09-15-2009, 18:32 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303402 Status: Offline Thanks Meter: 346 | Write Rpl Problem After Ask2Rpl 5610 after ask2rpl from server write to phone, the phone can not get info 5610 rm242 http://rapidshare.com/files/280503972/ask_rpl.zip |
The Following User Says Thank You to aswancamel For This Useful Post: |
09-15-2009, 18:53 | #2 (permalink) |
Member: 303402 Status: Offline Thanks Meter: 346 | here are the logs Code: MCU Version V 04.81 MCU Date 22-11-07 Product RM-242 Manufacturer (c) Nokia IMEI 12345610654321? Failed to read info -> '?' is not a valid integer value MCU Version V 04.81 MCU Date 22-11-07 Product RM-242 Manufacturer (c) Nokia IMEI 12345610654321? Failed to read info -> '?' is not a valid integer value Skipping RPL decryption... Erasing Security... Failed to Write RPL File -> Canceled by user Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Simlock... Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key NOT ACCEPTED ! Writing CMLA key... CMLA Key NOT ACCEPTED ! Writing WMDRM PD Data... WMDRM PD Data NOT ACCEPTED ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0AF00011E5814650A558B7A420159EB12F018E24 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Acc |
09-15-2009, 22:53 | #9 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | back-up all certs and thick on "erase security" before writing the rpl BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
09-16-2009, 13:52 | #10 (permalink) | |
Member: 303402 Status: Offline Thanks Meter: 346 | Quote:
but i tried with jaf here are logs Code: JAF version 1.98.64 Detected PKEY: 9000DCCC Card life counter: 93.88% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 20405, Library version: 30115 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.17.0 Changing mode...Done! Scanning RPL file... NPC DATA OK... VARIANT DATA NOT FOUND... CCC DATA OK... HWC DATA OK... NPC APE DATA NOT FOUND... VARIANT APE DATA NOT FOUND... CCC APE DATA NOT FOUND... HWC APE DATA NOT FOUND... SIMLOCK DATA OK... SIMLOCK KEY DATA OK... SUPERDONGLE KEY DATA OK... CMLA KEY DATA OK... WMDRM PD DATA OK... Connecting to phone... Writing SIMLOCK DATA and SIMLOCK DATA KEY... Writing SUPER DONGLE KEY... Writing CMLA KEY DATA... Writing WMDRM PD DATA... FAST PHONE detected! CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 220C00EC <=> SAMSUNG (SEC) -> K5G1257ATM CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Writing NPC DATA... Writing CCC DATA... Writing HWC DATA... Restarting phone... Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 04.81 22-11-07 RM-242 (c) Nokia PCI version: RFIC version: 17141715 DSP version: ICPR71_07w43 LCD version: SHARP PPM version: V 04.81 22-11-07 RM-242 (c) Nokia x BT MCM version: 2222-101B Retu version: 15 Tahvo version: 22 Production serial number: 0 Product code: Module code: Basic production code: Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 358652016400026 IMEI spare to net: 3A 85 56 02 61 04 00 02 IMEI SV to net: 33 85 56 02 61 04 00 12 F6 LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN done 99 % write pm 1 & 309 = 100% done why cyclone failed do that...(but i am not blame that) th | |
09-16-2009, 13:53 | #11 (permalink) | |
but i tried with jaf here are logs Code: JAF version 1.98.64 Detected PKEY: 9000DCCC Card life counter: 93.88% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 20405, Library version: 30115 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.17.0 Changing mode...Done! Scanning RPL file... NPC DATA OK... VARIANT DATA NOT FOUND... CCC DATA OK... HWC DATA OK... NPC APE DATA NOT FOUND... VARIANT APE DATA NOT FOUND... CCC APE DATA NOT FOUND... HWC APE DATA NOT FOUND... SIMLOCK DATA OK... SIMLOCK KEY DATA OK... SUPERDONGLE KEY DATA OK... CMLA KEY DATA OK... WMDRM PD DATA OK... Connecting to phone... Writing SIMLOCK DATA and SIMLOCK DATA KEY... Writing SUPER DONGLE KEY... Writing CMLA KEY DATA... Writing WMDRM PD DATA... FAST PHONE detected! CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 220C00EC <=> SAMSUNG (SEC) -> K5G1257ATM CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Writing NPC DATA... Writing CCC DATA... Writing HWC DATA... Restarting phone... Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 04.81 22-11-07 RM-242 (c) Nokia PCI version: RFIC version: 17141715 DSP version: ICPR71_07w43 LCD version: SHARP PPM version: V 04.81 22-11-07 RM-242 (c) Nokia x BT MCM version: 2222-101B Retu version: 15 Tahvo version: 22 Production serial number: 0 Product code: Module code: Basic production code: Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 358652016400026 IMEI spare to net: 3A 85 56 02 61 04 00 02 IMEI SV to net: 33 85 56 02 61 04 00 12 F6 LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN write pm 1 & 309 = 100% done why cyclone failed do that...(but i am not blame that) thanks br aswancamel | |
3110c after repair SD, write RPL problem | Options Media | Nokia Base Band 5 ( BB-5 ) | 1 | 02-16-2010 15:42 |
3110c after repair SD write RPL problem | Options Media | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 02-15-2010 12:58 |
N91 Write rpl problem | majidjony | MT-BOX | 4 | 12-07-2007 10:00 |
N91 write rpl problem | thxseto | MT-BOX | 3 | 09-10-2007 09:59 |
