Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 05-07-2012, 10:42   #1 (permalink)
GSV
Member: 2425
update problem
update problen with installer 1.20
Old 05-07-2012, 11:46   #2 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
See point nr 1 - we need your service tag.
Old 05-07-2012, 11:51   #3 (permalink)
GSV
Member: 2425
Cyclone Box Service Tag: 9B283B0B331DA8D9478770A7191F7A10
Old 05-07-2012, 21:29   #4 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
help probleme in new cyclone box instaler 2012
Old 05-07-2012, 21:31   #5 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Try now.....
br
karwos
Old 05-08-2012, 08:49   #6 (permalink)
GSV
Member: 2425
update done now without errors, but Nokia module start with error
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.01, (Apr 29 2012 16:16:15, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0000E62
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06
Initializing security card...
Security Card Process APDU Error -> Received TPDU NAD byte is not addressed for this device
Security Card Fetch Card SN Error -> APDU Process problem
Initialization has failed -> Problem with reading Card Serial Number
or next time
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Initializing box...
Security Card Reset Error -> Possible error: Security card PTS protocol negotiation failed
Initialization has failed -> Security card was not found!
Old 05-08-2012, 08:54   #7 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Could you check, please, if the smartcard is properly fitted in its holder inside the box?
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 05-08-2012, 09:13   #8 (permalink)
GSV
Member: 2425
Thanks, disasemmble and refit card - ok now.
Box in Main Mode...
Initializing box...
Card Serial Number: D2000720
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4,95v PASSED
MCU Voltage 3,28v PASSED
Core Voltage 1,76v PASSED
VBAT Voltage 0,01v PASSED
VBAT Voltage 4,88v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Internal Box VPP Enabled
VPP Voltage 4,88v PASSED
Box VPP disabled
VPP Voltage 0,00v PASSED
External Box VPP Enabled
VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 240.308MB
Avaiable Virtual Memory: 1.510GB
Avaiable Pagefile: 1.674GB
Initializing FBUS...
All initialized - Ready to work
Old 05-08-2012, 11:57   #9 (permalink)
Member: 259706
problem with new update
i have cyclone box sn:C0002016 . service tag: 7483BD857629AFF65BD2C48B3ABAF12DB . on nokia tool said again and again upgrade to v02.01 . please help thank you.
Old 05-08-2012, 12:22   #10 (permalink)
Member: 1067971
CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe)
Box Hardware Platform Read Failed -> No answer from CBUS
Failed to Determine Product Settings -> Failed to Read Box HW Platform
Failed to Check Clip -> Failed to determine Product Type
how to solve this, please help
Old 05-18-2012, 17:25   #11 (permalink)
Member: 514756
need helBox Maintenance procedure started at 21:24:32
Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support
Service Tag: 65E77B8BC71E841E605FC56F87EB0685
Connecting to Cyclone Server
Cyclone Server (2.0.0.42), Cyclone Box Team 2008-2012 - Ready.
Old 05-18-2012, 17:35   #12 (permalink)
Member: 514756
Help moulnisky
Box Maintenance procedure started at 21:33:04
========= Box Info =========
Box SN: C0007326
HW Revision: B, Suitable for: Production, Case: Unknown, MCU Manufacture Time: 2009, wk19
Set: Classic Box, TX2 Adapter, 100 Credits, 6 Months Warranty
Box registration status: Registered OK
Paired Card SN: D00D020F
First Name: Juzepe
Surname: Juzepe
Nickname: Juzepe
Address: Bichciv
Country: UA
E-Mail: Juzepe@ukr.net
Reseller: GSMService, Russia
Warranty Start Date: 2012-05-17
Warranty Period (months): 6
Warranty Stop Date: 2012-11-17
Warranty active: Yes
Updating Security Area...
Security Area Update Skipped, Not allowed
Updating Main Firmware...
Main Firmware Update Skipped, Not allowed
Updating COM Emulator Firmware...
COM Emulator Update Skipped, Not allowed
Updating Secure Bootloader...
Old 05-18-2012, 18:31   #13 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Originally Posted by vvvmmm View Post
Help moulnisky
Box Maintenance procedure started at 21:49:25
Box SN: C0007326
First Name: Juzepe
Surname: Juzepe
Nickname: Juzepe
Address: Bichciv
Country: UA
Failed to Upgrade Bootloader -> No connection was established, or box is not in needed mode
Secure Bootloader Update Skipped, Not allowed or not needed
Disconnected from Cyclone Server
Box Maintenance finished successfully
Job done : you can use box wizard now
please guys, use the dedicate thread for these situations: If you need to do and get Update Skipped, Not allowed- write there SN box for update
Alex
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-21-1999 18:43
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:39
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.36064 seconds with 12 queries
