Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 07-02-2012, 01:01   #406 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Have you bothered to check SiRoYa Sticky post ???? Or the Links posted 2 posts above your post ??
News about LG service
Old 07-02-2012, 09:35   #407 (permalink)
Member: 1450258
Blank Support area
i have a problem with support area on germany server, only things i see are : Cycator, lost+found,N9_rm-696_SM_L34..., and idex.php. Please help
Support Area Launched, Engine Revision: 1.0.1.713
Started authenthication procedure at 10:30:13 AM
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Box Service Tag: B4E3DE9F1A3E736456C5C253B4B59E3C
Cyclone Server (2.0.0.42), Cyclone Box Team 2008-2012 - Ready.
Ticket received, Veryfing it...
Server connection established, inflating data...
Ticket: C52F0D5CDFEBFAECDC2E6B1025C004F667144295
XML Revision: 1.0
XML Encoding: iso-8859-1
Interface Revision: 1
Message of the day:
Welcome to Germany! Hosted by Hetzner A.G, Cyclone Support Interface, (c) 2009-2012 Cyclone Box Team
Server Timestamp: 02.07.2012 09:29:46 CEST
Service Status: OK
Ticket Status: Ticket found
Ticket Box SN: B0001B22
Task Name: GetListing
Parsing files...
Files parsed OK!
Server time taken: 0.000718116760254s
and on USA server i get this error :
Cyclone Server Send Command Error -> SQL Error: Can't connect to MySQL server on '74.53.199.2' (10060)
(500)
Authenthication error -> Failed to obtain Support Ticket
Old 07-03-2012, 11:26   #408 (permalink)
Member: 548443
Thanks Meter: 70
Arrow Box Upgrade Problem
I need to upgrade my box to be able to use xGold service (
"Failed to Read X-Gold LOG2COD File -> XGold Service Counter is 0. UPGRADE YOUR BOX TO CONTINUE USING SERVICE.".,
But I am not receiving any response from Service.
Please I need help.
JKKB.
Old 07-03-2012, 17:25   #409 (permalink)
Member: 387267
Thanks Meter: 10
No server ever
WHEN TRY TO CONECT TO USA SERVER SAY THIS PLEASE HELP
Started authenthication procedure at 17:21:43
Box Service Tag: 5F7BF6BCAECB2E6A7B9ABCA3C333E2E9
(500)
Old 07-03-2012, 23:01   #410 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Please I need help.
JKKB.
Use "Box Wizard" to Upgrade your Box FW, thats all...
About what response from service are you talking about ?
Old 07-04-2012, 19:44   #411 (permalink)
Member: 1712202
Thanks Meter: 4
Sever ok?
Hi, i got same problem.
Internet is fine. Antivirus disable.
I removed cyclone completely, restarted pc. reinstalled, but can't do anything..
"Server Tools Launched, Engine Revision: 1.0.1.713
LG Get Codes Started for IMEI 357028040677304
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Please Wait...
Failed to Get LG Codes -> Failed to Connect to Cyclone Server"
tried maintainence tools:
"Support Area Launched, Engine Revision: 1.0.1.713
Started authenthication procedure at 19:38:55
Box Service Tag: 52DF739E733650B20718F7CB26286CCE
Authenthication error -> Failed to connect to Cyclone Server"
+ Box Wizard:
"Failed to connect to server. Check connection"
Old 07-04-2012, 20:10   #412 (permalink)
Pulka's Avatar
Member: 936229
Sonork: 1606911
Thanks Meter: 114
XML Revision: 1.0
Message of the day:
Service Status: OK
Parsing files...
Files parsed OK!
(500)
Hi.
Have same Problem,can't connect to USA Server for Download Flashfiles,tested on 2 new Cyclone Reloaded,please help!
Best regards.
Started authenthication procedure at 20:08:38
Box Service Tag: 813573E2D9033438BFA858CAE4ADB4C5
 (500)
Old 07-05-2012, 10:37   #413 (permalink)
Member: 862494
Iphone IMEI checking still not working, software is fully up to date and not been working for over a week now - can some one help please? I got this box specifically to check iphone imei's and it doesn't work
Old 07-05-2012, 22:16   #414 (permalink)
Member: 8802
Thanks Meter: 16
iphone imei analyzer not wokring
br
Old 07-06-2012, 08:56   #415 (permalink)
Member: 1657640
Sonork: ayikobuam
Thanks Meter: 11
wanted to unlock lg G4011
but errorLG Get Codes Started for IMEI 010305007065056
Please Wait...
Cyclone Server Send Command Error -> 'Couldn't resolve host 'serverfullunlock.com'' is not a valid integer value
(500)
Failed to Get LG Codes -> Command Send failed
box sn is c000394A
Old 07-06-2012, 09:26   #416 (permalink)
Member: 1026404
Thanks Meter: 5
Please Wait...
(500)
box sn is c000394A
LG service will be down for unknown time period,so please bare with us
br
SiRoYa
The Following User Says Thank You to Digi74 For This Useful Post:
Old 07-06-2012, 15:55   #417 (permalink)
addgsm's Avatar
Member: 1495266
Sonork: 100.1609552
Thanks Meter: 47
so are you trying to tell as we should buy Cyclone Reload or what??? is been a long time but no fix on server error... why????
iPhone checker
Please Wait...
Cyclone Server Send Command Error -> '$' is not a valid integer value
(500)
Failed to Check iPhone -> Command Send failed
LG Unlocker
(500)
Old 07-07-2012, 02:54   #418 (permalink)
bedel's Avatar
Member: 321176
Sonork: 100.1640958
Thanks Meter: 52
Hi LG server calculator are out of service or what,
Server Tools Launched, Engine Revision: 1.0.1.649
LG Get Codes Started for IMEI 352231XXXXXXXX
Please Wait...
(500)
Need Answer from support
Thank in Advance.
bedel
Old 07-07-2012, 20:42   #419 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
About LG Service:
Have you bothered to read the "STICKY THREAD" with the "News" about LG Service posted by SiRoYa on June 30 ????
About iPhone:
Cyclone Box Iphone/Ipad Imei Analyzer
cannot use iPhone imei Check [Alternative free software link provided]
The Following User Says Thank You to ptt For This Useful Post:
Old 07-08-2012, 03:49   #420 (permalink)
bedel's Avatar
Member: 321176
Sonork: 100.1640958
Thanks Meter: 52
Originally Posted by ptt View Post
About LG Service:
About iPhone:
Hey Bro I live in a country with internet access is same li water are out on the desert sorry about, I are very very happy with this tool but why not post in news or send sms to de owner about informer some situation or some changer.
thank bedel.
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 19:29
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-25-2009 17:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 18:04
Page generated in 0.47571 seconds with 9 queries
