED	Type: MCC-MNC	Data: 74810F
Simlock [6,1]	State: CLOSED	Type: MCC-MNC	Data: 74810F
Codes for IMEI: 3548270406
#pw+574599615566597+1#
#pw+127984839219646+2#
#pw+125615487748595+3#
#pw+785399074074894+4#
#pw+355702103855394+5#
#pw+566224131969407+6#
#pw+                        +7#
NCK[7] - ACCEPTED
MCU Date	08-09-10
IMEI		3548270406
Mastercode	22371644
PSN		0B6EF72AA
Module Code	0204358
LPSN		0
APE SW		V 21.2.103
APE HW		256
APE ADSP	256
RETU		16
TAHVO		22
AHNE		11
HW		0522
RFIC		17141716
DSP		ICPR72_10w16p1
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 74402F
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 74402F
Simlock [3,1]	State: OPENED	Type: 3F007F206F07FFFF @ FC00	Data: 722310
Simlock [4,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 722310
Simlock [5,1]	State: OPENED	Type: MCC-MNC	Data: 74810F
Simlock [6,1]	State: OPENED	Type: MCC-MNC	Data: 74810F
Simlock NCK	#pw+9=s‡75327091151+7#
Unlock C2-02 RM-693
[Nokia C2-02 USB Phonet]: Port opened OK!
MCU Version	V 06.52
MCU Date	19-07-11
Product		RM-693 (Nokia C2-02.1)
IMEI		012630004
Mastercode	2077314341
IMEI Spare	0A21360040404404
IMEI SV		0321360040404404F2000000
PPM		V 06.52, 19-07-11, RM-692, (c) Nokia            , L
CNT		Content: claro AR SKD, V 06.52, 19-07-11, RM-692, (c) Nokia
PSN		D766BD1AI
Product Code	059L6T7
Module Code	0205119
Basic Product Code	059L556
LPSN		0
HW		2501
RFIC		Dummy RFIC version
LCD		TPO
BT		19b5-22012
Asic		11
HW Signature	79E582B69BFB953E
Simlock Profile	800000000003000B
Simlock IMEI	00000126300040444400
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Codes for IMEI: 012630004
#pw+939953091704249+1#
#pw+243675614584301+2#
#pw+573489088838836+3#
#pw+052989391797023+4#
#pw+659653247499926+5#
#pw+359201055211302+6#
#pw+                        +7#
MCU Version	V 06.52
MCU Date	19-07-11
IMEI		012630004
PSN		D766BD1AI
Module Code	0205119
LPSN		0
HW		2501
LCD		TPO
BT		19b5-22012
Asic		11
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Old 01-03-2013, 08:49   #2889 (permalink)
Member: 320205
Thumbs up N302 Flesh done
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C000310D
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40
Initializing security card...
Card Serial Number: D7000222
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage	4.82v	PASSED
MCU Voltage	3.32v	PASSED
Core Voltage	1.75v	PASSED
VBAT Voltage	0.01v	PASSED
VBAT Voltage	4.78v	PASSED
Box VPP disabled
VPP Voltage	0.00v	PASSED
Internal Box VPP Enabled
VPP Voltage	4.79v	PASSED
Box VPP disabled
VPP Voltage	0.04v	PASSED
External Box VPP Enabled
VPP Voltage	0.04v	FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 1.676GB
Avaiable Virtual Memory: 1.889GB
Avaiable Pagefile: 3.628GB
Initializing FBUS...
All initialized - Ready to work
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Found 71 products, Filtering BB5 Products - wait...
30 Products left after filtering. Ready.
Found 71 products, Filtering DCT4 Products - wait...
10 Products left after filtering. Ready.
Retrieving Variants for Product RM-713 - wait...
Retrieving Variants for Product RM-813 - wait...
Backing up RPL...
Storing PSN...
Storing HWID...
Hashing...
Storing Simlock...
Reading Keys...
Storing WMDRM PD...
Security block OK and saved to "RM-813_353671051036912_132013_21441 PM.SecurityBlock.PM"
WARNING: "C47F0000FFFB3C40094C67CFAA936A557112A05A.C000310D" Not Exists, Will read it...
Booting CMT...
Old ROM Detected
CMT_PUBLIC_ID:		C47F0000FFFB3C40094C67CFAA936A557112A05A
CMT Ready!
ROM Ret: 0xFFFD125D
Readed OK, Saving to "C47F0000FFFB3C40094C67CFAA936A557112A05A.C000310D"
CMLA Key Store Problem -> Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Booting CMT...
Old ROM Detected
CMT Ready!
ROM Ret: 0xFFFD125D
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
Processing rm813__14.78.mcusw (CMT)...
Booting CMT...
Old ROM Detected
CMT Ready!
rm813__14.78.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6
ROM Ret: 0xFFFD125D
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00740000-0x0147FFFF, ONENAND
EraseArea[0,CMT]: 0x03200000-0x0387FFFF, ONENAND
EraseArea[0,CMT]: 0x01480000-0x0243FFFF, ONENAND
EraseArea[0,CMT]: 0x02440000-0x025BFFFF, ONENAND
Erase taken 0.594s
TurboCache Loaded!
All blocks written OK! Time taken 9.93s
Flashing Speed: 29397.68 kBit/S
Processing rm813__14.78.mcusw (APE)...
Processing rm813__14.78.ppm_mh2 (CMT)...
rm813__14.78.ppm_mh2, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x025C0000-0x031FFFFF, ONENAND
Erase taken 0.78s
TurboCache Loaded!
All blocks written OK! Time taken 1.657s
Flashing Speed: 32804.06 kBit/S
Processing rm813__14.78.ppm_mh2 (APE)...
Processing rm813__14.78.image_mh2_059L1D0 (CMT)...
rm813__14.78.image_mh2_059L1D0, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x03880000-0x0F07FFFF, ONENAND
Erase taken 2.610s
TurboCache Loaded!
All blocks written OK! Time taken 6.297s
Flashing Speed: 37761.19 kBit/S
Processing rm813__14.78.image_mh2_059L1D0 (APE)...
Restarting MCU...
Factory defaults OK
Reading info...
MCU Version	V 14.78
MCU Date	31-08-12
Product		RM-813 (Nokia RM-813)
IMEI		353671051036912
Mastercode	433075377
IMEI Spare	3A35760115309601
IMEI SV		3335760115309611F1000000
PPM		V 14.78, 31-08-12, RM-813, (c) Nokia            , MH2
CNT		Content: mh2_059L1D0, V 14.78, 31-08-12, RM-813, (c) Nokia
PSN		A702352AH
Product Code	059L1D0
Module Code	0205095
Basic Product Code	059J0F3
LPSN		0
WLAN MAC	F85F2AB884D3
RETU		51
TAHVO		00
AHNE		21
HW		1500
RFIC		|Alli_4.b.1
DSP		104_PM5_14.78
LCD		TPO
BT		4217-v924
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Nice cyclone Box Thanks
Last edited by ptt; 01-03-2013 at 11:15. Reason: MOVE TO THE RIGHT THREAD / PLACE & ADD [CODE] [/CODE] TAG TO THE LOG
Old 01-07-2013, 02:59   #2890 (permalink)
Member: 1069919
Nokia C3 (RM-614) ChAnGe EnGLisH to ArAbIc LaNgUaGe (Solved)
Nokia C3 (RM-614) Change English to Arabic Language!!!
Tools To Used:
CyCloNe Box
Usb Like Nokia 5310
Procedure:
Download firmware from (NAVIFIRM)
Then rUn Cyclone GUI,
fLash using Usb...
http://img832.imageshack.us/i/c3arabiclanguage.png
http://img543.imageshack.us/i/picture064k.jpg
http://img94.imageshack.us/i/picture065lb.jpg
http://img841.imageshack.us/i/picture066qm.jpg
Last edited by ptt; 01-08-2013 at 21:35. Reason: REMOVE [IMG] TAG -- IS BETTER IF YOU POST THE TXT LOG OF THE OPERATION AS ALL OTHERS DO
Old 01-08-2013, 07:46   #2891 (permalink)
Member: 1735447
Sonork: 100.1614319
E51 successfully Flashed Usb
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Initializing box...
Box Serial Number: C00080E4
HW Revision: C, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2011, wk01
Card Serial Number: D00C0281
Card Firmware Revision: 010A
Card is activated
Box is activated
USB Voltage    5.07v    PASSED
MCU Voltage    3.28v    PASSED
Core Voltage    1.80v    PASSED
VBAT Voltage    5.00v    PASSED
Box VPP disabled
VPP Voltage    0.02v    PASSED
VPP Voltage    4.97v    PASSED
Box VPP disabled
VPP Voltage    0.02v    FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
XGold/Blackberry Service Running, Counter: 94
Avaiable Physical Memory: 1.460GB
Avaiable Virtual Memory: 1.886GB
Avaiable Pagefile: 3.420GB
Found 78 products, Filtering BB5 Products - wait...
37 Products left after filtering. Ready.
Retrieving Variants for Product RM-244 - wait...
110 Variants Retrieved
Backing up RPL...
Phone not detected at USB -> Timeout, no any compatible USB device detected.
Booting CMT...
BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected.
Failed to Boot CMT -> No compatible USB devices detected
Selecting USB Flashing Method...
Proceeding with Dead USB Mode
Press power-on shortly to run USB Boot ROM
Failed to Process all Image files -> Failed to prepare BB5 USB Flashing
Backing up RPL...
Booting CMT...
Failed to prepare BB5 USB Connection -> USB Boot ROM Not detected, timeout
Old ROM Detected
CMT_SYSTEM_ASIC_ID:    000000010000022600010006400C192101021103
CMT_EM_ASIC_ID:        00000295
CMT_EM_ASIC_ID:        00000B22
CMT_PUBLIC_ID:        1EC000120ABD0058C481CE2EE8E471D28845C0EA
CMT_ROOT_KEY_HASH:    CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC:    A8C1D671
CMT_SECURE_ROM_CRC:    3E691FF8
DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5
Sending RAW Loader...
DeadUSB.alg, Type: Algorithm, Rev: , Algo: XSR 1.5
Sending CMT RAW Algorithm...
[Nokia BB5 ADL Loader USB Generic]: Port opened OK!
ADL Server Startup Confirmed OK!
Processing rm244_3003456_prd.c00 (CMT)...
rm244_3003456_prd.c00, Type: Flash Image, Algo: BB5, XSR 1.5
Partitioning...
Partitioning OK
Started flash erase
EraseArea[0,CMT]: 0x00040000-0x007FFFFF, ONENAND
EraseArea[0,CMT]: 0x00A00000-0x068FFFFF, ONENAND
Erase taken 1.360s
TurboCache Loaded!
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
Writing CMT SOS*CORE Certificate...
Writing CMT SOS+ROFS Certificate...
All blocks written OK! Time taken 70.109s
Flashing Speed: 6403.97 kBit/S
Processing rm244_3003456_prd.v01 (CMT)...
rm244_3003456_prd.v01, Type: Flash Image, Algo: BB5, XSR 1.5
Started flash erase
EraseArea[0,CMT]: 0x04A00000-0x068FFFFF, ONENAND
Erase taken 0.375s
TurboCache Loaded!
Writing CMT SOS+ROFX Certificate...
All blocks written OK! Time taken 28.203s
Flashing Speed: 6181.53 kBit/S
Processing rm244_3003456.01U (CMT)...
rm244_3003456.01U, Type: Flash Image, Algo: BB5, XSR 1.5
Started flash erase
Erase taken 0.16s
TurboCache Loaded!
All blocks written OK! Time taken 5.188s
Flashing Speed: 5942.72 kBit/S
Restarting CMT...
[Nokia E51 USB Phonet]: Port opened OK!
Factory defaults OK
Old 01-08-2013, 08:59   #2892 (permalink)
Member: 1735447
Sonork: 100.1614319
C1-01 Flashed
Initializing box...
Box Serial Number: C00080E3
Card Serial Number: D00C0231
Card is activated
Box is activated
VBAT Voltage	5.01v	PASSED
Box VPP disabled
VPP Voltage	4.95v	PASSED
Box VPP disabled
Box VPP disabled
Avaiable Physical Memory: 1.857GB
Avaiable Pagefile: 3.841GB
Processing rm607__06.05.mcusw (XGold2)...
Checking rm607__06.05.mcusw...
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Quantum_Bootloader_2.5_M1S1
[EBL] : Ready
Processing "rm607__06.05.mcusw_ebl_psi.fls"...
Erasing 0x40040000-0x4007FFFF...
Flashed 262144 bytes OK
Erasing 0x40080000-0x4009FFFF...
Flashing at 0x40080000...
Erasing 0x400A0000-0x4019FFFF...
Flashing at 0x400A0000...
Erasing 0x40400000-0x41BFFFFF...
Flashing at 0x40400000...
Flashed 24641536 bytes OK
Processing rm607__06.05.ppm_mi (XGold2)...
Checking rm607__06.05.ppm_mi...
Processing "package_mi.ppm_ebl_psi.fls"...
Erasing 0x41C00000-0x421FFFFF...
Flashing at 0x41C00000...
Flashed 3186904 bytes OK
Processing rm607__06.05.image_mi_059J840 (XGold2)...
Checking rm607__06.05.image_mi_059J840...
Processing "package_mi_059J840.image.fls"...
Erasing 0x42200000-0x43E5FFFF...
Flashing at 0x42200000...
Flashed 13107200 bytes OK
[Nokia C1-01 USB Phonet]: Port opened OK!
Factory defaults OK
Old 01-11-2013, 13:56   #2893 (permalink)
dapx's Avatar
Member: 1064967
Unlock N8 RM-596
[Nokia N8-00 USB Phonet]: Port opened OK!
MCU Version	V 92_11w25.1
MCU Date	01-07-11
Product		RM-596 (Nokia N8)
IMEI		351661050826415
Mastercode	7256127354
IMEI Spare	3A15660105284601
IMEI SV		3315660105284611F8000000
PSN		MJO231908
Product Code	059G132
Basic Product Code	059F9M3
LPSN		0
WLAN MAC	943AF0D340D9
APE SW		022.014
APE Variant	022.014022.014.33.01022.014.350.05
APE Test		0.148
APE HW		256
APE ADSP	256
RETU		40
TAHVO		00
AHNE		11
HW		7477
RFIC		|Alli_4.3.4
DSP		92_11w25
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 72234F
Codes for IMEI: 351661050826415
#pw+156311040639944+1#
#pw+393353924668526+2#
#pw+283133325217959+3#
#pw+625987087495852+4#
#pw+307191173805930+5#
#pw+610672656633537+6#
#pw+731448526127217+7#
NCK[7] - ACCEPTED
MCU Date	01-07-11
PSN		MJO231908
LPSN		0
APE SW		022.014
APE Test		0.148
APE HW		256
APE ADSP	256
RETU		40
TAHVO		00
AHNE		11
HW		7477
RFIC		|Alli_4.3.4
DSP		92_11w25
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 72234F
Simlock NCK	#pw+73c\48526127217+7#
Unlock 5230 RM- 594
MCU Date	08-09-10
IMEI		354827042
Mastercode	706747770
IMEI Spare	3A45280724996503
IMEI SV		3345280724996513F6000000
CNT		21.2.103_002_U540
PSN		1EE7AF9AA
Product Code	059F3B8
Module Code	0204736
Basic Product Code	059D997
LPSN		0
APE SW		V 21.2.103
APE Variant	V 21.2.103V 21.2.103 21.2.103.540.04
APE HW		256
APE ADSP	256
RETU		16
TAHVO		22
AHNE		11
HW		0822
RFIC		17141716
DSP		ICPR72_10w16p1
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Codes for IMEI: 354827042
#pw+147864624254935+1#
#pw+472384371247909+2#
#pw+474562716844903+3#
#pw+010996817440731+4#
#pw+808095618556278+5#
#pw+207843563475820+6#
#pw+                         +7#
NCK[7] - ACCEPTED
MCU Date	08-09-10
IMEI		354827042
PSN		1EE7AF9AA
Module Code	0204736
LPSN		0
APE SW		V 21.2.103
APE HW		256
APE ADSP	256
RETU		16
TAHVO		22
AHNE		11
HW		0822
RFIC		17141716
DSP		ICPR72_10w16p1
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock NCK	#pw+2fzO46984798425+7#
Unlock 5130 RM-495
MCU Version	V 07.95
MCU Date	03-02-10
Product		RM-495 (Nokia 5130 XpressMusic)
IMEI		35932902
Mastercode	67550774
IMEI Spare	3A95230932758900
IMEI SV		3395230932758940F8000000
PPM		V 07.95, 03-02-10, RM-495, (c) Nokia            , UA
Nokia            , ,
PSN		RFB508730
Product Code	0574258
Module Code	0204024
Basic Product Code	0567773
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		3000
RFIC		064c0601
DSP		ICPR72_10w01
LCD		SEIKO
BT		2222-302
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Codes for IMEI: 35932902
#pw+704924528950225+1#
#pw+457256194426394+2#
#pw+716914631127218+3#
#pw+661362866789848+4#
#pw+036870001079494+5#
#pw+250040075880911+6#
#pw+                        +7#
NCK[7] - ACCEPTED
MCU Version	V 07.95
MCU Date	03-02-10
IMEI		35932902
Mastercode	67550774
Nokia            , ,
PSN		RFB508730
Module Code	0204024
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		3000
RFIC		064c0601
DSP		ICPR72_10w01
LCD		SEIKO
BT		2222-302
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock NCK	#pw+1t7V64020320684+7#
Unlock 5130 RM-495
MCU Version	V 05.80
MCU Date	18-12-08
IMEI		356908032
Mastercode	6433327665
IMEI Spare	3A65090823850201
IMEI SV		3365090823850221F6000000
PPM		V 05.80, 18-12-08, RM-495, (c) Nokia            , UA
PSN		GEL140176
Product Code	0580923
Module Code	0204024
Basic Product Code	0567772
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		4000
RFIC		06540601
DSP		ICPR72_08w50
LCD		SEIKO
BT		2222-143C
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Codes for IMEI: 356908032
#pw+578669927461908+1#
#pw+608448086238194+2#
#pw+906703323658181+3#
#pw+508283641712751+4#
#pw+943863320938593+5#
#pw+827310888187526+6#
#pw+                        +7#
NCK[7] - ACCEPTED
MCU Version	V 05.80
MCU Date	18-12-08
IMEI		356908032
PSN		GEL140176
Module Code	0204024
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		4000
RFIC		06540601
DSP		ICPR72_08w50
LCD		SEIKO
BT		2222-143C
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock NCK	#pw+6g4d80830676264+7#
Unlock 5130 RM-495
MCU Version	V 05.80
MCU Date	18-12-08
IMEI		355232037
Mastercode	3551753
IMEI Spare	3A55320273591909
IMEI SV		3355320273591929F6000000
Nokia            , ,
PSN		GEK659388
Product Code	0580811
Module Code	0204024
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		4000
RFIC		06560601
DSP		ICPR72_08w50
LCD		SEIKO
BT		2222-143C
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Codes for IMEI: 355232037
#pw+497064942464679+1#
#pw+439555282946544+2#
#pw+198403133752059+3#
#pw+162458276579601+4#
#pw+743647476076173+5#
#pw+542201132025115+6#
#pw+                        +7#
NCK[7] - ACCEPTED
MCU Version	V 05.80
MCU Date	18-12-08
IMEI		355232037
Mastercode	3551753
Nokia            , ,
PSN		GEK659388
Module Code	0204024
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		4000
RFIC		06560601
DSP		ICPR72_08w50
LCD		SEIKO
BT		2222-143C
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Unlock 1616 RH-126
MCU Version	V 06.51
MCU Date	05-13-11
Product		RH-126 (Nokia 1616)
IMEI		01292000
Mastercode	1533104116
IMEI Spare	0A21290080642907
IMEI SV		0321290080642967F7000000
PPM		V 06.51, 05-13-11, RH-126, (c) Nokia, UB
PSN		GGZ875852
Product Code	059C1R3
Module Code	0204344
Basic Product Code	059J888
PSD		0000001800000000
HW		4003
UEM		1328
UPP		2292
LCD		WIN:BOHAIv9A, NT39121
ADSP Sw		p'V 06.51\n05-13-11\nRH-126\n(c) NMP\nub
Asic		11
HW Signature	181F1450F6846490
Simlock Server
Simlock IMEI	00000129200084692700
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Codes for IMEI: 01292000
#pw+989370143150217+1#
#pw+987098424190551+2#
#pw+972303336652627+3#
#pw+721478349835620+4#
#pw+384383088010847+5#
#pw+437468219936803+6#
#pw+                        +7#
NCK[7] - ACCEPTED
MCU Version	V 06.51
MCU Date	05-13-11
IMEI		01292000
PSN		GGZ875852
Module Code	0204344
HW		4003
UEM		1328
UPP		2292
Asic		11
Simlock Server
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Old 01-15-2013, 00:50   #2894 (permalink)
starXman's Avatar
Member: 111292
NK100 RH-130 Flashing OK
Hi friends,
just to report that nokia 100 rh-130 is correctly
flashed by fbus cable with cyclone box, as shows the following log:
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.1.923
Initializing box...
Box Serial Number: C0xxxxxx
2009, wk19
Card Serial Number: D7xxxxxx
Card is activated
Box is activated
USB Voltage	5,09v	PASSED
MCU Voltage	3,28v	PASSED
Core Voltage	1,78v	PASSED
VBAT Voltage	0,15v	PASSED
VBAT Voltage	5,04v	PASSED
Box VPP disabled
VPP Voltage	0,00v	PASSED
VPP Voltage	5,01v	PASSED
Box VPP disabled
VPP Voltage	0,02v	FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
XGold/Blackberry Service Running, Counter: 98
Avaiable Physical Memory: 2.97GB
Avaiable Virtual Memory: 1.431GB
Avaiable Pagefile: 3.1023GB
MCU Version	V 04.30
MCU Date	18-09-12
Product		RH-130 (Nokia RH-130)
IMEI		355195054835045
Mastercode	41721737
IMEI Spare	3A55910545380504
IMEI SV		3355910545380534F2000000
PPM		V 04.30, 18-09-12, RH-130, (c) Nokia, AD
PSN		D23848FAH
Product Code	059H2C9
Module Code	0204875
Basic Product Code	059R191
PSD		0000000D00000000
HW		1000
UEM		1328
UPP		2292
LCD		TPO:BARACOAv90, HX5081
ADSP Sw		p'V 04.30\n18-09-12\nRH-130\n(c) NMP\nad
Asic		11
HW Signature	FCAE74BA609BDDEA
Simlock Server
Simlock Profile	0000000000040002
Simlock IMEI	00003551950548350400
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Processing pre-flash tasks...
Pre-flash tasks finished
Checking rh130_004.400...
Booting X-Gold via ASC (press power-on if used non-battery cable)...
X-Gold: Ready, MCU ID: 0x3400
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Default_RAM_Bootloader
[EBL] : Ready
Setting Baudrate to 921600bps...
Baudrate Accepted (921600bps)
Flash Chip 0x00EC227A, Samsung, Size: 8MBytes
Processing "hw_f31_rh130_r04.400.fls"...
Erasing 0x00800000-0x00A0FFFF...
Flashing at 0x00800000...
Flashed 2162688 bytes OK
Erasing 0x00C60000-0x00EAFFFF...
Flashing at 0x00C60000...
Flashed 2217984 bytes OK
Erasing 0x00FFC000-0x00FFFFFF...
Flashing at 0x00FFC000...
Flashed 64 bytes OK
Box VPP disabled
Checking rh1300_nai04.40ag...
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Processing "hw_f31_rh1300_nai04.40ag.fls"...
Erasing 0x00EB0000-0x00F7FFFF...
Flashing at 0x00EB0000...
Flashed 358784 bytes OK
Box VPP disabled
Checking rh130_004.40ag...
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Processing "hw_f31_rh130_004.40ag.fls"...
Erasing 0x00210000-0x0045FFFF...
Flashing at 0x00210000...
Flashed 2165952 bytes OK
Box VPP disabled
Processing post-flash tasks...
Factory defaults OK
Post-flash tasks finished...
Flash successfully finished!
Cheers
Starxman.
Last edited by ptt; 01-15-2013 at 01:38. Reason: MOVE TO THE RIGHT THREAD / PLACE & ADD [CODE] [/CODE] TAG TO THE LOG
Old 01-17-2013, 08:43   #2895 (permalink)
Member: 1735447
Sonork: 100.1614319
Nokia 112 X Gold Flash...Cyclone
XGold/Blackberry Service Running, Counter: 92
Avaiable Physical Memory: 1.979GB
Avaiable Pagefile: 3.853GB
Backing up RPL...
Booting CMT...
Processing rm837__03.32.mcusw (XGold2)...
Checking rm837__03.32.mcusw...
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
Failed to process Image File -> BootROM not detected!
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Quantum_Bootloader_10.50_M1S1
[EBL] : Ready
Processing "rm837__03.32.mcusw_ebl_psi.fls"...
Processing rm837__03.32.ppm_s1 (XGold2)...
Checking rm837__03.32.ppm_s1...
Processing "package_s1.ppm_ebl_psi.fls"...
Flashed 4144008 bytes OK
Processing rm837__03.32.image_s1_059P4W2 (XGold2)...
Checking rm837__03.32.image_s1_059P4W2...
Processing "package_s1_059P4W2.image.fls"...
Flashed 16646144 bytes OK
Factory defaults OK
Last edited by ptt; 01-17-2013 at 20:23. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Put in this thread all successfull phones unlocked with micro-box hitibiti Basic Micro-Box Software Support 1724 05-23-2013 12:17
Put in this thread all successfull story of Dct4 Imei???? with Mxkey mobilecitycbk MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 06-17-2009 21:28
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box FullFLASHgSMPH Cyclonebox 2 04-13-2009 14:00
Page generated in 0.78261 seconds with 12 queries
