coolsand CT8853 write error ct8853 cpu can only read flash and codes but error when writing back flash or reset[format] & imei write error help >how can i write flash? Welcome to use McnBox! Selected COM16 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN2010viniicell Firmware V1.15 Checksum 7EC6-5EBE Software V3.30 Box Connected! Ready working at COM16 ------------------------------- Start Scanning... ->........... User Abort Connecting... Press Power button now ! Phone Connected! CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Start Reading... Read Done! File saved: D:\Program Files\Mcnbox Team\Mcnpro Box\Flashes\CoolSand\duos1128 Coolsand_GD25Q32.bin Connecting... Press Power button now ! Phone Connected! Initialize boot... CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Start Formatting,Wait... Format Error. ID: 1061 Connecting... Press Power button now ! Phone Connected! Initialize boot... CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Start Formatting,Wait... Format Error. ID: 1061 Connecting... Press Power button now ! Phone Connected! Initialize boot... CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Start Formatting,Wait... Format Error. ID: 1061 Connecting... Press Power button now ! Phone Connected! CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Check firmware,Wait... Unlock Code: 1234 Connecting... Press Power button now ! Phone Connected! Initialize boot... CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Start Writing... Write flash Error. ID: 1057 Connecting... Press Power button now ! Phone Connected! Initialize boot... CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Start Writing... Write flash Error. ID: 1057 Connecting... Press Power button now ! Phone Connected! Initialize boot... CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Start Writing... Write flash Error. ID: 1057 Connecting... Press Power button now ! Phone Connected! CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Start Reading... User Abort Connecting... Press Power button now ! Phone Connected! Initialize boot... CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Start Writing... Write flash Error. ID: 1057 Connecting... Press Power button now ! Phone Connected! Initialize boot... CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Start Writing... Write flash Error. ID: 1057 Connecting... Press Power button now ! Phone Connected! CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Check firmware,Wait... Unlock Code: 1234 Connecting... Press Power button now ! Phone Connected! Check firmware,Wait... Initialize boot... CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) ReImei,wait... Write flash Error. ID: 1057 Connecting... Press Power button now ! Phone Connected! b.r viniicell |
There is no solution from mcn support for now i think......still can't write for coolsand cpu even i have been upgrade to 3.30 soft do we have to wait for next update??? |
@viniicell what the status of your phone why you want to flash it try with low baudrate post result br |
@isokuikiae hello bro its just starting step from mcn team for coolsand cpu so be patient all problems will clear step by step dont worry and if you have any problem pls post screen shot for good help br |
Same thing happens to me with healthy phones. Dump flash file from phone Reading log: Start Scanning... -> Results: GND:2,RXD:4,TXD:6 [G:2 R:4 T:6] Apply to Box Connecting... Press Power button now ! Phone Connected! CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4,0M) Start Reading... Read Done! writting log: Results: GND:5,RXD:6,TXD:1 [G:5 R:6 T:1] Apply to Box Connecting... Press Power button now ! Phone Connected! Initialize boot... Boot Error. ID: 1011 Connecting... Press Power button now ! Phone Connected! CPU Info Coolsand Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4,0M) Check firmware,Wait... User Abort Connecting... Press Power button now ! Phone Connected! Initialize boot... Boot Error. ID: 1011 Connecting... Press Power button now ! Phone Connected! Initialize boot... Boot Error. ID: 1011 Connecting... Press Power button now ! Phone Connected! Initialize boot... Boot Error. ID: 1011 Connecting... Press Power button now ! Phone Connected! Initialize boot... Boot Error. ID: 1011 Hope you can add Write feature for this flash model. Thanks.- |
Start Scanning... -> Results: GND:1 2 4 5 6 ,RXD:8,TXD:9 [G:1 2 4 5 6 R:8 T:9] Apply to Box [G:1 2 4 5 6 R:8 T:9] Apply to Box Connecting... Press Power button now ! Phone Connected! CPU Info Coolsand (88087000) Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Start Reading... Read Done! File saved: F:\FLASHING\COOLSAND\NEXCOM\NC18\Coolsand_GD25Q32 NO SIGNAL Connecting... Press Power button now ! Phone Connected! CPU Info Coolsand (88087000) Flash Type NOR Flash ID 00C80040(00160000) Flash Model GD25Q32 Flash Size 0x400000(4.0M) Initialize boot... Boot Error. ID: 1011 same problem read ok but write error |
Forget MCNpro box buy other box from other team. |
