How conect mstar cpu rj 45? 1 Attachment(s) How conect this phone with mstar cpu .I try like in the picture but it not work .Wath I am doing wrong?Please explaine step by step for read flash m star cpu.With pin finder not detect pinout...thanks |
Mstar CPU phone only support flash phone Via USB, So , please try to using USB cable detect the Pinout. 1, Using USB Scan detect out the charge PIN. 2, Manual setting the Charge pin , then start to Scan the USB D+ D- Best regards! Mcnbox |
Confirm this bugs, will be improve at next version. Best regards ! Mcnbox |
jagdeep u can use dragon cable with pin only 350rs in india, viru also send me last 8 month back only box |
Mtk 6252 successful by Mcnpro Box ------------------------------- Start Scanning... >>->..... Results: CPU: MT6250 VCC:22,GND:3 11 12,RXD:7,TXD:8 [V:2 G:3 11 12 R:7 T:8] Apply to Box Read Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6252 Ver: CA04 SW:0100 Initialize Boot7 ... Flash(Nor) Type [MX] MX25U6435E Flash(Nor) Code 00C20025(00370000) Flash(Nor) Size 0x00800000 Hex Bytes Checking baud... Set Baud:921600 Done. Start Reading(Nor)... The phone information: LEATEK52_6432_10A_PCB01_GPRS_MT6252_S01.L_2450A_V1 _1_3.BIN_FLNMX25U6435E Read Done ! Time used: 2 mins 10 s File Saved: C:\Users\D\Desktop\LEATEK52_6432_10A_PCB01_GPRS_MT 6252_S01.L_2450A_V1_1_3.BIN_FLNMX25U6435E Write Press and Holding Power button now ! Connecting, wait... The File Information: LEATEK52_6432_10A_PCB01_GPRS_MT6252_S01.L_2450A_V1 _1_3.BIN_FLNMX25U6435E >> Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6252 Ver: CA04 SW:0100 Initialize Boot7 ... Flash(Nor) Type [MX] MX25U6435E Flash(Nor) Code 00C20025(00370000) Flash(Nor) Size 0x00800000 Hex Bytes Checking baud... Set Baud:921600 Done. Start Writing(Nor)... Write Done ! Time used: 4 m 16 s Backup Nadata Press and Holding Power button now ! Connecting, wait... CPU: 6252 Ver: CA04 CPUID: 00000700 Release Power Button now Phone detected NV Data saved to: C:\Users\D\Desktop\LEATEK52_6432_10A_PCB01_GPRS_MT 6252_S01.L_2450A_V1_1_3.BIN_FLNMX25U6435E_Nv_data Backup Done. Read IMEI Phone should be Switched on Phone detected, wait... Reading data... Done, IMEI-1: 13579024681122-0 Phone should be Switched on Phone detected, wait... Reading data... Done, IMEI-2: 13579024681122-0 Change IMEI Phone should be Switched on Phone detected, wait... SN to be changed... Done, IMEI-1: 35988888888888-5 Phone should be Switched on Phone detected, wait... SN to be changed... Done, IMEI-2: 35999999999999-8 Phone should be Switched on Phone detected, wait... Reading data... Done, IMEI-1: 35988888888888-5 Phone should be Switched on Phone detected, wait... Reading data... Done, IMEI-2: 35999999999999-8 Format Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6252 Ver: CA04 SW:0100 Initialize Boot7 ... Flash(Nor) Type [MX] MX25U6435E Flash(Nor) Code 00C20025(00370000) Flash(Nor) Size 0x00800000 Hex Bytes Start Formatting (Nor)... Start Addr: 0x768000, Size: 0x98000 Format Done ! |
MCN-BOX Detections mtk6516 os android ^_^ [IMG]http://4.bp.********.com/-HQvCXjuJMk8/Tsdj8ph7MlI/AAAAAAAAAN4/i-26KQ9-9gw/s320/mtk+android.jpg[/IMG] [IMG]http://2.bp.********.com/-LM4HXVuMMMU/Tsdj_T0c7GI/AAAAAAAAAOA/TxZMH6QsSxI/s1600/mt6516+android.jpg[/IMG] My Blog |
^_^ Better direct post logs, some user can not see the images. thanks |
To mcn team TO MCN TEAM WHEN WILL YOUR UPDATE COME FULL SUPPORT 6610/20 CPU WHIC NOT SUPPORTING YET IN YOUR BOX PLS IREQUEST YOU TO GIVE THIS 6610/20 FULL SUPPORT ALL YOUR BOX USER ARE WAITING FOR YOUR POWER FULL UPDATE WHICH CANT OTHER GIVE BECAUSE MCN IS BEST BOX IN THE WORLD WE THINK AND YOU HAVE TO PROVE IT THAT YOU ARE THE BEST AND BEST Welcome to use McnBox! Selected COM60 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN2011XXXXXXXXX Firmware V1.15 Checksum D07E-E6BE Box Connected! Ready working at COM60 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6610 Flash Type NOR Flash ID 00C80040(00160000) Flash Model SF_GD25Q32 Flash Size 0x400000(4.0M) Check firmware,Wait... Done.. Start Formatting,Wait... Start Addr:420000 Size:FFFC0000 Erase Flash Error. ID: N0001 Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6610 Flash Type NOR Flash ID 00C80040(00160000) Flash Model SF_GD25Q32 Flash Size 0x400000(4.0M) Check firmware,Wait... Boot Not support. TO MCN TEAM |
Hi supporter BlackBerry 9800 Not support unknown type of flash Welcome to use McnBox! Selected COM6 COM2 COM3 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN2010XXXXXXXXXXXX Firmware V1.15 Checksum E057-CFBE Box Connected! Ready working at COM6 ------------------------------- Start Scanning... ->. Results: CPU: MT6253. VCC:12,GND:10 11,RXD:3,TXD:2 [V:12 G:10 11 R:3 T:2] Apply to Box Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6253 Ver: 8A04 SW:8A00 Initialize Boot6 ... Flash(Nor) Type NOR_UNKNOWN Flash(Nor) Code 00208832(FFFFFFFF) Flash(Nor) Size 0x00000000 Hex Bytes Flash Type not found, Try other Boot http://dc258.file.qip.ru/img/JQ9rnS2...954422&sizeM=7 |
Please try Boot7 ! thanks |
Please MCN always a detective virus MCN error always get the virus, I wear the Eset NOD32 Anti-virus |
Realy ? ;) Which virus you got ? |
Please how the solution, so that com does not get the virus. |
