09-17-2014, 07:30 | #3016 (permalink) |
No Life Poster Join Date: May 2008 Location: saqi mobiles pirmahal pakistan Age: 37
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:32:14, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: ****** HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 5.07v PASSED MCU Voltage 3.26v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.03v PASSED VBAT Voltage 5.03v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.02v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 99 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 126.996MB Avaiable Virtual Memory: 1.898GB Avaiable Pagefile: 1.336GB Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... [Nokia USB Flashing Generic]: Port opened OK! Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! XGold223 ROM Detected Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT Failed to Create RPL from phone -> Failed to Boot / Prepare Phone RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing FEBD2E18_rm872__04.52.mcusw (XGold2)... Checking FEBD2E18_rm872__04.52.mcusw... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Flashing Generic]: Port opened OK! X-Gold: Ready, MCU ID Block: 1FB300020303010100FF [PBL] : Ready [EBL] : Mode CC [EBL] : Quantum_Bootloader_10.53_M1S1 [EBL] : Ready Setting Baudrate to 6500000bps... Baudrate Accepted (6500000bps) Flash Chip 0x00898982, Intel, Size: 64MBytes Processing "rm872__04.52.mcusw_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x40000000-0x4001FFFF... Flashing at 0x40000000... Flashed 131072 bytes OK Erasing 0x40040000-0x4005FFFF... Flashing at 0x40040000... Flashed 131072 bytes OK Erasing 0x40060000-0x4015FFFF... Flashing at 0x40060000... Flashed 1048576 bytes OK Erasing 0x40280000-0x41A7FFFF... Flashing at 0x40280000... Flashed 25165824 bytes OK Erasing 0x43E20000-0x43E5FFFF... Processing CC7A91E4_rm872__04.52.ppm_mh1 (XGold2)... Checking CC7A91E4_rm872__04.52.ppm_mh1... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_mh1.ppm_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x41A80000-0x420FFFFF... Flashing at 0x41A80000... Flashed 5109160 bytes OK Processing 3099529F_rm872__04.52.image_mh1_059Q317 (XGold2)... Checking 3099529F_rm872__04.52.image_mh1_059Q317... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_mh1_059Q317.image.fls"... Sending Certificate... Certificate Accepted Erasing 0x42100000-0x43E1FFFF... Flashing at 0x42100000... Flashed 18087936 bytes OK Erasing 0x43E60000-0x43F3FFFF... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia USB Flashing Generic]: Port opened OK! [Nokia X2-02 USB Phonet]: Port opened OK! [Nokia X2-02 USB Phonet]: Port opened OK! [Nokia X2-02 USB Phonet]: Port opened OK! [Nokia X2-02 USB Phonet]: Port opened OK! [Nokia X2-02 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia X2-02 USB Phonet]: Port opened OK! MCU Version V 04.52 MCU Date 30-06-13 Product RM-872 (Nokia 206) Manufacturer (c) Nokia IMEI 3559020545***** Mastercode 634547167 IMEI Spare 3A55090245958300 IMEI SV 335509*****58310F1000000 PPM V 04.52, 30-06-13, RM-872, (c) Nokia , MH1 CNT Content: mh1_059Q317, V 04.52, 30-06-13, RM-872, (c) Nokia PSN E56A8B7AH Product Code 059Q8L5 Module Code 0205283 Basic Product Code 059P5C3 PSD 0000000000000000 LPSN 0 HW 1600 RFIC 68 LCD TPO BT 19b5-22012 Asic 11 HW Signature DBAEA5868AED92D7 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000004000B Simlock Aux 000B0000 Simlock IMEI 00003559020545938000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
10-04-2014, 07:41 | #3017 (permalink) |
No Life Poster Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 226 | MCU Version V 09.55 MCU Date 12-11-09 Product RM-519 (Nokia RM-519) Manufacturer (c) Nokia IMEI 353425048865119 Mastercode 541562744 Setting Local Mode... Local mode Set Asic 11 HW Signature F90A53811C1F5582 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553534250488651100 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Autodetecting SP Type... Autodetection Finished Proceeding with RSA Unlock... Asking card to sign HW Signature... Signed OK (A7C8FA2D8362959CDE9D069D59DC5AF5608FB46E) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! |
10-08-2014, 19:10 | #3018 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Nokia asha 502 RM-921 flash success with cyclone box [Nokia USB Flashing Generic]: Port opened OK! XGold223 ROM Detected XGold223: Continuing Peripherial Booting... CMT_SYSTEM_ASIC_ID: 00000C2016100040 CMT_PUBLIC_ID: 550BB86A95DD51C149AA2009924A5422D25132A3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 125FC72605B5C4E48A9E0225084D2579 CMT_BOOT_ROM_CRC: 53588225 CMT_SECURE_ROM_CRC: 2F54C676 CMT Ready! Searching for BootCode: DualLine 32Bit XG223_v11_usb2nd.fg, Type: 2nd Boot Loader, Rev: 1024.12.30.1, Algo: XG223 Using NEW BB5 FLASHING PROTOCOL XGold223 2nd Boot Ready Searching for BootCode: DualLine 32Bit XG223_v11_usbalg.fg, Type: Algorithm, Rev: 1024.12.30.1, Algo: XG223_V0 ALG XGold223 Algo Ready Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7EC22006F565793C24924878FBAB9CA6CBE42C35 APE Subsystem Not Found Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found CMT PARTNERC Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing BCF760EF_rm921_14.0.6.mcusw.fpsx (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! XGold223 ROM Detected XGold223: Continuing Peripherial Booting... CMT_SYSTEM_ASIC_ID: 00000C2016100040 CMT_PUBLIC_ID: 550BB86A95DD51C149AA2009924A5422D25132A3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 125FC72605B5C4E48A9E0225084D2579 CMT_BOOT_ROM_CRC: 53588225 CMT_SECURE_ROM_CRC: 2F54C676 CMT Ready! BCF760EF_rm921_14.0.6.mcusw.fpsx, Type: Flash Image, Algo: XG223, XG223_V0 ALG Searching for BootCode: DualLine 32Bit XG223_v11_usb2nd.fg, Type: 2nd Boot Loader, Rev: 1024.12.30.1, Algo: XG223 Using NEW BB5 FLASHING PROTOCOL XGold223 2nd Boot Ready Searching for BootCode: DualLine 32Bit XG223_v11_usbalg.fg, Type: Algorithm, Rev: 1024.12.30.1, Algo: XG223_V0 ALG XGold223 Algo Ready Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7EC22006F565793C24924878FBAB9CA6CBE42C35 Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x40000000-0x4003FFFF, NOR EraseArea[0,CMT]: 0x47E00000-0x47E3FFFF, NOR EraseArea[0,CMT]: 0x40060000-0x426FFFFF, NOR EraseArea[0,CMT]: 0x47E40000-0x47F1FFFF, NOR Waiting 320s for erasure finish... Erase taken 16.115s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ISSW Certificate... Writing CMT MEMSET Certificate... Writing CMT PRIMAPP Certificate... Writing CMT LOADER Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 8.346s Flashing Speed: 33783.49 kBit/S Processing BCF760EF_rm921_14.0.6.mcusw.fpsx (APE)... Processing 867B5774_rm921_14.0.1_059S5Z8_i1_2007_01_451934.ro fs.fpsx (CMT)... 867B5774_rm921_14.0.1_059S5Z8_i1_2007_01_451934.ro fs.fpsx, Type: Flash Image, Algo: XG223, XG223_V0 ALG PAPUBKEYS Hash for CMT: 7EC22006F565793C24924878FBAB9CA6CBE42C35 Started group flash erase EraseArea[0,CMT]: 0x42700000-0x437FFFFF, NOR Waiting 320s for erasure finish... Erase taken 3.338s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT PPM Certificate... Programming Status OK! All blocks written OK! Time taken 2.168s Flashing Speed: 36273.18 kBit/S Processing 867B5774_rm921_14.0.1_059S5Z8_i1_2007_01_451934.ro fs.fpsx (APE)... Processing 49ACA51E_rm921_14.0.1_059S5Z8_i1_2007_01_451934.im age.fpsx (CMT)... 49ACA51E_rm921_14.0.1_059S5Z8_i1_2007_01_451934.im age.fpsx, Type: Flash Image, Algo: XG223, XG223_V0 ALG PAPUBKEYS Hash for CMT: 7EC22006F565793C24924878FBAB9CA6CBE42C35 Started group flash erase EraseArea[0,CMT]: 0x43800000-0x47DFFFFF, NOR Waiting 320s for erasure finish... Erase taken 21.793s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 6.333s Flashing Speed: 36593.29 kBit/S Processing 49ACA51E_rm921_14.0.1_059S5Z8_i1_2007_01_451934.im age.fpsx (APE)... Processing 6AF332F3_rm921_14.0.6_059S5Z8_i1_SD_4GB_2007_01_45 1934.fpsimage.fpsx (CMT)... 6AF332F3_rm921_14.0.6_059S5Z8_i1_SD_4GB_2007_01_45 1934.fpsimage.fpsx, Type: Flash Image, Algo: XG223, XG223_V0 ALG PAPUBKEYS Hash for CMT: 7EC22006F565793C24924878FBAB9CA6CBE42C35 Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 2.746s Flashing Speed: 109503.17 kBit/S Processing 6AF332F3_rm921_14.0.6_059S5Z8_i1_SD_4GB_2007_01_45 1934.fpsimage.fpsx (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia USB Phonet]: Port opened OK! MCU Version V 14.0.6 MCU Date 10-07-14 Product RM-921 (Nokia RM-921) Manufacturer (c) Nokia IMEI 3581490xxxxxxxxxxx Mastercode 4124306376 IMEI Spare 3A85410995963606 IMEI SV 3385410995963606F8000000 PPM 2191e29b766b31a18c2e5caa75ce5c0c00b57ae5 PSN 4F010ABBH Product Code 059V467 Module Code 0205563 Basic Product Code 059R5D3 PSD 0000000000000000 LPSN 0 WLAN MAC DCC79355BD25 APE Variant 0000000000000000000000000000000000000000 TAHVO RM-921-14.0.6-059V467-14.0.1-14.0.1 AHNE 4 HW 1000 UPP MFR:0xff,DEV:0xff1a,REV:0xf011 RFIC Integrated to main ASIC LCD TPO BT 0101-0.1.9 AEM 43362a2-5.96.13.0 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
The Following User Says Thank You to mubarak2344 For This Useful Post: |
10-08-2014, 19:12 | #3019 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Nokia asha 502 RM-921 flash success with cyclone box [Nokia USB Flashing Generic]: Port opened OK! XGold223 ROM Detected XGold223: Continuing Peripherial Booting... CMT_SYSTEM_ASIC_ID: 00000C2016100040 CMT_PUBLIC_ID: 550BB86A95DD51C149AA2009924A5422D25132A3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 125FC72605B5C4E48A9E0225084D2579 CMT_BOOT_ROM_CRC: 53588225 CMT_SECURE_ROM_CRC: 2F54C676 CMT Ready! Searching for BootCode: DualLine 32Bit XG223_v11_usb2nd.fg, Type: 2nd Boot Loader, Rev: 1024.12.30.1, Algo: XG223 Using NEW BB5 FLASHING PROTOCOL XGold223 2nd Boot Ready Searching for BootCode: DualLine 32Bit XG223_v11_usbalg.fg, Type: Algorithm, Rev: 1024.12.30.1, Algo: XG223_V0 ALG XGold223 Algo Ready Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7EC22006F565793C24924878FBAB9CA6CBE42C35 APE Subsystem Not Found Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found CMT PARTNERC Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing BCF760EF_rm921_14.0.6.mcusw.fpsx (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! XGold223 ROM Detected XGold223: Continuing Peripherial Booting... CMT_SYSTEM_ASIC_ID: 00000C2016100040 CMT_PUBLIC_ID: 550BB86A95DD51C149AA2009924A5422D25132A3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 125FC72605B5C4E48A9E0225084D2579 CMT_BOOT_ROM_CRC: 53588225 CMT_SECURE_ROM_CRC: 2F54C676 CMT Ready! BCF760EF_rm921_14.0.6.mcusw.fpsx, Type: Flash Image, Algo: XG223, XG223_V0 ALG Searching for BootCode: DualLine 32Bit XG223_v11_usb2nd.fg, Type: 2nd Boot Loader, Rev: 1024.12.30.1, Algo: XG223 Using NEW BB5 FLASHING PROTOCOL XGold223 2nd Boot Ready Searching for BootCode: DualLine 32Bit XG223_v11_usbalg.fg, Type: Algorithm, Rev: 1024.12.30.1, Algo: XG223_V0 ALG XGold223 Algo Ready Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7EC22006F565793C24924878FBAB9CA6CBE42C35 Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x40000000-0x4003FFFF, NOR EraseArea[0,CMT]: 0x47E00000-0x47E3FFFF, NOR EraseArea[0,CMT]: 0x40060000-0x426FFFFF, NOR EraseArea[0,CMT]: 0x47E40000-0x47F1FFFF, NOR Waiting 320s for erasure finish... Erase taken 16.115s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ISSW Certificate... Writing CMT MEMSET Certificate... Writing CMT PRIMAPP Certificate... Writing CMT LOADER Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 8.346s Flashing Speed: 33783.49 kBit/S Processing BCF760EF_rm921_14.0.6.mcusw.fpsx (APE)... Processing 867B5774_rm921_14.0.1_059S5Z8_i1_2007_01_451934.ro fs.fpsx (CMT)... 867B5774_rm921_14.0.1_059S5Z8_i1_2007_01_451934.ro fs.fpsx, Type: Flash Image, Algo: XG223, XG223_V0 ALG PAPUBKEYS Hash for CMT: 7EC22006F565793C24924878FBAB9CA6CBE42C35 Started group flash erase EraseArea[0,CMT]: 0x42700000-0x437FFFFF, NOR Waiting 320s for erasure finish... Erase taken 3.338s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT PPM Certificate... Programming Status OK! All blocks written OK! Time taken 2.168s Flashing Speed: 36273.18 kBit/S Processing 867B5774_rm921_14.0.1_059S5Z8_i1_2007_01_451934.ro fs.fpsx (APE)... Processing 49ACA51E_rm921_14.0.1_059S5Z8_i1_2007_01_451934.im age.fpsx (CMT)... 49ACA51E_rm921_14.0.1_059S5Z8_i1_2007_01_451934.im age.fpsx, Type: Flash Image, Algo: XG223, XG223_V0 ALG PAPUBKEYS Hash for CMT: 7EC22006F565793C24924878FBAB9CA6CBE42C35 Started group flash erase EraseArea[0,CMT]: 0x43800000-0x47DFFFFF, NOR Waiting 320s for erasure finish... Erase taken 21.793s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 6.333s Flashing Speed: 36593.29 kBit/S Processing 49ACA51E_rm921_14.0.1_059S5Z8_i1_2007_01_451934.im age.fpsx (APE)... Processing 6AF332F3_rm921_14.0.6_059S5Z8_i1_SD_4GB_2007_01_45 1934.fpsimage.fpsx (CMT)... 6AF332F3_rm921_14.0.6_059S5Z8_i1_SD_4GB_2007_01_45 1934.fpsimage.fpsx, Type: Flash Image, Algo: XG223, XG223_V0 ALG PAPUBKEYS Hash for CMT: 7EC22006F565793C24924878FBAB9CA6CBE42C35 Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 2.746s Flashing Speed: 109503.17 kBit/S Processing 6AF332F3_rm921_14.0.6_059S5Z8_i1_SD_4GB_2007_01_45 1934.fpsimage.fpsx (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia USB Phonet]: Port opened OK! MCU Version V 14.0.6 MCU Date 10-07-14 Product RM-921 (Nokia RM-921) Manufacturer (c) Nokia IMEI 358149xxxxxxxxxxx Mastercode 4124306376 IMEI Spare 3A85410995963606 IMEI SV 3385410995963606F8000000 PPM 2191e29b766b31a18c2e5caa75ce5c0c00b57ae5 PSN 4F010ABBH Product Code 059V467 Module Code 0205563 Basic Product Code 059R5D3 PSD 0000000000000000 LPSN 0 WLAN MAC DCC79355BD25 APE Variant 0000000000000000000000000000000000000000 TAHVO RM-921-14.0.6-059V467-14.0.1-14.0.1 AHNE 4 HW 1000 UPP MFR:0xff,DEV:0xff1a,REV:0xf011 RFIC Integrated to main ASIC LCD TPO BT 0101-0.1.9 AEM 43362a2-5.96.13.0 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
12-15-2014, 16:44 | #3020 (permalink) |
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 226 | MCU Version V 5.32 MCU Date 05-18-08 Product RH-106 (Nokia RH-106) Manufacturer (c) NMP IMEI 012142009840410 Mastercode 145601026 IMEI Spare 0A21410290484001 IMEI SV 0321410290484051F9000000 PPM V 5.32, 05-18-08, RH-106, (c) NMP, UB PSN RDG385322 Product Code 0551853 Module Code 0203485 Basic Product Code 0565808 PSD 0000001800000000 HW 0337 UEM 1328 UPP 2292 RFIC 0700 DSP P06w45.v50 LCD WINTEK:NAXv84, ST7628 ADSP Sw p*V 5.32\n05-18-08\nRH-106\n(c) NMP\nub_lta Asic 11 HW Signature 3A92E7744259FFA7 Simlock Server SIMLOCK SERVER Simlock Key 3700200072402456 Simlock Profile 8000000000010002 Simlock Aux 000B0000 Simlock IMEI 00000121420098404100 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 37002F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 42502F Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 338070 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 330110 Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 20404F Auto Selecting Flash Files on User Request... Product Code: 0551853 No Flash Datapackage installed for this Phone! MCU Version V 5.32 MCU Date 05-18-08 Product RH-106 (Nokia RH-106) Manufacturer (c) NMP IMEI 012142009840410 Mastercode 145601026 Setting Local Mode... Local mode Set Asic 11 HW Signature 3A92E7744259FFA7 Simlock Server SIMLOCK SERVER Simlock Key 3700200072402456 Simlock Profile 8000000000010002 Simlock Aux 000B0000 Simlock IMEI 00000121420098404100 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 37002F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 42502F Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 338070 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 330110 Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 20404F Autodetecting SP Type... Autodetection Finished Proceeding with RSA Unlock... Asking card to sign HW Signature... Signed OK (D12F8E401458B166D88B24583A6E2C2EAD05C880) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! |
12-27-2014, 09:07 | #3021 (permalink) |
No Life Poster Join Date: May 2010 Location: South America Age: 41
Member: 1308889 Status: Offline Sonork: 100.1608156 Thanks Meter: 266 | Successfully unlocked Nokia 6556B BB5 Unlock Started... MCU Version V 03.31 MCU Date 01-08-07 Product RM-289 (Nokia 6556B CLASSIC CABLE 6555) Manufacturer (c) Nokia IMEI 356271019851838 Mastercode 141756063 Simlock Server SIMLOCK SERVER Simlock Key 3101700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310150 Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310170 Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 311180 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310410 Simlock [5,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310980 Reading Security Block... Security block OK and saved to "RM-289_356271019851838_22112014_082042 p.m..SecurityBlock.PM" WARNING: "12C0000103FB0154B7CF819B325154BCFD213544.C000785D " Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 12C0000103FB0154B7CF819B325154BCFD213544 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Old Loader Detected Readed OK, Saving to "12C0000103FB0154B7CF819B325154BCFD213544.C000785D " Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) #pw+312079345969823+1# #pw+300896577083276+2# #pw+951186727230134+3# #pw+986018689315506+4# #pw+847322713919720+5# #pw+160003736947256+6# #pw+903748566397875+7# Sending NCK Codes.. NCK[1] - ACCEPTED NCK[2] - Too fast between tries (bruteforce protection) NCK[3] - Too fast between tries (bruteforce protection) NCK[4] - Too fast between tries (bruteforce protection) NCK[5] - Too fast between tries (bruteforce protection) NCK[6] - Too fast between tries (bruteforce protection) NCK[7] - Too fast between tries (bruteforce protection) MCU Version V 03.31 MCU Date 01-08-07 Product RM-289 (Nokia 6556B CLASSIC CABLE 6555) Manufacturer (c) Nokia IMEI 356271019851838 Mastercode 141756063 Simlock Server SIMLOCK SERVER Simlock Key 3101700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310150 Simlock [2,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310170 Simlock [3,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 311180 Simlock [4,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310410 Simlock [5,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310980 Simlock NCK #pw+312079345969823+1# Unlock finished! Time taken 10.485sSelected model: S3370 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM68 Reading phone info... Model: GT-S3370 Phone version: S3370NEJD1 IMEI: 352673041252675 Model: GT-S3370 Country code: ¿µ±¹ Cal date: 2010-04-27 Factory SW: S3370NEJD1_3UKJD1 Unique number: 80220000376793 Memory phone: K522H1HACC(S3370)S Reading sysinfo... OK Searching server... OK Writing sysinfo... OK Reseting... Unlock done Done with Samsung Tool v.18.3 |
12-27-2014, 09:08 | #3022 (permalink) |
Member: 1308889 Status: Offline Sonork: 100.1608156 Thanks Meter: 266 | Successfully unlocked nokia 268Os-2b MCU Version V 06.17 MCU Date 10-03-09 Product RM-393 (Nokia RM-393) Manufacturer (c) Nokia IMEI 011740001138633 Mastercode 123663632 Setting Local Mode... Local mode Set Asic 11 HW Signature 9C389DC6A7D818AD Simlock Server SIMLOCK SERVER Simlock Key 3027200000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00550117400011386300 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 302720 Autodetecting SP Type... Autodetection Finished Proceeding with RSA Unlock... Asking card to sign HW Signature... Signed OK (D38B3988CB9C43D6B584537789F2112F232FF7CE) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! |
01-01-2015, 04:52 | #3023 (permalink) |
Major Poster Join Date: Feb 2014
Member: 2129042 Status: Offline Thanks Meter: 11 | E-72 RM-530 ( Still working good for me Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:32:14, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B0002622 HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: Unknown Box is activated Started box selftests procedure USB Voltage 5.04v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.77v PASSED VBAT Voltage 0.03v PASSED VBAT Voltage 5.00v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.04v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 3.1023GB Avaiable Virtual Memory: 1.730GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing D:\Nokia Firmware\Products\... Found 36 products, Filtering BB5 Products - wait... 23 Products left after filtering. Ready. Retrieving Variants for Product RM-530 - wait... 1 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-530_352724040365305_112015_104159 AM.SecurityBlock.PM" WARNING: "0B600018318503445B8F8C9839600EDACFCC23B6.B0002622" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Prepare phone failed with message -> Failed to Boot CMT Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone) Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Prepare phone failed with message -> Failed to Boot CMT Failed to Create RPL from phone -> Failed to Boot / Prepare Phone RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing rm530_091.004_prd.core.fpsx (CMT)... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process rm530_091.004_prd.core.fpsx Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-530_352724040365305_112015_104300 AM.SecurityBlock.PM" WARNING: "0B600018318503445B8F8C9839600EDACFCC23B6.B0002622" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0B600018318503445B8F8C9839600EDACFCC23B6 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! New_RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Sending Auxiliary Loader... Auxiliary Loader Sent! If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs Custom loader running OK! Working... Readed OK, Saving to "0B600018318503445B8F8C9839600EDACFCC23B6.B0002622" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0B600018318503445B8F8C9839600EDACFCC23B6 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found Storing PARTNERC... Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing rm530_091.004_prd.core.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0B600018318503445B8F8C9839600EDACFCC23B6 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! rm530_091.004_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00020000-0x0003FFFF, ONENAND EraseArea[0,CMT]: 0x00060000-0x004DFFFF, ONENAND EraseArea[0,CMT]: 0x008E0000-0x0E77FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.217s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 126.891s Flashing Speed: 7065.84 kBit/S Restarting MCU... Processing rm530_091.004_prd.core.fpsx (APE)... Processing rm530_091.004_42.01_Thai_QW_prd.rofs2.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0B600018318503445B8F8C9839600EDACFCC23B6 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! rm530_091.004_42.01_Thai_QW_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x07CC0000-0x0CDBFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.437s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 69.499s Flashing Speed: 7177.23 kBit/S Restarting MCU... Processing rm530_091.004_42.01_Thai_QW_prd.rofs2.fpsx (APE)... Processing rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0B600018318503445B8F8C9839600EDACFCC23B6 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x0CDC0000-0x0E77FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.156s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 9.922s Flashing Speed: 7127.07 kBit/S Restarting MCU... Processing rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx (APE)... Processing rm530_091.004_U007.000_prd.uda.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0B600018318503445B8F8C9839600EDACFCC23B6 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! rm530_091.004_U007.000_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x0E780000-0x1F13FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 1.373s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 17.254s Flashing Speed: 6649.57 kBit/S Restarting MCU... Processing rm530_091.004_U007.000_prd.uda.fpsx (APE)... Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0B600018318503445B8F8C9839600EDACFCC23B6 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x004E0000-0x008DFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.32s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 3.151s Flashing Speed: 6881.04 kBit/S Restarting MCU... Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V ICPR82_11w16.3.11 MCU Date 29-03-12 Product RM-530 (Nokia E72) Manufacturer (c) Nokia IMEI 352724040365305 Mastercode 304616022 IMEI Spare 3A25270404633500 IMEI SV 3325270404633560F1000000 PSN C3B341543 Product Code 0587041 Basic Product Code 0583552 PSD 0000000000000000 LPSN 0 WLAN MAC A04E04794398 RETU 40 TAHVO 00 AHNE 11 HW 0803 RFIC |Vapaus_5.1 | Aura_?.? DSP 11w52 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
01-21-2015, 17:25 | #3024 (permalink) |
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 226 | MCU Version V 07.16 MCU Date 27-05-08 Product RM-364 (Nokia 3120 classic) Manufacturer (c) Nokia IMEI 353102024324334 Mastercode 552325273 IMEI Spare 3A35010242233403 IMEI SV 3335010242233443F8000000 PPM V 07.16, 27-05-08, RM-364, (c) Nokia , C CNT Content: 3_uk, V 07.16, 27-05-08, RM-364, (c) Nokia , , PSN DEJ116622 Product Code 0561596 Module Code 0203643 Basic Product Code 0553930 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 1000 RFIC 17141715 DSP ICPR71_08w17 LCD SEIKO BT 06cc-P9.2 Simlock Server SIMLOCK SERVER Simlock Key 2342000000000000 Simlock Profile 8000000000000002 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23420F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23594F Auto Selecting Flash Files on User Request... Product Code: 0561596 Scanning avaiable products... No flash paths set! Go to Settings -> Paths and set them! Scanning avaiable products... No flash paths set! Go to Settings -> Paths and set them! No Flash Datapackage installed for this Phone! BB5 Unlock Started... MCU Version V 07.16 MCU Date 27-05-08 Product RM-364 (Nokia 3120 classic) Manufacturer (c) Nokia IMEI 353102024324334 Mastercode 552325273 Simlock Server SIMLOCK SERVER Simlock Key 2342000000000000 Simlock Profile 8000000000000002 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23420F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23594F Reading Security Block... Security block OK and saved to "RM-364_353102024324334_1212015_110400 AM.SecurityBlock.PM" WARNING: "18F00115BEA44F504E6C27DB8275D84788467A60.C000554C " Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 18F00115BEA44F504E6C27DB8275D84788467A60 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Old Loader Detected Readed OK, Saving to "18F00115BEA44F504E6C27DB8275D84788467A60.C000554C " Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) #pw+203555903520454+1# #pw+610803472005688+2# #pw+201547971283474+3# #pw+904505809069979+4# #pw+081413450688252+5# #pw+698296350182817+6# #pw+700020664911924+7# Sending NCK Codes.. NCK[1] - ACCEPTED NCK[2] - Too fast between tries (bruteforce protection) NCK[3] - Too fast between tries (bruteforce protection) NCK[4] - Too fast between tries (bruteforce protection) NCK[5] - Too fast between tries (bruteforce protection) NCK[6] - Too fast between tries (bruteforce protection) NCK[7] - Too fast between tries (bruteforce protection) MCU Version V 07.16 MCU Date 27-05-08 Product RM-364 (Nokia 3120 classic) Manufacturer (c) Nokia IMEI 353102024324334 Mastercode 552325273 Simlock Server SIMLOCK SERVER Simlock Key 2342000000000000 Simlock Profile 8000000000000002 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 23420F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 23594F Simlock NCK #pw+203555903520454+1# Unlock finished! Time taken 14.86s |
01-22-2015, 06:51 | #3025 (permalink) |
01-26-2015, 18:41 | #3026 (permalink) |
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 226 | MCU Version V 06.01 MCU Date 18-03-05 Product RH-19 (Nokia 3100/3120 CABLE 6100) Manufacturer (c) Nokia. IMEI 353784004029676 Mastercode 501566346 IMEI Spare 3A35870440206907 IMEI SV 3335870440206907F9000000 PDC 4E54544A50123456 PPM V 06.01 , 18-03-05, RH-19, (c) Nok, I PSN GBE951954 Product Code 0525912 Module Code 0202448 Basic Product Code 0518447 PSD 0000001700000000 ATO g????????????????????????????????????????????????? HW 3028 UEM 1092 UPP 1120 RFIC 0300 DSP N4.11 LCD LDS172 Asic 2 HW Signature 5D8DA33FF676E2A6 Simlock Server SIMLOCKLIB VERSION 2.28- More TDS-6 boxes supported Simlock Key 3630100000000000 Simlock Profile 0000000000000002 Simlock Aux 00025555 Simlock IMEI 00553537840040296700 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 36301F Auto Selecting Flash Files on User Request... Product Code: 0525912 Scanning avaiable products... No flash paths set! Go to Settings -> Paths and set them! Scanning avaiable products... No flash paths set! Go to Settings -> Paths and set them! No Flash Datapackage installed for this Phone! BB5 Unlock Started... MCU Version V 06.01 MCU Date 18-03-05 Product RH-19 (Nokia 3100/3120 CABLE 6100) Manufacturer (c) Nokia. IMEI 353784004029676 Mastercode 501566346 BB5 Unlock Failed -> Initial SP corrupted or not a Baseband5 phone detected MCU Version V 06.01 MCU Date 18-03-05 Product RH-19 (Nokia 3100/3120 CABLE 6100) Manufacturer (c) Nokia. IMEI 353784004029676 Mastercode 501566346 Setting Local Mode... Local mode Set Asic 2 HW Signature 3BF83891DB4C796B Simlock Server SIMLOCKLIB VERSION 2.28- More TDS-6 boxes supported Simlock Key 3630100000000000 Simlock Profile 0000000000000002 Simlock Aux 00025555 Simlock IMEI 00553537840040296700 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 36301F Autodetecting SP Type... Autodetection Finished Proceeding with Normal DCT4 Unlock... Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! |
03-19-2015, 17:45 | #3027 (permalink) |
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 226 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000554C HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk35 Initializing security card... Card Serial Number: D006029C Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5.13v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.81v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.09v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 5.10v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 930.476MB Avaiable Virtual Memory: 1.817GB Avaiable Pagefile: 3.318GB Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Pre flash tasks finished, continuing... Processing 5901B58F_rm813__15.15.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007400C192103032108 CMT_EM_ASIC_ID: 00001051 CMT_EM_ASIC_ID: 00001060 CMT_PUBLIC_ID: 8A3B0000FFFB3C40BA035AFAB95C1706F2C11E8A CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT_BOOT_ROM_CRC: 2CAC45E2 CMT_SECURE_ROM_CRC: 3BC33C8B CMT Ready! 5901B58F_rm813__15.15.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6 Searching for BootCode: DualLine 32Bit RAPUv21_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPUv21_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x000403FF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, ONENAND EraseArea[0,CMT]: 0x00140000-0x004BFFFF, ONENAND EraseArea[0,CMT]: 0x004C0000-0x0073FFFF, ONENAND EraseArea[0,CMT]: 0x00740000-0x0147FFFF, ONENAND EraseArea[0,CMT]: 0x00160000-0x0017FFFF, ONENAND EraseArea[0,CMT]: 0x03200000-0x0387FFFF, ONENAND EraseArea[0,CMT]: 0x0F080000-0x0F67FFFF, ONENAND EraseArea[0,CMT]: 0x01480000-0x0243FFFF, ONENAND EraseArea[0,CMT]: 0x02440000-0x025BFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.795s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT KEYS Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT MCUSW1 Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT ISA+DYNSW Certificate... Writing CMT ADA Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT RAP3NAND Certificate... Writing CMT UPDAPP Certificate... Writing CMT ISA+EXTDRV Certificate... Programming Status OK! All blocks written OK! Time taken 4.883s Flashing Speed: 54746.14 kBit/S Processing 5901B58F_rm813__15.15.mcusw (APE)... Processing D0318CD3_rm813__15.15.ppm_c5 (CMT)... D0318CD3_rm813__15.15.ppm_c5, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x025C0000-0x031FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.109s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 0.671s Flashing Speed: 72155.54 kBit/S Processing D0318CD3_rm813__15.15.ppm_c5 (APE)... Processing 42EDF42D_rm813__15.15.image_c5_059K7T6 (CMT)... 42EDF42D_rm813__15.15.image_c5_059K7T6, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x03880000-0x0F07FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 2.387s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 3.541s Flashing Speed: 61202.04 kBit/S Processing 42EDF42D_rm813__15.15.image_c5_059K7T6 (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia USB Flashing Generic]: Port opened OK! [Nokia USB Flashing Generic]: Port opened OK! [Nokia USB Flashing Generic]: Port opened OK! [Nokia USB Flashing Generic]: Port opened OK! [Nokia USB Flashing Generic]: Port opened OK! Factory defaults OK Reading info... [Nokia USB Flashing Generic]: Port opened OK! Failed to read info -> Phone not detected Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
04-29-2015, 19:08 | #3028 (permalink) |
No Life Poster Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 226 | MCU Version V 08.71 MCU Date 29-09-09 Product RM-520 (Nokia RM-520) Manufacturer (c) Nokia IMEI 012047001442687 Mastercode 234610746 BB5 Unlock Failed -> Initial SP corrupted or not a Baseband5 phone detected MCU Version V 08.71 MCU Date 29-09-09 Product RM-520 (Nokia RM-520) Manufacturer (c) Nokia IMEI 012047001442687 Mastercode 234610746 Setting Local Mode... Local mode Set Asic 11 HW Signature A0871F7CE9FABD4B Simlock Server SIMLOCK SERVER Simlock Key 3101700000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00550120470014426800 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310150 Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310170 Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 311180 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310410 Simlock [5,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310980 Autodetecting SP Type... Autodetection Finished Proceeding with RSA Unlock... Asking card to sign HW Signature... Signed OK (011B7FAB35CA477DE6B448F876F9D2239C102EAD) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! |
06-17-2015, 13:06 | #3030 (permalink) |
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 226 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000554C HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk35 Initializing security card... Card Serial Number: D006029C Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5.05v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.81v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 1.732GB Avaiable Virtual Memory: 1.850GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work MCU Version V 06.82 MCU Date 26-09-08 Product RM-394 (Nokia 1680C CLASSIC) Manufacturer (c) Nokia IMEI 356378026203778 Mastercode 1121546414 IMEI Spare 3A65730862027307 IMEI SV 3365730862027347F5000000 PPM V 06.82, 26-09-08, RM-394, (c) Nokia, UA CNT Content: ua_grey_digicel_jamaica, V 06.82, 26-09-08, RM-394, (c) Nokia, , PSN GDJ602232 Product Code 0573822 Module Code 0203777 Basic Product Code 0556746 PSD 0000000D00000000 LPSN 0 HW 4002 UEM 1328 UPP 3162 Failed to read info -> Failed to read extended info MCU Version V 06.82 MCU Date 26-09-08 Product RM-394 (Nokia 1680C CLASSIC) Manufacturer (c) Nokia IMEI 356378026203778 Mastercode 1121546414 Setting Local Mode... Local mode Set Asic 11 HW Signature 40A236DAD97762EC Simlock Server SIMLOCK SERVER Simlock Key 3380500000000000 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00553563780262037700 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 33805F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 35805F Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 360070 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 352030 Simlock [5,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 342750 Simlock [6,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 374130 Simlock [7,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 363020 Simlock [8,1] State: CLOSED Type: MCC-MNC Data: 36269F Simlock [9,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310380 Simlock [10,1] State: CLOSED Type: MCC-MNC Data: 34020F Simlock [11,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 372020 Simlock [12,1] State: CLOSED Type: MCC-MNC Data: 73801F Simlock [13,1] State: CLOSED Type: MCC-MNC Data: 70602F Simlock [14,1] State: CLOSED Type: MCC-MNC Data: 74603F Simlock [15,1] State: CLOSED Type: MCC-MNC Data: 53703F Simlock [16,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 708040 Simlock [17,1] State: CLOSED Type: MCC-MNC Data: 53988F Simlock [18,1] State: CLOSED Type: MCC-MNC Data: 54105F Simlock [19,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 348770 Simlock [20,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 714040 Simlock [21,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 714041 Autodetecting SP Type... Autodetection Finished Proceeding with RSA Unlock... Asking card to sign HW Signature... Signed OK (59724948A266C39394658EAFA4A5844C30CB2648) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! Security Code 19200 Attempts 05 Attempts counter was resetted OK Security code was resetted to 12345 |
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. | hitibiti | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2837 | 07-05-2020 10:10 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
