Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 11-15-2011, 11:45   #16 (permalink)
Member: 739324
Thanks Meter: 11
Originally Posted by Mcnbox View Post
Please try boot7
Best regards !
Mcnbox
Connecting, wait...
Phone detected, wait..
CPU: 6235 Ver: 8A04 SW:8A01
Initialize Boot7 ...
Flash Inf not found, the Phone maybe bad
Circuit maybe bad
read ,,write normal format not suport,,,,,,,,,,
help,,,,,,,,,, whether this is software or hardware????????? tanks
Old 11-15-2011, 12:37   #17 (permalink)
unlockers555's Avatar
Member: 547368
Thanks Meter: 245
Originally Posted by unlockers555 View Post
hyper box r u support spreadtrum cpu sc6800h1 ?
because i have 10pcs china 4g to unlock.
if you can do it,then i buy HYPERBOX
sorry mcnpro.....................
Old 11-15-2011, 13:26   #18 (permalink)
Member: 547368
Thanks Meter: 245
please give me answer ......................
Old 11-15-2011, 16:32   #19 (permalink)
Member: 547368
Thanks Meter: 245
mcnpro. supporter r u there..................?
Old 11-15-2011, 17:55   #20 (permalink)
Member: 217769
Thanks Meter: 14
File error restore defaut issue
Hi, I have lot of phone with displaying on screen : FILE ERROR RESTORE DEFAUT. The phone pinouts are detected but cannot boot. Is it software or hardware problem ?
THANKS
Old 11-16-2011, 02:56   #21 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Full Supported !
Best regards !
Mcnbox
The Following User Says Thank You to Mcnbox For This Useful Post:
Old 11-16-2011, 03:04   #22 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
THANKS
I can not image which is hardware or software problem , But i think which was software problem. as you said Pinout can be detected, but can not boot that's a little strange. Could you open those kindly phone , And make some picture ?
Best regards !
Mcnbox
Old 11-16-2011, 03:05   #23 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Originally Posted by dianda View Post
Connecting, wait...
Circuit maybe bad
Check hardware first ! thanks
Mcnbox
Old 11-16-2011, 10:50   #24 (permalink)
Member: 447517
Thanks Meter: 22
touchscreen calibration mstar cpu
helo sir,, how to calibration mstar cpu??
Ready working at COM46
Scanning pin status,please waiting...
Pin-status Scan Done
Scanning,waiting...
Operation done, Pin detect out.
BOOT£º4
USB D-: 2 USB D+: 3 Mstar MSW853X
Press [ Save ] to save Pinout
Total expend 1 seconds
[G:5 D-:2 D+:3 Down:4] Apply to Box
If Scan other phone, please click [Stop]
Connecting, wait...
Connect Ok.
Not support Reset.
Old 11-16-2011, 12:07   #25 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Scanning,waiting...
BOOT£º4
Connecting, wait...
Connect Ok.
Not support Reset.
You have to be sure which is Nand or Nor flash IC. then chose related boot do the jobs. In fact , we have not make calibration function yet, so maybe you can try to reflash or reset your phone then.
Best regards!
Mcnbox
Old 11-16-2011, 15:35   #26 (permalink)
Member: 1562038
Thanks Meter: 35
McnPro surprise update SPD 6800H support
I need McnPro surprise update SPD 6800H support, because at present still have no box is other support, customer McnPro in thailand wait for update good news for CPU SPD 6800H support
Thank.
Old 11-16-2011, 16:10   #27 (permalink)
Member: 918154
Sonork: As Long As I Can
Thanks Meter: 22
dear MCN pro Team.....
i was try to connect Samsung E1080T....RxTx scan Ok and format option disable
Start Scanning...
Results:
SI4904 Chipset
VCC:7 8,GND:12 19,RXD:5,TXD:4,BOOT:6
[V:7 8 G:6 12 19 R:5 T:4] Apply to Box
but when i try to read or unlock with Boot1 or Boot2 ....
Please Hold "ON" to download Boot ok...
Connected to Phone(Holding [ON]).
Downloading Boot...
download boot ok
and nothings happen.....
please give me an info....it's support or not to read n write firmware for Samsung E1080T or unlock it ? if supported please tell me how to do it (Step by Step)?
Thanxs....
Old 11-16-2011, 18:20   #28 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Start Scanning...
Results:
SI4904 Chipset
Downloading Boot...
download boot ok
Thanxs....
Try to reflash phone !
Old 11-17-2011, 09:22   #29 (permalink)
Member: 1562038
Thanks Meter: 35
McnPro Box with G-net G8 MT6516 Android
I Test McnPro Box Scaning pin out it can Read Full Flash G-net G8 MT6516 Android get, But can't flash file at Read can't return, i need mcnpro can Unlock, read code, Read Full Flash , and , Flash , be unexpected that can, i test take every Chinese other box at i have still don't can do scaning pin out get but can't iron the file or use which order have just McnPro only that can but Read for long time
Thanks
Old 11-17-2011, 18:42   #30 (permalink)
.::jagdeep-Gupta::.'s Avatar
Member: 787829
Sonork: 100.1615114
Thanks Meter: 910
Test report cpu 6610 mcn box
Connecting, wait...
Phone Connected!
Info: Spreadtrum Boot Block version 2.0
Initialize boot...
CPU Info 6610
Flash Type NOR
Flash ID 00C80040(00160000)
Flash Model SF_GD25Q32
Flash Size 0x400000(4.0M)
Check firmware,Wait...
Done..
Start Formatting,Wait...
Start Addr:420000 Size:FFFC0000
Erase Flash Error. ID: N0001
Connecting, wait...
Phone Connected!
Initialize boot...
CPU Info 6610
Flash Type NOR
Boot Not support.
Connecting, wait...
Phone Connected!
Initialize boot...
Boot Error. ID: D0000
Connecting, wait...
Phone Connected!
Initialize boot...
CPU Info 6610
Flash Type NOR
Boot Not support.
Connecting, wait...
Phone Connected!
Initialize boot...
CPU Info 6610
Flash Type NOR
Format Error. ID: R1003 , SatrAddr and size > flash size
MCN BOX WHAT IS THIS PROBLEM PLS SOLVE THIS ERROR NOT SUPPORTING 6610 CPU IN LATEST VERSION 3.21
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 14:12
Page generated in 0.46783 seconds with 9 queries
