07-02-2012, 00:01 | #406 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | http://forum.gsmhosting.com/vbb/f528...rvice-1498527/ |
07-02-2012, 08:35 | #407 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1450258 Status: Offline Thanks Meter: 0 | Blank Support area i have a problem with support area on germany server, only things i see are : Cycator, lost+found,N9_rm-696_SM_L34..., and idex.php. Please help Support Area Launched, Engine Revision: 1.0.1.713 Started authenthication procedure at 10:30:13 AM Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Box Service Tag: B4E3DE9F1A3E736456C5C253B4B59E3C Cyclone Server (2.0.0.42), Cyclone Box Team 2008-2012 - Ready. Ticket received, Veryfing it... Server connection established, inflating data... Ticket: C52F0D5CDFEBFAECDC2E6B1025C004F667144295 XML Revision: 1.0 XML Encoding: iso-8859-1 Interface Revision: 1 Message of the day: ====================================== Welcome to Germany! Hosted by Hetzner A.G, Cyclone Support Interface, (c) 2009-2012 Cyclone Box Team ====================================== Server Timestamp: 02.07.2012 09:29:46 CEST Service Status: OK Ticket Status: Ticket found Ticket Box SN: B0001B22 Task Name: GetListing Parsing files... Files parsed OK! Server time taken: 0.000718116760254s and on USA server i get this error : Cyclone Server Send Command Error -> SQL Error: Can't connect to MySQL server on '74.53.199.2' (10060) (500) Authenthication error -> Failed to obtain Support Ticket |
07-03-2012, 10:26 | #408 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 548443 Status: Offline Thanks Meter: 70 | Box Upgrade Problem I need to upgrade my box to be able to use xGold service ( "Failed to Read X-Gold LOG2COD File -> XGold Service Counter is 0. UPGRADE YOUR BOX TO CONTINUE USING SERVICE."., But I am not receiving any response from Service. Please I need help. JKKB. |
07-03-2012, 16:25 | #409 (permalink) |
Freak Poster Join Date: Nov 2006 Location: uruguay
Member: 387267 Status: Offline Thanks Meter: 10 | No server ever WHEN TRY TO CONECT TO USA SERVER SAY THIS PLEASE HELP Support Area Launched, Engine Revision: 1.0.1.713 Started authenthication procedure at 17:21:43 Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Box Service Tag: 5F7BF6BCAECB2E6A7B9ABCA3C333E2E9 Cyclone Server (2.0.0.42), Cyclone Box Team 2008-2012 - Ready. Cyclone Server Send Command Error -> SQL Error: Can't connect to MySQL server on '74.53.199.2' (10060) (500) Authenthication error -> Failed to obtain Support Ticket |
07-03-2012, 22:01 | #410 (permalink) | |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Quote:
About what response from service are you talking about ? | |
07-04-2012, 18:44 | #411 (permalink) |
Junior Member Join Date: Jan 2012
Member: 1712202 Status: Offline Thanks Meter: 4 | Sever ok? Hi, i got same problem. Internet is fine. Antivirus disable. I removed cyclone completely, restarted pc. reinstalled, but can't do anything.. "Server Tools Launched, Engine Revision: 1.0.1.713 LG Get Codes Started for IMEI 357028040677304 Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Please Wait... Failed to Get LG Codes -> Failed to Connect to Cyclone Server" ------------- tried maintainence tools: "Support Area Launched, Engine Revision: 1.0.1.713 Started authenthication procedure at 19:38:55 Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Box Service Tag: 52DF739E733650B20718F7CB26286CCE Authenthication error -> Failed to connect to Cyclone Server" ----------------------- + Box Wizard: "Failed to connect to server. Check connection" |
07-04-2012, 19:10 | #412 (permalink) | |
Freak Poster Join Date: Jan 2009 Location: Germany/NRW
Member: 936229 Status: Offline Sonork: 1606911 Thanks Meter: 115 | Quote:
Have same Problem,can't connect to USA Server for Download Flashfiles,tested on 2 new Cyclone Reloaded,please help! Best regards. Code: Support Area Launched, Engine Revision: 1.0.1.713 Started authenthication procedure at 20:08:38 Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Box Service Tag: 813573E2D9033438BFA858CAE4ADB4C5 Cyclone Server (2.0.0.42), Cyclone Box Team 2008-2012 - Ready. Cyclone Server Send Command Error -> SQL Error: Can't connect to MySQL server on '74.53.199.2' (10060) (500) Authenthication error -> Failed to obtain Support Ticket | |
07-05-2012, 09:37 | #413 (permalink) |
Junior Member Join Date: Sep 2008
Member: 862494 Status: Offline Thanks Meter: 0 | Iphone IMEI checking still not working, software is fully up to date and not been working for over a week now - can some one help please? I got this box specifically to check iphone imei's and it doesn't work |
07-05-2012, 21:16 | #414 (permalink) | |
Freak Poster Join Date: Jan 2002 Location: sp coastline
Member: 8802 Status: Offline Thanks Meter: 16 | Quote:
br | |
07-06-2012, 07:56 | #415 (permalink) |
Freak Poster Join Date: Sep 2011 Location: uganda Age: 34
Member: 1657640 Status: Offline Sonork: ayikobuam Thanks Meter: 11 | wanted to unlock lg G4011 but errorLG Get Codes Started for IMEI 010305007065056 Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Please Wait... Cyclone Server (2.0.0.42), Cyclone Box Team 2008-2012 - Ready. Cyclone Server Send Command Error -> 'Couldn't resolve host 'serverfullunlock.com'' is not a valid integer value (500) Failed to Get LG Codes -> Command Send failed box sn is c000394A |
07-06-2012, 08:26 | #416 (permalink) | |
Insane Poster Join Date: May 2009
Member: 1026404 Status: Offline Thanks Meter: 5 | Quote:
br SiRoYa | |
The Following User Says Thank You to Digi74 For This Useful Post: |
07-06-2012, 14:55 | #417 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1495266 Status: Offline Sonork: 100.1609552 Thanks Meter: 47 | so are you trying to tell as we should buy Cyclone Reload or what??? is been a long time but no fix on server error... why???? iPhone checker Please Wait... Cyclone Server (2.0.0.42), Cyclone Box Team 2008-2012 - Ready. Cyclone Server Send Command Error -> '$' is not a valid integer value (500) Failed to Check iPhone -> Command Send failed LG Unlocker Cyclone Server Send Command Error -> 'Couldn't resolve host 'serverfullunlock.com'' is not a valid integer value (500) Failed to Get LG Codes -> Command Send failed |
07-07-2012, 01:54 | #418 (permalink) |
No Life Poster Join Date: Jul 2006 Location: SCN Movil Centro
Member: 321176 Status: Online Sonork: 100.1640958 Thanks Meter: 62 | Hi LG server calculator are out of service or what, Server Tools Launched, Engine Revision: 1.0.1.649 LG Get Codes Started for IMEI 352231XXXXXXXX Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Please Wait... Cyclone Server (2.0.0.42), Cyclone Box Team 2008-2012 - Ready. Cyclone Server Send Command Error -> 'Couldn't resolve host 'serverfullunlock.com'' is not a valid integer value (500) Failed to Get LG Codes -> Command Send failed Need Answer from support Thank in Advance. bedel |
07-07-2012, 19:42 | #419 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | About LG Service: Have you bothered to read the "STICKY THREAD" with the "News" about LG Service posted by SiRoYa on June 30 ???? http://forum.gsmhosting.com/vbb/f528...rvice-1498527/ About iPhone: http://forum.gsmhosting.com/vbb/8519885-post271.html http://forum.gsmhosting.com/vbb/f528...vided-1497919/ http://forum.gsmhosting.com/vbb/8555577-post9.html |
The Following User Says Thank You to ptt For This Useful Post: |
07-08-2012, 02:49 | #420 (permalink) | |
Member: 321176 Status: Online Sonork: 100.1640958 Thanks Meter: 62 | Quote:
Hey Bro I live in a country with internet access is same li water are out on the desert sorry about, I are very very happy with this tool but why not post in news or send sms to de owner about informer some situation or some changer. thank bedel. | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
