Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 12-15-2009, 16:50   #1 (permalink)
Member: 338958
Sonork: 100.1580789
Thanks Meter: 33
additional tool to MCN BOX
can be made if a tool like that for MCN BOX
its function for hp china that no connectors ?????
The Following User Says Thank You to adhidarwis For This Useful Post:
Old 12-16-2009, 02:53   #2 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
how many pin for the connector ? 8 pin ?
The Following 2 Users Say Thank You to Mcnbox For This Useful Post:
Old 12-16-2009, 05:53   #3 (permalink)
Member: 338958
Sonork: 100.1580789
Thanks Meter: 33
yes, 8 pin.
pin at HP using F-bus ....
Old 12-16-2009, 09:03   #4 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Then you no need anyother extra Adapter , direct using Box "Service Rj45" Port !
The Following User Says Thank You to Mcnbox For This Useful Post:
Old 12-27-2009, 06:47   #5 (permalink)
Member: 143878
Thanks Meter: 9
additional tool
can you show diagram
regards
Old 12-28-2009, 12:54   #6 (permalink)
PhoneCareCenter's Avatar
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@tnasoft
U dont need that Tool or the Diagram, cuz McnPro can do without that. Just connect your cable directly to the RJ45 Port on McnPro & u all set.
McnPro Team
Old 01-19-2010, 08:51   #7 (permalink)
Mobileman_hu's Avatar
Member: 3097
Thanks Meter: 30
Hi!
I tried to use MCNpro rj45 connector, but how to select pins for rj 45? Without selecting, and applying pinouts u can't use MCNbox.
So what to set up in sw, or how to setup MCN pro for working on normal rj45?
Thanks!
Mobileman
Old 01-19-2010, 12:09   #8 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Select any 8 Pin cable then apply ! eg. C8A or C8B
Best Regards !
Mcnbox
Old 01-19-2010, 21:32   #9 (permalink)
Member: 3097
Thanks Meter: 30
REALLY THANKS!!!
Mobileman
Old 01-24-2010, 18:46   #10 (permalink)
Member: 907285
Thanks Meter: 14
thanks master.... your's the best
Old 12-29-2010, 05:57   #11 (permalink)
hape_tenso's Avatar
Member: 1199611
Thanks Meter: 23
1. what is pinout of service RJ45 ? 1=... 2=... 3=... ?
2. should we re-detect the pinout if we use in "service RJ45"
thx...
Old 12-29-2010, 11:28   #12 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@hape_tenso
1. what is pinout of service RJ45 ? 1=... 2=... 3=... ? Answer: No Specific Pinouts
2. should we re-detect the pinout if we use in "service RJ45" Answer: Yes, once u connect to RJ45 Port u have to detect Pinout using McnPro Software.
McnPro Team
The Following User Says Thank You to PhoneCareCenter For This Useful Post:
mcn box is e-gate sim system or jaf pkey system somonahmed McnPro Box 5 03-14-2010 14:49
help mcn box cpx_cell McnPro Box 27 03-06-2010 19:28
to new user, driver ft232 mcn box here iwan8818 McnPro Box 7 02-24-2010 13:20
to mcn box iwan8818 McnPro Box 6 08-29-2009 03:42
to mcn pro box iwan8818 McnPro Box 2 04-09-2009 23:19
Page generated in 0.21392 seconds with 10 queries
