01-10-2010, 04:41 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 306026 Status: Offline Thanks Meter: 111 | box error please help when go to selftest box here is the result Welcome to use McnBox! Selected COM8 COM4 COM1 Initialize in progress... Checking data, wait... Serial number: MCN20090923 - D0097 Firmware version: V1.06 Checksum value: 0AB1-29BE Box Connected! Box Operating at high speed port: COM1 Power supply testing...OK Intelligent-resistance testing...OK level testing...OK Intelligent Chip testing...OK Tran-clamps testing... Tran-clamps not normal,Wrong data:04 FT232 testing...OK >>Box Self-testing Completed please help me to fix it |
01-19-2010, 03:38 | #2 (permalink) |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | @Mj Disconnect the phone from box , and repair box firmware, if you have same problem , contact reseller change the main adapter cable for you. Thanks and Regards ! Mcnbox |
01-20-2010, 10:43 | #3 (permalink) |
Freak Poster Join Date: Jul 2006 Location: indonesia
Member: 310458 Status: Offline Thanks Meter: 94 | hiii i have error when selftest,no phone conect to box when selftest. Welcome to use McnBox! Selected COM4 Initialize in progress... Checking data, wait... Serial number: MCN20xxxxxxx Firmware version: V1.06 Checksum value: 0FB4-2CBE Box Connected! Box Operating at high speed port: COM4 Power supply testing...OK Intelligent-resistance testing...OK level testing... 1: set low-volt errorl Intelligent Chip testing...OK Tran-clamps testing...OK FT232 testing... ft232 DSR low test abnormal Box Self-testing Completed and box cant detect phone. |
01-20-2010, 11:17 | #4 (permalink) | |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Quote:
Did you install FTD232 driver? at \Drivers\Box drivers\FTD232 Check please ! | |
01-20-2010, 12:24 | #5 (permalink) | |
Member: 310458 Status: Offline Thanks Meter: 94 | Quote:
if not isntaled box cant coneect right ? Code: Welcome to use McnBox! Selected COM4 Initialize in progress... Checking data, wait... Serial number: MCxxxxxxx Firmware version: V1.06 Checksum value: 0FB4-2CBE Box Connected! >>Box Operating at high speed port: COM4 try other MCN box and selftest its normaly. try repair firmware still probelem like that. | |
01-20-2010, 16:52 | #6 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @utuh Self Test are giving u (ft232 DSR low test abnormal) but is the box working fine?? I see the Box connects without any problem.. McnPro Team |
01-20-2010, 19:14 | #8 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @utuh Try detecting an MTK cpu with Battery to confirm if clamps are working... Post Result, or add me to Messenger for faster Support. McnPro Team |
01-22-2010, 05:55 | #9 (permalink) | |
hope MCN team have solution for my probleme. thanks | |
01-22-2010, 14:22 | #10 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | @utuh Try to change the main adapter cable and detect R/Tx. if same issue , then box hardware get problem , contact reseller change a new box (if under warranty, if not, PM me , i will give you info send to us directly, but you need pay for delivery). Please be patient ! Regards Mcnbox |
The Following User Says Thank You to Mcnbox For This Useful Post: |
01-22-2010, 19:16 | #11 (permalink) | |
ok i will contact my reseller. thanks | |
02-11-2010, 10:29 | #12 (permalink) | |
Banned Join Date: Jan 2010 Location: Now We Back With LGTool
Member: 1216493 Status: Offline Sonork: 100.1590644 Thanks Meter: 1,355 | Quote:
Br Gsm. | |
02-19-2010, 20:21 | #13 (permalink) |
Freak Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 43
Member: 120908 Status: Offline Thanks Meter: 38 | my box like this Box Connected! Box Operating at high speed port: COM6 Power supply testing...OK Intelligent-resistance testing...OK level testing...OK Intelligent Chip testing...OK Tran-clamps testing...OK FT232 testing...OK >>Box Self-testing Completed that normal but if that search that can,t turn on the green light that why or that beacause im upgrade to 2.78 in any phone that cant deteck but in any phone that can work fine |
03-26-2010, 07:48 | #14 (permalink) |
Freak Poster Join Date: Jun 2002 Location: sky
Member: 12495 Status: Offline Thanks Meter: 2 | Welcome to use McnBox! Selected COM50 COM88 Initialize in progress... Checking data, wait... Serial number: MCN20xxxxxx - xxxxx Firmware version: V1.06 Checksum value: 1AA1-39BE Box Connected! Box Operating at high speed port: COM88 Power supply testing...OK Intelligent-resistance testing...OK level testing... 2: Set high-volt errorlset low-volt errorl Intelligent Chip testing...OK Tran-clamps testing...OK FT232 testing...OK >>Box Self-testing Completed whats problems with my box???? |
03-26-2010, 08:22 | #15 (permalink) | |
A, Disconnect multi adapter cable, box only with USB cable and 9V PW, open software do repair, then make a test . B, Do same job on other Computer. And post the result , let me check ! Best regards ! Mcnbox | |
Box Error Please Help | playa0502 | FuriousGold | 8 | 12-11-2009 09:53 |
BOX ERROR please help | sanibm | MT-BOX | 9 | 12-27-2007 13:27 |
martech box error please help!!! | reignsmart | Martech CLIP / Box / Key | 7 | 06-18-2006 17:07 |
