Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member Join Date: Jan 2013
Member: 1864545 Status: Offline Thanks: 2
| Hello! I bought a cable for nokia n82 5 pin. When connecting to the cyclone box reloaded phones not found in the Local mode is not included, just turn on. Tried on two different phones. What's the problem? |
| | #2 (permalink) |
| Super Moderator ![]() Join Date: Jan 2009 Location: England Age: 48
Member: 947561 Status: Offline Thanks: 2,690
| looks like: a) the cable has a too low value BSI resistor b) your mobile has local mode problem you can try to go in the tab "bb5/flashing" and click on "check flashing bus": the mobile should go in local mode once done BR Alex |
| The Following User Says Thank You to moulnisky For This Useful Post: |
| | #3 (permalink) |
| Thank you. Resistors 8.2k and 65k measured with a multimeter. After chek flashing bus phone just turn as usual. Here chek: Booting CMT... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9D6611B43E90E6BA2D087777E6A09C9B0EEEF25A APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 10C000052C730052CAAB6D3BD49F90B9CBCA4FCF CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: A8C1D671 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Prepare phone failed with message -> CMT Secondary Loader was not accepted (1) Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone |
| | #4 (permalink) |
| Weird as you have a cyclone box reloaded which is able to compensate errors on the bsi value.. looks more like a local mode problem on the phone ![]() check if the sodlering of the bsi inside the cable is fine and the bsi Pin is touching properly where due Try as well to replace the 8.2 kohm resistor with a 10-15 kohm one. If you need to unlock or back-up you can do it via fbus as well (remember to remove the battery when asked etc etc) but, before doing any flash, be sure you have a full back-up of this phone ![]() if still problems you should search on the forum for local mode solution for this phone as hardware. BR Alex |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
