Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 03-27-2009, 13:12   #1 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,683
** Registration problems - solve here **
As i am watching server logs, i see some ppls having problems with their box registration. This problems coming from using special chars in Registration data (Russian chars, etc) so please tilll next update when we will filter this data and allow only alphanum characters, don't use it
Old 01-05-2012, 12:59   #2 (permalink)
Member: 1646785
Sonork: 1002400
Thanks Meter: 3
hi
Please Change my Box Registration to this info: thanks
firstname: mohammad reza
surname: pourasadi
nickname: mrpourasadi
adress: tehran
country: iran
E-Mail: [email protected]
Maintenance Box:
Box Maintenance procedure started at 01:47:06 .
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support
Service Tag: 4ACBAFB385C2967C68553197FB871F33
Connecting to Cyclone Server
Cyclone Server (1.0.0.683), Cyclone Box Team 2008-2011 - Ready.
========= Box Info =========
Box SN: C000638B
HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk48
Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty
Box registration status: Registered OK
Paired Card SN: D0090368
First Name: porasadi
Surname: porasadi
Nickname: porasadi
Address: tehran
Country: iran
E-Mail: [email protected]**********.com
Reseller: Ipmart, Malaysia
Warranty Start Date: 2012-01-05
Warranty Period (months): 6
Warranty Stop Date: 2012-07-05
Warranty active: Yes
Updating Security Area...
Security Area Update Skipped, Not allowed
Updating Main Firmware...
Main Firmware Update Skipped, Not allowed
Updating COM Emulator Firmware...
COM Emulator Firmware Updated, Took: 0.32s
Updating Secure Bootloader...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Firmware: Cyclone Nokia/Blackberry Application v01.82, (Nov 12 2011 09:45:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011
Boot Agent: Cyclone Secure BootAgent Server v3.01 (C) KarwosSoft 2010 wk41
Bootloader is already Up-to-date
Secure Bootloader Update Skipped
Disconnected from Cyclone Server
Box Maintenance finished successfully
registration wizard:
Registration Wizard Ready, Engine Revision: 1.0.0.11671
Box Registration Preparation procedure started at 01:49:08 .
Box Registration Preparation Error -> Box is already registered! Contact support if any problems occurs.
Old 01-06-2012, 19:01   #3 (permalink)
Member: 783899
Hi members i have a cyclone box , each time i conect its saying !Handling device: [Cyclone Team], [Cyclone Bootloader]
Card reading error -> No connection was established, or box is not in needed mode ..rif there is any one who can help me how be very greatful .here is my email addrese [email protected] ,,,Thanks in advance
Old 01-06-2012, 19:04   #4 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Did You check Box Maintenance tab and press Maintenance Box button?
Old 01-07-2012, 08:41   #5 (permalink)
msattar123's Avatar
Member: 645436
Thanks Meter: 1,491
Red face
Registration Wizard Ready, Engine Revision: 1.0.0.11865
Box Registration Preparation procedure started at 1:38:12 AM
Service Tag: 7589F653D04188C2F40A954A30FCC96D
Box Registration Preparation Error -> Can't connect to Cyclone Server
plese help me sir ...................
Old 01-07-2012, 09:19   #6 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Try now, reason was on server, i fixed it.
The Following User Says Thank You to kaisak For This Useful Post:
Old 01-07-2012, 10:17   #7 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by <Y.P.Y> View Post
hi
surname: pourasadi
adress: tehran
country: iran
Maintenance Box:
Box SN: C000638B
Surname: porasadi
Nickname: porasadi
Address: tehran
Country: iran
Your register data have been updated.
Old 01-26-2012, 17:31   #8 (permalink)
Member: 1713335
Registration for SE on Cyclone
I try to register SE for unlocking with Cyclone how should i do that pls. help customers are waiting
Old 01-26-2012, 19:05   #9 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Register what ? Have you bothered to read / search before post ?
How to Unlock Xperia Phones using CycloneBox ? [Instructions Inside]
21-12-2011 CycloneBox Installer v1.17 with Xperia Addon and more
Old 02-03-2012, 14:47   #10 (permalink)
Member: 889369
Sonork: 100.1638354
Thanks Meter: 321
Hi i have same problem can please check :
Box Maintenance procedure started at 15:37:53
Bootloader: Cyclone Secure Bootloader v2.10, (Dec 5 2009 23:39:04), Type: Signed Production Application
Service Tag: 9CDBEAD55E5AC697145915E9F22BB2B3
Cyclone Server Send Command Error -> Code: 500, Given ServiceTag was not found in database
Box Maintenance Error -> Server command send error
Old 02-07-2012, 22:28   #11 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Fixed, pls try register Your box
Old 02-08-2012, 16:11   #12 (permalink)
leonirvana's Avatar
Member: 290434
Thanks Meter: 39
i have problem with ALL maintenance tabs.
please help.
BOX MAINTENANCE
Box Maintenance procedure started at 01:05:33 p.m.
Service Tag: F2B4099CC303F001E2BB8B43E2D1926F
Box Maintenance Error -> Can't connect to Cyclone Server
BOX REGISTRATION
Box Registration Preparation procedure started at 01:06:57 p.m.
CARD MAINTENANCE
Started card reading procedure at 01:07:25 p.m.
CLIP MAINTENANCE
Clip Maintenance Tool Ready, Engine Revision: 1.0.0.11926
Opening Box...
Failed to Check Clip -> No connection was established, or box is not in needed mode
Old 02-08-2012, 18:31   #13 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
please help.
Read this:
We have limited server slots to 20!
update failed
Have patience, try later
The Following User Says Thank You to ptt For This Useful Post:
Old 02-25-2012, 06:54   #14 (permalink)
Member: 69627
Thanks Meter: 6
please halp my
Surname: samtredia
Nickname: vaso-58
Address: rustaveli 94
Country: georgia
Reseller: Mobitec, Syria
Warranty Start Date: 2009-08-29
Warranty Stop Date: 2010-02-28
Warranty active: No
COM Emulator Update Skipped, Not allowed
Failed to Upgrade Bootloader -> No connection was established, or box is not in needed mode
Old 02-25-2012, 12:00   #15 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 13,971
Originally Posted by Iraklis View Post
please halp my
Surname: samtredia
Nickname: vaso-58
Country: georgia
Warranty active: No
Wrong thread and if you don't show us the serial is impossible to help you too
Alex
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
buy your GSM here midlandcellular Main Sales Section 0 09-04-1999 17:14
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.46786 seconds with 9 queries
