07-20-2011, 07:26 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 838176 Status: Offline Thanks Meter: 57 | Sir, pls help me so sir please guide me fo this Code: Box Maintenance procedure started at 11:50:49 AM Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support Service Tag: 2D3E7FC82B6390C16712FE77289D0C02 Connecting to Cyclone Server Cyclone Server (1.0.0.667), Cyclone Box Team 2008-2011 - Ready. ========= Box Info ========= Box SN: C0000701 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D100034D First Name: mohan Surname: g Nickname: mohan Address: mumbai Country: India E-Mail: [email protected] Reseller: GPGIndustries, China Warranty Start Date: 2009-04-14 Warranty Period (months): 6 Warranty Stop Date: 2009-10-14 Warranty active: No ============================ Updating Security Area... Security Area Updated, Took: 0.125s Updating Main Firmware... Main Firmware Updated, Took: 17.297s Updating COM Emulator Firmware... COM Emulator Firmware Updated, Took: 1.297s Updating Secure Bootloader... Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Box Firmware Version Read Failed -> No answer from CBUS Failed to Upgrade Bootloader -> Failed to read Box Firmware Version - Try to Maintenance Box Secure Bootloader Update Skipped Disconnected from Cyclone Server Box Maintenance finished successfully Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Box Firmware Version Read Failed -> No answer from CBUS Initialization has failed -> Failed to read Box Firmware Version - Try to Maintenance Box |
07-20-2011, 08:39 | #3 (permalink) |
Member: 838176 Status: Offline Thanks Meter: 57 | sir i uninstalled old ver. then installed new ver. also setup new driver tryied different computer but same one thing i noted when i run nokia tool , the driver which is installed in device manager as "CYCLONE BOOTLODER" disappears( uninstalls)after tool runs so what may be the reason ? |
07-20-2011, 08:46 | #4 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | the main drivers and the bootloader drivers both r installed? when u run the cyclone soft and nokia tool then checked in device manager what new cyclone device appear? |
07-20-2011, 09:13 | #5 (permalink) | |
Member: 838176 Status: Offline Thanks Meter: 57 | Quote:
but while i run nokia tool i can see for seconds "cyclone bootloader" changes to "cyclone box" but disappears iam not a new user , using from long time but i am facing this problem from last few days so please guide me | |
07-20-2011, 13:25 | #9 (permalink) |
Member: 838176 Status: Offline Thanks Meter: 57 | yes sir i will try your solution but iam in confusion that after trying long time i found this box is working fine in one computer only i have three pcs , and not working on other two also same drivers is installed the surprise is this box is not working on the computer on which this box iam using from long time so what will be exact problem? |
07-20-2011, 14:48 | #10 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Poland
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | Quote:
Thats why short cable is very important ( longer cable - bigger resistance - ..... ). Box during Main FIrmware startup peaks quite much power usage (like 300-400mW) during clocks initialization, USB clock initialization, etc etc so if your port isn't enough powerfull, Box will reboot. | |
The Following User Says Thank You to kaisak For This Useful Post: |
07-20-2011, 15:43 | #11 (permalink) |
Member: 838176 Status: Offline Thanks Meter: 57 | sir as you guided me i checked again by shortened usb power cable and also shorted the low ohms resisters (65 ohms)which are to input for d+ & d- but not working for me , today iam tired to do one job see this is where it is working fine Code: Box Maintenance procedure started at 7:08:30 PM Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support Service Tag: 2D3E7FC82B6390C16712FE77289D0C02 Connecting to Cyclone Server Cyclone Server (1.0.0.667), Cyclone Box Team 2008-2011 - Ready. ========= Box Info ========= Box SN: C0000701 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D100034D First Name: mohan Surname: g Nickname: mohan Address: mumbai Country: India E-Mail: [email protected] Reseller: GPGIndustries, China Warranty Start Date: 2009-04-14 Warranty Period (months): 6 Warranty Stop Date: 2009-10-14 Warranty active: No ============================ Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Updating COM Emulator Firmware... COM Emulator Update Skipped, Not allowed Updating Secure Bootloader... Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Firmware: Cyclone Nokia/Blackberry Application v01.66, (Jul 19 2011 16:55:18, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Boot Agent: Cyclone Secure BootAgent Server v3.01 (C) KarwosSoft 2010 wk41 Bootloader is already Up-to-date Secure Bootloader Update Skipped Disconnected from Cyclone Server Box Maintenance finished successfully Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.66, (Jul 19 2011 16:55:18, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0000701 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D100034D Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.95v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.77v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.75v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE see here it is not working on two computers Code: Box Maintenance procedure started at 6:54:51 PM Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support Service Tag: 2D3E7FC82B6390C16712FE77289D0C02 Connecting to Cyclone Server Cyclone Server (1.0.0.667), Cyclone Box Team 2008-2011 - Ready. ========= Box Info ========= Box SN: C0000701 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D100034D First Name: mohan Surname: g Nickname: mohan Address: mumbai Country: India E-Mail: [email protected] Reseller: GPGIndustries, China Warranty Start Date: 2009-04-14 Warranty Period (months): 6 Warranty Stop Date: 2009-10-14 Warranty active: No ============================ Updating Security Area... Security Area Updated, Took: 0.125s Updating Main Firmware... Main Firmware Updated, Took: 17.297s Updating COM Emulator Firmware... COM Emulator Firmware Updated, Took: 1.297s Updating Secure Bootloader... Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Box Firmware Version Read Failed -> No answer from CBUS Failed to Upgrade Bootloader -> Failed to read Box Firmware Version - Try to Maintenance Box Secure Bootloader Update Skipped Disconnected from Cyclone Server Box Maintenance finished successfully Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Box Firmware Version Read Failed -> No answer from CBUS Initialization has failed -> Failed to read Box Firmware Version - Try to Maintenance Box |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
