06-23-2011, 20:38 | #1 (permalink) |
Junior Member Join Date: Oct 2008
Member: 885003 Status: Offline Sonork: harry Thanks Meter: 1 | Unlocking problem Nokia E71 [ SL3 Phone --> Use BF method ] BB5 Unlock Started... MCU Version V ICPR71_09w47.5 MCU Date 24-05-10 Product RM-357 (Nokia E71) Manufacturer (c) Nokia IMEI 353782041021458 Mastercode 2456773765 Simlock Server SIMLOCK SERVER Simlock Key 3102600016495098 Simlock Profile 9000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310410 Simlock [1,2] State: CLOSED Type: GID Data: DEFF Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310260 Simlock [2,2] State: CLOSED Type: GID Data: DEFF Reading Security Block... Security block OK and saved to "RM-357_353782041021458_6232011_33301 PM.SecurityBlock.PM" "0AF0000757A600527CB843E10930EB66E5C990B9.C0000DEF " Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) BB5 Unlock Failed -> Failed to read NCK Codes (both algos failed), Box Reported: Security Section Not Found (SL3 phone?) |
06-24-2011, 00:28 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Middle East
Member: 950386 Status: Offline Thanks Meter: 114 | Try this..... You used NCK Calculation New Method to try and unlock the E71 = Failed Now try another cyclone unlock method like RPL Calculation Method? or try Nokia Calculation Old Method. Kind Regards |
06-24-2011, 00:41 | #4 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Quote:
This is SL3 Phone. Regards Haicha | |
06-24-2011, 18:02 | #5 (permalink) |
Member: 885003 Status: Offline Sonork: harry Thanks Meter: 1 | Rpl Calculation method for E71 As you told me try with RPL calculation method i did but no luck... BB5 Unlock Started... MCU Version V ICPR71_09w47.5 MCU Date 24-05-10 Product RM-357 (Nokia E71) Manufacturer (c) Nokia IMEI 353782041021458 Mastercode 2456773765 Simlock Server SIMLOCK SERVER Simlock Key 3102600016495098 Simlock Profile 9000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310410 Simlock [1,2] State: CLOSED Type: GID Data: DEFF Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310260 Simlock [2,2] State: CLOSED Type: GID Data: DEFF Reading Security Block... Security block OK and saved to "RM-357_353782041021458_6242011_10029 PM.SecurityBlock.PM" "0AF0000757A600527CB843E10930EB66E5C990B9.C0000DEF " Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... BB5 Unlock Failed -> Simlock NOT ACCEPTED ! Maybe is SL3 phone? |
06-24-2011, 18:12 | #7 (permalink) |
Member: 885003 Status: Offline Sonork: harry Thanks Meter: 1 | Nck calculation old method- still need help Even i try with NCK OLD Calcualtion method still no luck need help BB5 Unlock Started... MCU Version V ICPR71_09w47.5 MCU Date 24-05-10 Product RM-357 (Nokia E71) Manufacturer (c) Nokia IMEI 353782041021458 Mastercode 2456773765 Simlock Server SIMLOCK SERVER Simlock Key 3102600016495098 Simlock Profile 9000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310410 Simlock [1,2] State: CLOSED Type: GID Data: DEFF Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310260 Simlock [2,2] State: CLOSED Type: GID Data: DEFF Reading Security Block... Security block OK and saved to "RM-357_353782041021458_6242011_10408 PM.SecurityBlock.PM" Determining PA Simlock... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0AF0000757A600527CB843E10930EB66E5C990B9 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (old method) BB5 Unlock Failed -> Unsupported Rootkey Hash for selected Unlock Method, this is critic |
