03-11-2013, 11:11 | #1 (permalink) |
No Life Poster Join Date: Sep 2012
Member: 1813192 Status: Offline Thanks Meter: 60 | what is problem with nokia c-2 i c,ant reed CMT_SYSTEM_ASIC_ID: 000000010000022600000001020C192102044100 CMT_EM_ASIC_ID: 00001051 CMT_EM_ASIC_ID: 00001060 CMT_PUBLIC_ID: 1FA0010F70201449374658EC1EB5893059344767 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT_BOOT_ROM_CRC: 67E82268 CMT_SECURE_ROM_CRC: F29CEA60 CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv40_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. CBUS Request Error -> CBUS Response wrong header Prepare phone failed with message -> Failed to get CMT Configuration Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phon |
03-11-2013, 14:02 | #2 (permalink) |
Member: 1813192 Status: Offline Thanks Meter: 60 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0002142 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: D40003BC Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.80v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.80v PASSED VBAT Voltage 1.24v PASSED VBAT Voltage 4.71v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.79v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 89 Avaiable Physical Memory: 1.3GB Avaiable Virtual Memory: 1.892GB Avaiable Pagefile: 3.37GB Initializing FBUS... All initialized - Ready to work Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600000001020C192102044100 CMT_EM_ASIC_ID: 00001051 CMT_EM_ASIC_ID: 00001060 CMT_PUBLIC_ID: 2980020C02F410492CD5CDD1D520FDB9A95E0DF9 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT_BOOT_ROM_CRC: 67E82268 CMT_SECURE_ROM_CRC: F29CEA60 CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv40_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Prepare phone failed with message -> Failed to set CMT Transmission Mode Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone |
03-11-2013, 15:39 | #5 (permalink) |
Major Poster Join Date: Oct 2011
Member: 1676491 Status: Offline Thanks Meter: 2 | deves to have the battery fully charged my friend it is worth reviewing the logic of the computer may be bad heco entry and you'll have a bad read or process on your first flasea therefore depending friend that you want to do |
