Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-19-2011, 01:08   #1 (permalink)
Member: 1440240
Sonork: JiBriL DcTeAm
Thanks Meter: 116
Can I Repair E65 Blue Screen with Cyclone?
I look for help to repair
PHP Code:
E65 RM-208 blue screen with
Cyclone after unlock secuuitiy code . I flashed with latest firmware version but nothing happened it still same . I've som advices for solve this probleme .
Old 04-19-2011, 05:06   #2 (permalink)
dabing's Avatar
Member: 857401
Sonork: 1596086
Thanks Meter: 129
try this flash put mcu and flash
Old 04-19-2011, 09:45   #3 (permalink)
Member: 1440240
Thanks Meter: 116
Originally Posted by dabing View Post
I've select files as that :
Mcu :all_rapido_blank_504KB_pmm_10.fpsx
Ppm :m208_m128_h20_ka_prod_406337400_v01_variant.bin
Cnt :rm208_cp_3.0.fpsx
I had these error while flash proced .
Log :
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing all_rapido_blank_504KB_pmm_10.fpsx (CMT)...
Booting CMT...
APE_SYSTEM_ASIC_ID: 17100708
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: D9984AC8E33BB4A3A9A926CEB69EE9335689053F
APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000
APE_BOOT_ROM_CRC: 1DFD6613
APE_SECURE_ROM_CRC: 2C872FD4
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B21
CMT_PUBLIC_ID: 09A0010F7EA60154E0A6A354C6625F523BB89E35
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
all_rapido_blank_504KB_pmm_10.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5
Searching for BootCode: Single Line 8Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Flashbus Write baud set to 650Kbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
Processing Flash Image Failed -> Not found required Algorithm
Failed to Process all Image files -> Failed to process all_rapido_blank_504KB_pmm_10.fpsx
Old 04-19-2011, 14:20   #4 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
dear the pmm that u give him,is for e 66,,ok,,not for e65,,so plz don,t teach wrong method
The Following User Says Thank You to alkhaleejmobile For This Useful Post:
Old 04-19-2011, 15:42   #5 (permalink)
Member: 1440240
Thanks Meter: 116
can you give ( link or share there ) good for E65 ?
Old 04-19-2011, 16:56   #6 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
dear,,plz first do full flash with latest firmware.
and post here flashing logs,,,,self test and info,if possible,
so plz post here ,yr phone logs,
thanks
Old 04-19-2011, 17:25   #7 (permalink)
taimoorkhan's Avatar
Member: 101548
Sonork: 100.1611535
Thanks Meter: 210
brother put this file in mcu nd flash it ur problem will b solve.....
File Type: rar E66_blank_504KB_pmm_10.rar (707 Bytes, 69 views)
The Following 2 Users Say Thank You to taimoorkhan For This Useful Post:
Old 04-20-2011, 19:23   #8 (permalink)
Member: 1440240
Thanks Meter: 116
This is job info after many methode .
Flash Log :
Processing rm208_m128_h20_ka_prod_406337400_c00_combined.bin (CMT)...
Booting CMT...
CMT Ready!
rm208_m128_h20_ka_prod_406337400_c00_combined.bin, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1710 UNISTORE-II-1.2.1 ALG
Flashbus Write baud set to 51Kbits
FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR
FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V
RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Box VPP disabled
Internal CMT Phone VPP Enabled
Warning: PAPUBKEYS Hash Missing!
Flashbus Write baud set to 5.0Mbits
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x001E0000-0x00708315, NOR
EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00080000-0x0009FFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x000DFFFF, NOR
EraseArea[0,CMT]: 0x00880000-0x0089FFFF, NOR
EraseArea[0,CMT]: 0x00F00000-0x00FDFFFF, NOR
Waiting 320s for erasure finish...
Erase taken 1.766s
Writing all blocks...
Initializing TurboCache...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
Writing CMT PAPUBKEYS Certificate...
Writing CMT ADL Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 92.766s
Flashing Speed: 3760,23 kBit/S
Restarting MCU...
Processing rm208_m128_h20_ka_prod_406337400_c00_combined.bin (APE)...
Booting CMT...
CMT Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: 0266638E9C2164FC6B5194ED596A6A251C699896
helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5
FlashChip[0,APE]: 0x0098007800A500C0, Toshiba, NAND
FlashContent[0,APE]: 00020000000600000000000000000000, NAND
FlashChip 0x00980078 (Toshiba), Size: 128MBytes, VPP: 21V
h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG
Box VPP disabled
Internal APE Phone VPP Enabled
PAPUBKEYS Hash for APE: 0266638E9C2164FC6B5194ED596A6A251C699896
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x00000000-0x0007FFFF, NAND
EraseArea[0,APE]: 0x00080000-0x000803FF, NAND
EraseArea[0,APE]: 0x000C0000-0x03CFFFFF, NAND
Erase taken 5.125s
TurboCache Loaded!
Writing APE KEYS Certificate...
Writing APE X-LOADER Certificate...
Writing APE PRIMAPP Certificate...
Writing APE SOS+LOADER Certificate...
Writing APE ADL Certificate...
Writing APE SOS+XZIP Certificate...
Writing APE PASUBTOC Certificate...
Writing APE PAPUBKEYS Certificate...
Writing APE SOS*CORE Certificate...
Writing APE SOS+ROFS Certificate...
Writing APE SOS+ROFX Certificate...
All blocks written OK! Time taken 301.735s
Flashing Speed: 1156,05 kBit/S
Restarting MCU...
Processing rm208_m128_h20_ka_prod_406337400_v01_variant.bin (CMT)...
Processing rm208_m128_h20_ka_prod_406337400_v01_variant.bin (APE)...
Booting CMT...
CMT Ready!
rm208_m128_h20_ka_prod_406337400_v01_variant.bin, Type: Flash Image, Algo: BB5, OMAP1710 UNISTORE-II-1.2.1 ALG, BB5, BB5 ALGORITHM
Flashbus Read baud set to 100Kbits
Box VPP disabled
Box VPP disabled
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x02860000-0x03CFFFFF, NAND
Erase taken 1.890s
TurboCache Loaded!
All blocks written OK! Time taken 287.625s
Flashing Speed: 440,61 kBit/S
Restarting MCU...
Processing rm208_cp_3.0.fpsx (CMT)...
Processing rm208_cp_3.0.fpsx (APE)...
Booting CMT...
CMT Ready!
rm208_cp_3.0.fpsx, Type: Flash Image, Algo: BB5, OMAP1710 UNISTORE-II-1.2.1 ALG, BB5, BB5 ALGORITHM
Box VPP disabled
Box VPP disabled
TurboCache Loaded!
All blocks written OK! Time taken 10.188s
Flashing Speed: 114,60 kBit/S
Restarting MCU...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
MCU Version V 4.0615.2
MCU Date 05-06-08
Product RM-208 (Nokia E65)
Manufacturer (c) Nokia.
IMEI 353261010705144
Mastercode 7041505660
IMEI Spare 3A35620101071504
IMEI SV 3335620101071544F0000000
PSN SIH592282
Product Code 0542318
Basic Product Code 0536849
PSD 0000000000000000
WLAN MAC 00197945BD92
RETU 15
TAHVO 21
AHNE 30
HW 0702
RFIC 17141714
DSP A06w14PB_08w10
Simlock Server SIMLOCK SERVER VERSION 63
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Selftest log :
Selftests to proceed: 26
Passed ST_TAHVOINT_TEST
Passed ST_UEM_CBUS_IF_TEST
Passed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Passed ST_SIM_IO_CTRL_LOOP_TEST
Passed ST_SIM_LOCK_TEST
Passed ST_SECURITY_TEST
Passed ST_PWR_KEY_TEST
Passed ST_CURRENT_CONS_TEST
Passed ST_BACKUP_BATT_TEST
Passed ST_WARRANTY_TEST
Failed ST_CMT_APE_WAKEUP_TEST
Passed ST_SLEEPCLK_FREQ_TEST
Passed ST_HOOKINT_TEST
Passed ST_BTEMP_TEST
Passed ST_EXT_DEVICE_TEST
Failed ST_CDSP_RF_BB_IF_TEST
Failed ST_CDSP_RF_SUPPLY_TEST
Failed ST_CDSP_TX_IQ_TEST
Failed ST_CDSP_TXC_DATA_TEST
Failed ST_CDSP_PWR_DETECTOR_BIAS_TEST
Failed ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Failed ST_CDSP_WCDMA_TX_POWER_TEST
Failed ST_CDSP_RX_IQ_LOOP_BACK_TEST
Failed ST_CDSP_GSM_TX_POWER_TEST
Selftests done, Tests total: 26, Tests passed: 15, Tests not passed: 11
BLANK_PPM job log :
Read RPL operation not possible for Old USB Flashing Method
Backing up simlock...
MCU Date 05-06-08
Simlock backup OK, saved to RM-208_353261010705144_20042011_182546.SLBackup.PM
Backup simlock thread finished, continuing...
Processing E66_blank_504KB_pmm_10.fpsx (CMT)...
Booting CMT...
CMT Ready!
Processing Flash Image Failed -> Given image file is not suitable for this CMT System ASIC ID (Tick "Skip CMT ID Check" if you are sure that given Image File is suitable for this phone!).
Failed to Process all Image files -> Failed to process E66_blank_504KB_pmm_10.fpsx
Phone are still blue screen
Old 04-20-2011, 19:33   #9 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
check hardware ,, open ye set ,and clean cable connector ,,,also clean,3 ics,crystal,,post result
Old 07-14-2012, 16:32   #10 (permalink)
shahadat87j's Avatar
Member: 1783085
Sonork: 100.1618518
Thanks Meter: 32
Old 07-14-2012, 17:55   #11 (permalink)
Member: 1783085
Sonork: 100.1618518
Thanks Meter: 32
[IMG]
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.33426 seconds with 10 queries
