03-22-2010, 15:35 | #1 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | About 6235 CPU Due to the increase in problems with MT6235 Cpu, we are now asking our Dear Customers to stop working with this CPU until we completely solve the Issue. Old Encryption Base 128 seems to be working on the MT6235 Cpu, but Newer MT6235 Cpu with Base 164 is still been figured out, so pls be a bit patient and give us Time to figure out the Solution to this Issue. Once again, avoid working with MT6235 Cpu, once u detect Pinout and see that Cpu dont work on it. McnPro Team |
The Following 5 Users Say Thank You to PhoneCareCenter For This Useful Post: |
03-28-2010, 09:56 | #4 (permalink) | |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Yes, you can make backup any time , Make this topic which not mean's Mcnpro not support 6235, only not very stable, But we are still working on this. Quote:
A, check the cable B, phone connector C, phone without hardware problem. Best regards! Mcnbox | |
The Following User Says Thank You to Mcnbox For This Useful Post: |
03-28-2010, 19:06 | #6 (permalink) | |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Quote:
Best regards ! Mcnbox | |
04-02-2010, 18:55 | #7 (permalink) |
No Life Poster Join Date: May 2007 Location: Badui My home
Member: 508048 Status: Offline Thanks Meter: 123 | what if I read 6235 MTK firmware chip for a long time? this screenshot .. if it can be in the input back to the same phone type asked for his explanation that it was not wrong in progress .... thx |
04-29-2010, 15:17 | #9 (permalink) | |
05-01-2010, 14:28 | #10 (permalink) |
Member: 508048 Status: Offline Thanks Meter: 123 | tes new aupdate phone NX-G801 Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6235 Ver: 0001 SW:8A01 CPU ID: 00000300 Initialize Boot... Flash(Nand) Type: [HYNIX] HY27xS08121M/A Flash(Nand) Code: 00AD0076(00AD0076) Flash(Nand) Size: 0x04200000 Hex Bytes INT/EXT RAM Size: 0x00010000+0x00000000 Checking baud¡* Set Baud:921600 OK. New flash detection way actived Proceding MTK622x CPU encryption... OK Start Writing(Nand)... Write Done. if phone not pwoer on, try to formatS Time used: 5 m 50 s but after flash phone no network.. what wrong? |
05-01-2010, 17:06 | #11 (permalink) | |
05-14-2010, 17:46 | #15 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303402 Status: Offline Thanks Meter: 346 | You are right....@Mr. neokia it is time mcn team proves that this cpu can do perfectly...... i do not expect that this box makes disappointed your ppl who compare with cheap boxes and give more power.... i just see your supporting is better than your update.... what i expect from MCN team, your supporting must be as good as your update i understand, no box is perfect....but, i hope , do not let your ppl sell their box because of un-supported mt6235 cpu perfectly... br aswancamel |
Any News About MTK 6235 Cpu..? | LoveLess | Infinity-Box | 1 | 12-21-2009 03:09 |
MTK 6235 CPU Read Error.. | LoveLess | SpiderMan | 4 | 09-04-2009 13:12 |
About 2.56 not working 6235 cpu fix | jack-china | SpiderMan | 0 | 08-31-2009 09:30 |
Need flash file for MTK-6235 CPU | reaz.com | CPF-BOX Ⅱ | 2 | 08-29-2009 01:47 |
Is infinity support MTK-6235 cpu ?? | reaz.com | Infinity-Box | 2 | 08-27-2009 19:19 |
