Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 06-03-2012, 22:15   #1 (permalink)
atiq022's Avatar
Member: 587405
why cant i unlock nokia bb5
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.03, (Jun 1 2012 21:15:43, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C00059F5
HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk44
Initializing security card...
Card Serial Number: D00905AC
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.05v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 1.11v PASSED
VBAT Voltage 4.91v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 258.976MB
Avaiable Virtual Memory: 1.482GB
Avaiable Pagefile: 1.8GB
Initializing FBUS...
All initialized - Ready to work
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 12E00019E49001585D97C18770C025D50B5DA98B
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: A8C1D671
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND
Requested Algorithm: XSR 1.5 (CMT)
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: B5385A493D2188678E1FD88DA506480F874E2949
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
BB5 Unlock Started...
MCU Version V ICPR72_08w44.1
MCU Date 10-11-08
Product RM-333 (Nokia N85)
Manufacturer (c) Nokia
IMEI 355708024805433
Mastercode 7652145110
Simlock Server SIMLOCK SERVER
Simlock Key 2140100000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 1
Simlock FBUS Cnt 1
Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F
Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F
Reading Security Block...
Security block OK and saved to "RM-333_355708024805433_632012_101045 PM.SecurityBlock.PM"
WARNING: "12E00019E49001585D97C18770C025D50B5DA98B.C00059F5 " Not Exists, Will read it...
Reading CYC file from phone...
Booting CMT...
CMT Ready!
New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5
Sending Auxiliary Loader...
Auxiliary Loader Sent!
Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs
Custom loader running OK! Working...
Neither CYC file and exists or failed to read it from phone (Readed Unique Data is probably corrupted)
BB5 Unlock Failed -> Failed to obtain Phone Unique Data
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
MCU Date 10-11-08
Simlock Key Cnt 1
Simlock FBUS Cnt 1
Security block OK and saved to "RM-333_355708024805433_632012_101109 PM.SecurityBlock.PM"
Determining PA Simlock...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: PM Security Block Calculation
Booting CMT...
CMT Ready!
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Using OLD BB5 FLASHING PROTOCOL
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Received Security Block OK !
Writing Security Block...
BB5 Unlock Failed -> Failed to write Security Block
MCU Date 10-11-08
Simlock Key Cnt 1
Simlock FBUS Cnt 1
Security block OK and saved to "RM-333_355708024805433_632012_101140 PM.SecurityBlock.PM"
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
Booting CMT...
CMT Ready!
Booting CMT...
Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem
Prepare phone failed with message -> Failed to Boot CMT
Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
MCU Date 10-11-08
Simlock Key Cnt 1
Simlock FBUS Cnt 1
Security block OK and saved to "RM-333_355708024805433_632012_101421 PM.SecurityBlock.PM"
Booting CMT...
CMT Ready!
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
MCU Date 10-11-08
Simlock Key Cnt 1
Simlock FBUS Cnt 1
Security block OK and saved to "RM-333_355708024805433_632012_101510 PM.SecurityBlock.PM"
Booting CMT...
CMT Ready!
Booting CMT...
CMT Ready!
Searching for BootCode: Single Line 8Bit
Prepare phone failed with message -> Not found required CMT Secondary Loader
Booting CMT...
CMT Ready!
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
MCU Date 10-11-08
Simlock Key Cnt 1
Simlock FBUS Cnt 1
Security block OK and saved to "RM-333_355708024805433_632012_101657 PM.SecurityBlock.PM"
Booting CMT...
CMT Ready!
Old 06-04-2012, 00:50   #2 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Are you using the TX2 adapter? (The yellow cable in bundle with the box)
Alex
Old 06-04-2012, 11:35   #3 (permalink)
atiq022's Avatar
Member: 587405
yes i use the tx2 adapter
Old 06-04-2012, 11:44   #4 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
are you removing the battery and doing what asked when due?
N85 is a rapido mobile
Alex
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.34709 seconds with 11 queries
