Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-13-2012, 23:43   #226 (permalink)
duncan99's Avatar
Member: 1322701
Thanks Meter: 127
please help me out
for 3days now i havent done any work with my cyclone box because i cant fill my card. i have lost a lot of client because of thing please help me out
cyclone the best but im mAD
Old 04-13-2012, 23:47   #227 (permalink)
duncan99's Avatar
Member: 1322701
Thanks Meter: 127
please please help me
please my cyclone box for 3days now refused to fill my card and i cant do any work with it because it wont let me please this 3days has been very hard for me please fix this thing cyclone you the best
Old 04-14-2012, 00:17   #228 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
us other tool and let cyclone team finish last update
Old 04-14-2012, 01:10   #229 (permalink)
ali_7867's Avatar
Member: 910577
Thanks Meter: 242
hi team for ticket
but does not work i check my internet 100% fine working with two more pc
thanks still need help pleaseeeeeeeeee
Support Area Launched, Engine Revision: 1.0.0.11865
Started authenthication procedure at 1:07:23 AM
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Box Service Tag: 10B887DBD48A83555B01ABD3CC1F7B60
Cyclone Server (2.0.0.5), Cyclone Box Team 2008-2011 - Ready.
Ticket received, Veryfing it...
Server connection lost, Reconnecting...
Authenthication error -> Socket Error # 11004
Started authenthication procedure at 1:08:08 AM
Cyclone Server Send Command Error -> Code: 500, SQL Error: Unknown MySQL server host 'orcan.karwosgsm.pl' (11004)
Authenthication error -> Failed to obtain Support Ticket
Started authenthication procedure at 1:08:36 AM
Old 04-14-2012, 01:43   #230 (permalink)
Member: 59058
Thanks Meter: 11
Box Maintenance procedure started at 01:35:30
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Bootloader: Cyclone Classic Common Bootloader v3.00, (Apr 6 2012 16:14:55)
Service Tag: 421F41D8A410524628960A755950AD03
Connecting to Cyclone Server
Box Maintenance Error -> Can't connect to Cyclone Server
Like this for some time now ?
Old 04-14-2012, 05:59   #231 (permalink)
Member: 577307
Thanks Meter: 58
this is my problem
hi sir , this is my problem.
when i connected box and click nokia tool ti shows
"Service Tag: 0238A47BF10CC7219BC4D7BECA0889C1
Failed to Check Credits -> Failed to connect to Cyclone Server"
when box maintains
when i try to fill cards it shows like this
"Card is empty, proceeding with credits fill...
Card credits fill error -> Can't connect to Cyclone Server"
that is the solution
pleas help me.
Old 04-14-2012, 06:54   #232 (permalink)
Member: 577307
Thanks Meter: 58
Originally Posted by hadjifr41 View Post
i try this and not work
# Copyright (c) 1993-1999 Microsoft Corp.
# Ceci est un exemple de fichier HOSTS utilisé par Microsoft TCP/IP
# pour Windows.
# Ce fichier contient les correspondances des a******* IP aux noms d'hôtes.
# Chaque entrée doit être sur une ligne propre. L'adresse IP doit être placée
# dans la première colonne, suivie par le nom d'hôte correspondant. L'adresse
# IP et le nom d'hôte doivent être séparés par au moins un espace.
# De plus, des commentaires (tels que celui-ci) peuvent être insérés sur des
# lignes propres ou après le nom d'ordinateur. Ils sont indiqué par le
# symbole '#'.
# Par exemple :
102.54.94.97 rhino.acme.com
83.19.176.83 cyclone.karwosgsm.pl
38.25.63.10 x.acme.com # hôte client x
please give me the hosts fie for i paste in my pc
I had edited like .
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP ad******* to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
83.19.176.83 cyclone.karwosgsm.pl # source server
127.0.0.1 localhost
it is working for me.
Old 04-14-2012, 07:22   #233 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Did You edit file hosts?
Old 04-14-2012, 07:26   #234 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by soadbra View Post
Come on suporters!
We need answers!
What is going on?
Why the edition trick is only work for few members?
You have ALL INORMATION from karwos on this thread?! Did You read it Before post?
http://forum.gsmhosting.com/vbb/f528...ml#post8314854
There You can find answer on Your's question what's going on.
Old 04-14-2012, 07:28   #235 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by digitalgsm_cora View Post
F...ing server is down !
B.R.
Server works fine- this is not problem pf server.
Old 04-14-2012, 07:29   #236 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by Adrian6342 View Post
Hello,
I have been having trouble connecting for the past 2 days.. I am in Mexico..what information do you need to check.
Old 04-14-2012, 07:30   #237 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by adnan_taeki View Post
Same at Cyclone Box Maintenance Module
Box Maintenance procedure started at 9:40:17 PM
Service Tag: **************************
Regards,
Adnan Khaver
Old 04-14-2012, 09:11   #238 (permalink)
Member: 32127
Thanks Meter: 34
Originally Posted by biri26 View Post
Go to C:\windows\system32\drivers\etc\hosts and add entry:
your problem will be solved
NOT at All Times buddy, maybe u only got lucky....
we want real solution
Old 04-14-2012, 10:33   #239 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
B.R.
It's was fuking up , problem was in DNS server and i've
1) posted solution in THIS thread
2) sent mass sonork message
so this means your eyes is down.
Old 04-14-2012, 10:33   #240 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Come on suporters!
We need answers!
What is going on?
Maybe because you can't edit hosts properly?
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.30505 seconds with 11 queries
