07-11-2009, 12:19 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: ****** Age: 45
Member: 801286 Status: Offline Sonork: [email protected] Thanks Meter: 54 | thank you cyclon box team flash 6280 ok Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: xxxxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06 Initializing security card... Card Serial Number: xxxxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.98v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.88v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 69 products, Filtering BB5 Products - wait... 7 Products left after filtering. Ready. Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone WMDRM Store not supported Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1490010BD470005458F4E2631A0F0B03AC95DD6D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22FE00000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC APE Subsystem Not Found Storing NPC... CMT CCC Not Found CMT HWC Not Found Storing VARIANT... Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Backing up simlock... MCU Version V 05.92 MCU Date 07-09-06 Product RM-78 Manufacturer (c) Nokia IMEI 357603004804670 Mastercode 611653351 Simlock backup OK, saved to RM-78_357603004804670_11072009_020444 ã.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm7830006.430.mcusw (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1490010BD470005458F4E2631A0F0B03AC95DD6D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F rm7830006.430.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22FE00000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000202BF, NOR EraseArea[0,CMT]: 0x00020300-0x000252FF, NOR EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR EraseArea[0,CMT]: 0x00200000-0x0037FFFF, NOR EraseArea[0,CMT]: 0x00380000-0x011DDFFF, NOR EraseArea[0,CMT]: 0x011DE000-0x011DEFFF, NOR EraseArea[0,CMT]: 0x011DF000-0x011DFFFF, NOR EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR Waiting 320s for erasure finish... Erase taken 103.203s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT PMM_CONF Certificate... Writing CMT SBIF_CONF Certificate... Programming Status OK! All blocks written OK! Time taken 116.188s Restarting MCU... Processing rm7830006.430.mcusw (APE)... Processing rm783006.43.ppm_g (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1490010BD470005458F4E2631A0F0B03AC95DD6D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F rm783006.43.ppm_g, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22FE00000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC Started group flash erase EraseArea[0,CMT]: 0x011E0000-0x016DFFFF, NOR Waiting 320s for erasure finish... Erase taken 24.360s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 27.188s Restarting MCU... Processing rm783006.43.ppm_g (APE)... Processing rm7830006.43.image_g (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1490010BD470005458F4E2631A0F0B03AC95DD6D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F rm7830006.43.image_g, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22FE00000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC Started group flash erase EraseArea[0,CMT]: 0x016E0000-0x01FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 57.312s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 19.984s Restarting MCU... Processing rm7830006.43.image_g (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V 06.43 MCU Date 30-03-07 Product RM-78 Manufacturer (c) Nokia IMEI 357603004804670 Mastercode 611653351 IMEI Spare 3A75060340086407 IMEI SV 3375060340086417F8000000 PPM V 06.43, 30-03-07, RM-78, (c) Nokia, G CNT Content: g, V 06.43, 30-03-07, RM-78, (c) Nokia PSN SJE867136 Product Code 0542821 Basic Product Code 0520041 PSD 0000001F00000000 RETU 32 TAHVO 52 AHNE 30 HW 1000 RFIC 17191719 DSP pb05w46v49 LCD SHARP Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
07-11-2009, 15:28 | #2 (permalink) |
Member: 801286 Status: Offline Sonork: [email protected] Thanks Meter: 54 | and new log 7510 rm 398 Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: xxxxxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06 Initializing security card... Card Serial Number: D20005B1 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.00v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.95v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 69 products, Filtering BB5 Products - wait... 7 Products left after filtering. Ready. Retrieving Variants for Product RM-398 - wait... 131 Variants Retrieved Processing pre flash tasks... Read RPL operation not possible for USB bus Backing up simlock... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Selecting USB Flashing Method... [BB5 ADL Server]: Found 0 active devices [BB5 ADL Server]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Proceeding with Dead USB Mode Press power-on shortly to run USB Boot ROM [BB5 BootRom]: Found 1 active devices [Nokia USB Flashing Generic]: Opening Connection [Nokia USB Flashing Generic]: Port opened OK! CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0B3001174CA87D5605AE56F0D97BDB99D99AD3EE CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_ROM_ID: 273F6D55DFAAF68F DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5 Sending RAW Loader... Sending CMT UPDAPP Certificate and Data... Waiting for ADL Server Startup... [BB5 ADL Server]: Found 1 active devices [Nokia BB5 ADL Loader USB Generic]: Opening Connection [Nokia BB5 ADL Loader USB Generic]: Port opened OK! ADL Server Startup Confirmed OK! Processing rm398__03.80.mcusw (CMT)... rm398__03.80.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0023FFFF, NOR EraseArea[0,CMT]: 0x015A0000-0x0177FFFF, NOR EraseArea[0,CMT]: 0x00240000-0x0159FFFF, NOR EraseArea[0,CMT]: 0x02140000-0x025DFFFF, NOR Erase taken 133.203s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT ISA+DYNSW Certificate... Programming Status OK! All blocks written OK! Time taken 91.375s Processing rm398__03.80.ppm_ma (CMT)... rm398__03.80.ppm_ma, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x01780000-0x0213FFFF, NOR Erase taken 46.31s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 25.563s Processing rm398__03.80.image_ma (CMT)... rm398__03.80.image_ma, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x025E0000-0x0297FFFF, NOR EraseArea[0,CMT]: 0x02980000-0x03FBFFFF, NOR Erase taken 176.172s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 33.266s Restarting CMT... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Factory defaults OK Reading info... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Failed to read info -> Phone not detected Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
07-11-2009, 16:26 | #3 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | Thanks For Feed Back But Post Here http://forum.gsmhosting.com/vbb/showthread.php?t=709123 |
07-11-2009, 16:26 | #4 (permalink) |
Big Thanks to Cyclone Box Team | Kashif Khan | Cyclonebox | 5 | 10-02-2009 16:10 |
thank you cyclon box team | hamidove | Cyclonebox | 0 | 07-13-2009 10:29 |
thank you cyclone team | nokia-ps | Cyclonebox | 2 | 07-12-2009 19:11 |
thank you Infinity-Box a38 unlocker ok | ceptel | Infinity-Box | 0 | 12-21-2006 21:45 |
