Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 02-09-2012, 10:10   #46 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
Originally Posted by Dipendra Pathak View Post
Box Maintenance procedure started at 3:29:56 PM
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support
Service Tag: D64963B1C4FE5DB521768E0C259EB9BB
Connecting to Cyclone Server
Box Maintenance Error -> Can't connect to Cyclone Server
What Happened to this ??? I am trying from yesterday. You say Server Back..... Where is Server Back? If it is back, then we can write new firmware to the box.
Do not say that is my antivirus problem and Internet connection problem. I have disable antivirus and My connection speed around 790 kbps and it is working fine. But, cyclone can't find its own server...
Also,
Box Firmware Old and needs to be upgrated to 1.85, If you click "Yes" then, ALWAYS LOOPING and same Question. And We can't upgrade Firmware. If you don't upgrade firmware, then can't run software.... Should we go back to OLD software ie Old Version????
Calm down, offcourse server NOT BACK, because works ALL TIME, so dont need back. I wrote yesterday that We had limit on connection We have limited server slots to 20!. WE DONT SAY ON ANY POST TO ANY USER FROM YESTERDAY ABT ANTIVIRUS OR INTERNET CONNECTON I excellent know when reason is on Our site when on User, Pls read Our post more carrefully!!! If you make update in Maintenance then sw stop ask You abt update. I checked- server was hang up 10:45 till 11:00 now works, You need be patient and try.
Old 02-09-2012, 10:13   #47 (permalink)
ronandaly's Avatar
Member: 234917
Yes finally I got the unlock code. Patience is needed.
Old 02-09-2012, 10:14   #48 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
Originally Posted by l0velyb0y View Post
Box Maintenance procedure started at 11:02:26
Service Tag: 61D9822C2C62C0434DD7EDF685358CA0
only no connect please update you server . thx
We had hang up server 10:45 till 11:00 try connect now, sorry for problems.
Old 02-09-2012, 16:05   #49 (permalink)
Member: 154834
Connecting to Cyclone Server...
Failed to Send SL3 COD File -> Failed to connect to Cyclone Server
Old 02-10-2012, 07:41   #50 (permalink)
Ciux's Avatar
Member: 234440
today 08:33h, (GMT +01:00)
Box Maintenance procedure started at 8:33:56
Service Tag: ****************************
when try to Maintenance Box.
Old 02-10-2012, 08:21   #51 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Just retry until you get it done.
Alex
Old 02-10-2012, 09:32   #52 (permalink)
Zegarek's Avatar
Member: 551345
Sonork: 100.1590161
Me too 10:30 gmt +01:00 :
Box Maintenance procedure started at 10:30:05
Service Tag: FDCA56xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Old 02-10-2012, 09:37   #53 (permalink)
Member: 1720739
I've just bought a cyclonebox and I can't activate it neither :
Box Registration Preparation procedure started at 10:30:40
Service Tag: F8EXXXXXXXXXXXXXXXXXXXXXXXX
Box Registration Preparation Error -> Can't connect to Cyclone Server
Box Registration Preparation procedure started at 10:36:34
Service Tag: F8EFEXXXXXXXXXXXXXXXXXXXXXXXX
Old 02-10-2012, 09:54   #54 (permalink)
Member: 1720739
Servers are working now.
Old 02-10-2012, 14:13   #55 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
I think this is an external attack to the Server. Who will be this Team???
Old 02-10-2012, 15:40   #56 (permalink)
Ciux's Avatar
Member: 234440
Box Maintenance procedure started at 16:35:29 (GMT +01:00)
Service Tag: ******************************
Still nothing.
All day I trying, and nothing. Can not use box and need to work.
Supporters need to tell when this server issue will be repaired!!
If can not make server up at the moment, give us some executable file which we can run locally, which will update firmware of our box offline. What else!
Old 02-10-2012, 19:39   #57 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
Still nothing.
We changed limits for maximum-I checked couple times and ask to try connect to users- nobody dont have problems, so sorry on this moment You need check Your internet connection, because for server site everything works fine.
Old 02-10-2012, 21:10   #58 (permalink)
Ciux's Avatar
Member: 234440
My Internet connection is good.
all my other boxes communicate without problem with they servers:
- SETOOL check how much credits left
- MICRO BOX checking activations on server without problem
- etc. etc.
Only Cyclone box, not work:
Box Maintenance:
Box Maintenance procedure started at 22:03:03 (GMT +01:00)
Check Credits:
Started credits checking procedure at 22:03:52 (GMT +01:00)
Failed to Check Credits -> Failed to connect to Cyclone Server
Support Area:
Support Area Launched, Engine Revision: 1.0.0.11948
Started authenthication procedure at 22:05:28 (GMT +01:00)
Box Service Tag: ********************
Authenthication error -> Failed to connect to Cyclone Server
Problem is not on my side.
Problem is, this last installer is not connecting correct to your server, or server is now accept connection from installer for some reason.
Old 02-10-2012, 21:18   #59 (permalink)
ptt
ptt's Avatar
Member: 348680
My internet connection s u c k s (12% packet loss), and i don't see any problem connecting to Cyclone Server.
Just checked few minutes ago.....
Box Maintenance procedure started at 06:14:14 p.m.
Service Tag:
Cyclone Server (1.0.0.686), Cyclone Box Team 2008-2011 - Ready.
Started credits checking procedure at 06:12:53 p.m.
Service Tag:
Credits: 349
Started authenthication procedure at 06:13:31 p.m.
Box Service Tag:
Ticket received, Veryfing it...
Server connection established, inflating data...
Ticket:		5F605871260ACDD7C18F86E82795BE6CE4D5E609
XML Revision: 	1.0
XML Encoding: 	iso-8859-1
Interface Revision:	1
Message of the day:
Welcome to Germany! Hosted by Hetzner A.G, Cyclone Support Interface, (c) 2009-2011 Cyclone Box Team
Server Timestamp:	10.02.2012 22:13:29 CET
Service Status:	OK
Ticket Status:	Ticket found
Ticket Box SN:
Task Name:	GetListing
Parsing files...
Files parsed OK!
Server time taken:	0.0434310436249s
None of the Team members that have access to the server are online now, i sent them a message about this issue, but from my side, server seems to be fine.....
sorry if i cant be of more help.
Old 02-10-2012, 21:23   #60 (permalink)
Ciux's Avatar
Member: 234440
I find where was problem in my case.
I make like this:
1. Uninstall Cyclone software
2. Install older version - v1.17
3. Then, make Box Maintenance
4. Then update Cyclone software v1.86
and now working.
If you first update Cyclone Software and after try Box Maintenance, will not work. At least for me was not.
The Following User Says Thank You to Ciux For This Useful Post:
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
Page generated in 0.52208 seconds with 12 queries
